scameronh Samba Member
Joined: November 16, 2016 Posts: 4 Location: Orange County, CA
Posted: Fri Jul 13, 2018 11:30 am Post subject: Help needed in replacing shifter plate |
The plastic plate that is around the shifter arm on my Eurovan is broken. This is the plate that moves when you move the shifter. It helps to seal the cabin. Mine cracked and broke so now I can see through to the underside of the car.
Couple questions:
What is this plate called?
Where can I buy one?
How do I replace it?
Thanks for the help.
Scott |
markcm2 Samba Member
Joined: September 02, 2015 Posts: 505 Location: Bellingham, Washington
Posted: Fri Jul 13, 2018 11:47 am Post subject: Re: Help needed in replacing shifter plate |
scameronh wrote: |
Couple questions:
Scott |
I just bought one of these, then realized you can easily make one. For example I just bought some new kneepads for mountain biking which came on a sheet of black plastic that would work perfect.
This thread has all the information you need:
https://www.thesamba.com/vw/forum/viewtopic.php?t=692586&highlight= |
Posted: Sun Aug 26, 2018 9:32 pm Post subject: Re: Help needed in replacing shifter plate |
Thanks for the input. I ended up using the plastic sheeting from the bottom one of my wife's reusable grocery bags. Looks perfect and easy to cut. |
