Smileybuggy Samba Member
Joined: June 13, 2018 Posts: 13 Location: Chicago, IL
Posted: Fri Jul 13, 2018 6:48 am Post subject: Installing new headlights without high beams? |
So I'm new at this but I have a 69 dune buggy manx replica and I'm trying to install new headlights. New headlights came with 3 wires, my hook up only has 2. I'm assuming the wires on the new one are for high beam, low beam and ground. My buggy doesn't have any switch for high beams, it just has a toggle switch for the current headlights, which don't laugh, but they are tractor headlights... PO put them on just to get lights on it quickly.. Anyways, I'm assuming that since there are only 2 wires, the one missing is for the high beams? So, I don't really care if I have high beams, can I hook these up and have them work without using that 3rd wire. And if so, what do I do with that 3rd wire? Im not the best at wiring so I don't want to get into adding high beams just yet. |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20378 Location: Just a tiny bit west of Yosemite Valley
Posted: Fri Jul 13, 2018 7:48 am Post subject: Re: Installing new headlights without high beams? |
Not sure of tractor lights (not DOT approved/street legal) ... But yes you can make them work....
This would be somewhat typical of headlight circuit that generally works for high/low operation...
First thing I would do is be sure the two wires are not the high and low wires and ground is missing....
Typical of back of sealed beam headlight...
Posted: Fri Jul 13, 2018 8:23 am Post subject: Re: Installing new headlights without high beams? |
Thanks, we are ditching the tractor lights. Im sure they don't have high beams. I don't even have a switch or anything inside the car for high beams, so as of right now, I don't want to mess with it. I bought actual bucket headlights made for a buggy which is what I'm trying to install. Just wondered what to do with that 3rd wire on the new one. I only have the 2 wires going to the tractor light right now. I was hoping this was going to be easy hook up |
Q-Dog Samba Member
Joined: April 05, 2010 Posts: 8699 Location: Sunset, Louisiana
Posted: Fri Jul 13, 2018 11:26 am Post subject: Re: Installing new headlights without high beams? |
To be street legal you need high and low beams.
Instead of the relay and switch, why not use the good old-fashioned foot operated dimmer switch? Existing switch sends power to the foot switch and foot switch selects between high and low beams. Cheap, simple, and effective. _________________ Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle |
Posted: Sat Jul 14, 2018 8:22 am Post subject: Re: Installing new headlights without high beams? |
Thanks, I appreciate the tip. We will add the high beams eventually, but we just want to get the new lights on the way it is just until we have some extra time to tackle it. There are other wiring things we have to do that we want to do while we're in there. |
tgodber Samba Member
Joined: May 02, 2004 Posts: 410 Location: Okanagan Falls B.C. Canada
Posted: Sat Jul 14, 2018 11:21 am Post subject: Re: Installing new headlights without high beams? |
I used the old fashioned foot dimmer switch. I mounted it in the dash. A little redneck but it works well. _________________ My wife said I never listen to her.
Or something like that! |
Posted: Sat Jul 14, 2018 3:44 pm Post subject: Re: Installing new headlights without high beams? |
Yeah, funny you should say that, that's prob where it'll end up. That's where the PO put the toggle switch for the turn signals 😉 Just trying to find out if, temporarily, I can hook the headlights up without the high beams because I despise the tractor lights.. |
slalombuggy Samba Member
Posted: Sat Jul 14, 2018 6:02 pm Post subject: Re: Installing new headlights without high beams? |
Just use a 3 position toggle switch with an on/off/on set up. I used these in all my buggies and race cars. If you put the switch in the up down position, when you flip the switch down its low beams, up is high beams and center is off. I have also used these switches for signal lights but mounted them in the horizontal position so the toggle moves side to side. Super simple and cheap. I do spend money and good good toggle switches though and for my own stuff I have a stash of MIL Spec switches I got from a surplus shop that are bullet proof.
brad |
didget69 Samba Member
Joined: July 22, 2004 Posts: 4927 Location: Raleigh, North Carolina
Posted: Sun Jul 15, 2018 6:45 am Post subject: Re: Installing new headlights without high beams? |
I'm using 6" tractor headlight buckets in my build,
using H4 Low/High beam bulb / housing assemblies. (5.75")
bryan _________________ I never found the need to impress people with any mechanic certifications, trophies or track wins... unless it was for Mom to post on the refrigerator door. |
EVfun Samba Member
Posted: Sun Jul 15, 2018 7:43 am Post subject: Re: Installing new headlights without high beams? |
Smileybuggy wrote: |
Its an easy hook up. The new headlight buckets typically come with a plug with wires to connect to the headlight bulb. Just wire to the low beam and ground terminals. Make sure the high beam wire that comes out of the plug is taped off so it cannot short to ground. It is not legal, but no one is likely to know because no one should be seeing your high beams from the front (that's rude). I've done it on a Bug before when the floor dimmer switch failed. For a short while it was a wire from the headlight switch terminal to the low beam fuses on the fuse block. Worked fine and nobody else knew (until now). _________________
Wildthings wrote: |
Posted: Sun Jul 15, 2018 8:35 am Post subject: Re: Installing new headlights without high beams? |
Note black wire from shell of K5 - K2 - K3 bulbs going to fuse position that is powered when ever IGN switch is on...
Grounds to light lamps are supplies buy ALT/GEN or switches attached to bulbs (blue wires with tracers)...
Posted: Sun Jul 15, 2018 9:19 am Post subject: Re: Installing new headlights without high beams? |
Thank you EVfun!!! I so appreciate everyone's info on hooking up the high beams, I will use this info shortly when I tackle the other wiring stuff. 🙂 for now, I am way too excited to get the old lights off and the new ones on. Hopefully I can get this done today... |
Posted: Sun Jul 15, 2018 3:03 pm Post subject: Re: Installing new headlights without high beams? |
Got them installed!!! Such an improvement!! Thanks everyone for all the advice, it will come in handy soon 🙂 I'm attaching a before and after so you can see why I couldn't get the tractor lights off quick enough!
