JeffnDes1977 Samba Member
Posted: Wed Feb 21, 2024 2:16 pm Post subject: Oil Light comes on ((and freaks me out)) |
1977 Bus 2.0FI - Lately my oil light has been coming on randomly and I don't care for it. It usually happens after it warms up and I head out to work. About a mile down the road, it comes on at the second stop I make. Then its usually normal the rest of the drive. I took it in to my local aircooled VW service shop and they checked the oil pressure and its fine. I have an engine saver dipstick and I feel like I never saw the oil light on until I started using that dipstick, other than on start-up.
A couple notes
I've owned this bus since 2007 and have been driving it at least once a week for the last few months - the most its moved since I got it. It sat off and on for several years previously.
I have a print of the oil pressure numbers at home, but not in front of me at this moment.
Any info helps _________________ 1977 Bay 2.0 FI
1968 Sandrail/ woods buggy project
1970 Sandrail
19?? Sandrail project - soon to be for sale!
1960 Beetle - My first car! |
bsairhead Samba Member
Joined: October 08, 2008 Posts: 3580 Location: viroqua wi.
Posted: Wed Feb 21, 2024 2:44 pm Post subject: Re: Oil Light comes on ((and freaks me out)) |
JeffnDes1977 wrote: |
A couple notes
Any info helps |
Change the lamp in the dash from a 1.2w to 1.5 or 2. |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34022 Location: Conejo Valley, CA
Posted: Wed Feb 21, 2024 3:43 pm Post subject: Re: Oil Light comes on ((and freaks me out)) |
Do the 2L engines have a pressure relief valve like the 1600s? Maybe it's sticking from a burr or debris? |
Posted: Wed Feb 21, 2024 4:12 pm Post subject: Re: Oil Light comes on ((and freaks me out)) |
Unhook it from the dipstick and see if that stops the light from coming one. |
airschooled Air-Schooled
Posted: Wed Feb 21, 2024 5:50 pm Post subject: Re: Oil Light comes on ((and freaks me out)) |
Another solution looking for a problem, those dipsticks… _________________ Learn how your vintage VW works. And why it doesn't!
www.airschooled.com |
timvw7476 Samba Member
Posted: Wed Feb 21, 2024 9:15 pm Post subject: Re: Oil Light comes on ((and freaks me out)) |
I'm going to assume that 'second stop' is at a downhill slope/grade & the oil is pooling near the 1/3 cylinders. Just some air. Happens. |
Abscate Samba Member
Posted: Thu Feb 22, 2024 4:02 am Post subject: Re: Oil Light comes on ((and freaks me out)) |
As long as it goes out on light revolutions, ignore it, just like the manual says. _________________ .ssS! |
mikedjames Samba Member
Joined: July 02, 2012 Posts: 2745 Location: Hamble, Hampshire, UK
Posted: Thu Feb 22, 2024 12:08 pm Post subject: Re: Oil Light comes on ((and freaks me out)) |
The "save my bug" dipstick starts the oil light blinking if you put it in a bus, and get the bus properly warmed up, not even hot for a bus.
Because a bus runs hotter than a bug. _________________ Ancient vehicles and vessels
Globespotter Samba Member
Joined: February 16, 2012 Posts: 1770 Location: Newmarket, ON
Posted: Thu Feb 22, 2024 10:31 pm Post subject: Re: Oil Light comes on ((and freaks me out)) |
At least on a Type 1 it’s not in the cooling airflow inlet AND passing through the fan shroud.
Heat soak city.
Posted: Fri Feb 23, 2024 2:40 am Post subject: Re: Oil Light comes on ((and freaks me out)) |
Sales of the dipstick rocketed after the Dukes ofHazzard aired…. _________________ .ssS! |
Posted: Sat Feb 24, 2024 6:04 am Post subject: Re: Oil Light comes on ((and freaks me out)) |
I used to figure that any add-ons being sold for VW's by JC Whitney were very apt to be bogus, while today this same business has been taken over by others like CIP. Glad that when I first got into VWs, the recommended oil for that car was a straight 30wt for warm season use with a note about not using multi-grades, which was the same advice given in a class on lubrication that I had taken, which was taught by a former EXXON lubrication engineer who had helped develop EXXON's late 1960's multigrades. I figure that advice helped save me from ever going down the VW engine oil rabbit hole that so many still willfully crawl into.
