BavarianWrench Samba Member
Joined: January 18, 2004 Posts: 1045 Location: Oceans Edge
Posted: Fri Jul 13, 2018 7:19 am Post subject: Re: Broke the spark plug! WBX 2.1L 1987 |
Hello Jonas
Welcome to the madness of the Wasserboxer. That is an ugly snap on that spark plug. I am always looking to do a sneak repair and save some labor by avoiding pulling the head. In your case I think pulling the heads and I say both heads would be smart. You have gone so far in the removal and teardown, intake and exhaust are removed. In your third photo I notice some of the crusty corrosion developing at the head gasket that develops into pitting and a compromised seal to the coolant. It would be a bummer to have that leak in a year or so.
Pull the head, use any of many methods to get the broken end out. Clean up the engine and reseal the whole thing. I support pulling the head. Wish you all the best. |
CdnVWJunkie Samba Member
Joined: February 01, 2004 Posts: 1110 Location: Sarnia, Ontario, Canada
Posted: Fri Jul 13, 2018 10:30 am Post subject: Re: Broke the spark plug! WBX 2.1L 1987 |
I've been here before. I soaked the broken spark plug with quality penetrating oil for ~ 1 week, daily. Then I took a oxy-ace torch and got the broken insert hot. Pounded in a helical style EZ out. Boom out it came. Chased the theaded and thoroughly blew the hole out. That engine is still in use. |
jonas.andersson Samba Member
Posted: Sat Jul 14, 2018 3:03 pm Post subject: Re: Broke the spark plug! WBX 2.1L 1987 |
what a day!!
Started off with a total failure! I even broke the Ez out this time while beeing inside the broken spark plug
after several attempts to weld a nut onto it and back it out i succeed
so back to the first problem! getting the plug out I started off this time with another approach... file it down! After almost 40 min of filing a upper and lower line it came loose and i could simply pick it out with pliers.
Tbob Samba Member
Joined: May 26, 2007 Posts: 417 Location: Pensacola, Fl.
Posted: Mon Jul 16, 2018 7:36 pm Post subject: Re: Broke the spark plug! WBX 2.1L 1987 SOLVED! |
Anyone else notice the offending plug is a "made in Russia" Bosch? I had dismal success with a set in my 85 1.9, miss-firing and easily fouled. Re installing the old plugs solved the problem. At least mine didn't break in half like the OP's, but it made me concerned about the quality of Russian parts (as if the old URAL motorcycles weren't bad enough). Bosch seems to be a marketing company only now, no longer worried about quality and engineering. The corporate effort seems to be only on getting the brand name on any and all products possible. _________________ 1969 Deluxe, owned since 1973
1973 Westfalia, owned since 1983
1980 Westfalia, watercooled conversion
1985 Westfalia, stock!
1986 Westfakia, Audi I-4 conversion
A couple of trucks and a couple of Jeeps |
Posted: Mon Jul 16, 2018 9:06 pm Post subject: Re: Broke the spark plug! WBX 2.1L 1987 SOLVED! |
Tbob wrote: |
Anyone else notice the offending plug is a "made in Russia" Bosch? I had dismal success with a set in my 85 1.9, miss-firing and easily fouled. Re installing the old plugs solved the problem. At least mine didn't break in half like the OP's, but it made me concerned about the quality of Russian parts (as if the old URAL motorcycles weren't bad enough). Bosch seems to be a marketing company only now, no longer worried about quality and engineering. The corporate effort seems to be only on getting the brand name on any and all products possible. |
I have been ranting against Bosch for ten year or more at this point in time. For a lot of what the sell they are as trashy as any brand out there. It is sad that what was once the go to brand should now be avoided. |
