LAGrunthaner Samba Member
Joined: March 18, 2007 Posts: 5509 Location: 1st Coast
Posted: Fri Jul 13, 2018 3:50 am Post subject: 67 gas door bumper which way to insert? |
I just got my gas door bumpers and I am pretty sure they insert in this direction. Please confirm on direction and do I grab the end with a plier (flat no groves) to pull through (guess I'm just weak)?
_________________ American Red Cross Safe And Well:
Maui Roadsters
www.mauiroadsters.com
http://www.oacdp.org
Lind wrote: |
Okie Adam Samba Member
Joined: November 07, 2003 Posts: 1347 Location: OOOOOOOOOOOOOOOOOklahoma
Posted: Fri Jul 13, 2018 4:21 am Post subject: Re: 67 gas door bumper which way to insert? |
I put mine in the opposite way, with the cone facing out and the flat side towards the motor. A little lube and pliers to pull it through did the job. It wasn't easy but then again you don't want them coming out! _________________ Oil Capital Air Cooled
55 Wolfsburg Kombi
60 Walkthrough Kombi
62 Single Cab
66 21window
67 so42
76 Westy
64 Karmann Ghia |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24765 Location: Olympia Wash Rinse & Repeat
Posted: Fri Jul 13, 2018 6:49 am Post subject: Re: 67 gas door bumper which way to insert? |
Did a search of the gallery for "bus gas door" with no luck. Then tried "bus gas cap" and got this:
_________________ In Stereo, Where Available! |
BulliBill Samba Member
Joined: July 09, 2004 Posts: 4574 Location: St Charles, MO
Posted: Fri Jul 13, 2018 8:16 am Post subject: Re: 67 gas door bumper which way to insert? |
Eric&Barb wrote: |
Hi Linda,
Yep! The photo that Barb and Eric posted shows the way they should be installed. I usually start to push them into the hole from the inside towards the outside. I place a finger on the flat head of the rubber grommet (a little smear of lube around the conical shaped shaft of the rubber grommet that has to squeeze through that hole in the sheet metal is helpful) and while keeping outward pressure on the grommet with that finger, I use either my fingers to wiggle the cone or a small flat blade screwdriver to help press and pry the rubber through the sheet metal. Pry and pull the rubber all the way 360 degrees around the cone of rubber pulling a little more each time until the grommet groove snaps into place. Be careful not to slip with the screwdriver and scratch your paint (ask me how I know that).
Then test the fit of the door in the closed position. If the rubber is too tall and the door isn't closed flush with the body, then carefully use a new razor blade to shave off a little rubber at a time off the top (outward) of the cone until the door shuts flush.
Job done!
Bill Bowman _________________ I'm looking for these license plate frames for my fleet:
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help! |
Posted: Sat Jul 14, 2018 3:06 am Post subject: Re: 67 gas door bumper which way to insert? |
Thanks, Eric&Barb, yes that that was my first step I typed "bus gas door" yes I should have tried bus gas cap. Now when I see bus gas cap results I see flat bumpers.
Thanks BulliBill for the extensive answer.
BulliBill wrote: |
Eric&Barb wrote: |
Hi Linda,
Job done!
Bill Bowman |
Maui Roadsters
Lind wrote: |
Clara Samba Member
Posted: Sat Jul 14, 2018 7:15 am Post subject: Re: 67 gas door bumper which way to insert? |
I think the top pic is a 67
second is bay,
third is my 66 kombi
did they change the bumper for 67? when they dropped the lock?
maybe check the parts list
LAGrunthaner wrote: |
BulliBill wrote: |
Eric&Barb wrote: |
Hi Linda,
Job done!
Bill Bowman |
hitest Samba Member
Joined: September 30, 2008 Posts: 10296 Location: Prime Meridian, ID
Posted: Sat Jul 14, 2018 9:16 am Post subject: Re: 67 gas door bumper which way to insert? |
Linda- as suggested- they do pull through toward you. No tools are needed and I don't know a more appropriate way to say this other than to just say it (please forgive me)...
Warm it in your hand for a minute and pull it through like a, ahem, titty twister. Pull and flick it side to side and around. No lube required- just hand warmth. _________________
EverettB wrote: |
FU#5 |
zmichael84 Samba Member
Joined: October 24, 2016 Posts: 129 Location: Murrieta, CA
Posted: Sat Jul 14, 2018 9:22 am Post subject: Re: 67 gas door bumper which way to insert? |
hitest wrote: |
Warm it in your hand for a minute and pull it through like a, ahem, titty twister. Pull and flick it side to side and around. No lube required- just hand warmth. |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14271 Location: Casa de Oro, California
Posted: Sat Jul 14, 2018 11:54 am Post subject: Re: 67 gas door bumper which way to insert? |
You should try them with the cone part coming out at first. Those replacement ones allow the door to sit flush that way out. If you don't like it then you can tweak them out from the inside and reverse them. But then the door strikes the paint when it slams. Those original ones that look like yours but going inward have a thicker bumper. |
zozo Samba Member
Joined: October 15, 2005 Posts: 5217 Location: South of Ol' San Antonio
Posted: Sat Jul 14, 2018 3:37 pm Post subject: Re: 67 gas door bumper which way to insert? |
Bottom front and back, top front and back.
I’d bet the ranch these are original.
hitest Samba Member
Posted: Sat Jul 14, 2018 3:55 pm Post subject: Re: 67 gas door bumper which way to insert? |
Exactly. They pull through from the inside out. They all start off life as cones and crush to the trumpet mute shape. They provide rattle free pressure against the gas door latch- exactly how the bumpers on an early beetle's glove box does. They keep both items from shaking themselves open. But you cats might not know about them there beetles.
I can further add through extensive rubber nipple research that the WCM bumpers are softer than WW's, but have a slightly looser fit where they mount. What they do in VWs is a matter for another forum. _________________
EverettB wrote: |
FU#5 |
