gimmesomeshelter Samba Member
Joined: May 08, 2004 Posts: 1466 Location: San Carlos, CA
Posted: Fri Jul 13, 2018 7:38 pm Post subject: Vintage Full Flow Filters |
I've collected a number of vintage Fram full flow filters over the years, and I'm wondering which ones I should use. I would like to use one of my smaller ones for aesthetic reasons, but I suspect that a larger filter will reduce the chance of a big pressure drop. I've looked for data from the various filter companies, but I haven't found any. Comments anyone?
Cheers,
Paul _________________ "I would rather have questions that can't be answered than answers that can't be questioned."
Richard Feynman |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76902 Location: Sneaking up behind you
Posted: Fri Jul 13, 2018 8:06 pm Post subject: Re: Vintage Full Flow Filters |
If I remember correctly, they are all bypass filters and only filter some of the oil eventually cleaning all the oil. These are different from full flow that all the oil passes through. _________________ Glenn
Member #1009
#BlueSquare |
Posted: Fri Jul 13, 2018 9:01 pm Post subject: Re: Vintage Full Flow Filters |
These are full flow, not bypass filters. The most common is the FH6-PL which was used by Denzel.
Cheers,
Richard Feynman |
Glenn Mr. 010
Posted: Sat Jul 14, 2018 5:22 am Post subject: Re: Vintage Full Flow Filters |
gimmesomeshelter wrote: |
Paul |
Don't then get oil from a fitting at the oil pressure switch and return it through a hollow stud? _________________ Glenn
Member #1009
#BlueSquare |
Posted: Sat Jul 14, 2018 8:32 am Post subject: Re: Vintage Full Flow Filters |
Here's a typical setup.
Oil is pumped in from a special oil pump cover and returned where where the oil pressure sensor screws into the case.
Cheers,
Richard Feynman |
Glenn Mr. 010
Posted: Sat Jul 14, 2018 12:25 pm Post subject: Re: Vintage Full Flow Filters |
Got it... I stand corrected.
This is what I was thinking.
Member #1009
#BlueSquare |
slalombuggy Samba Member
Posted: Sat Jul 14, 2018 7:43 pm Post subject: Re: Vintage Full Flow Filters |
Pressure in a sealed system is equal in all directions regardless of size. There will only be a difference at startup but once it is up to pressure the size of the filter will have no effect on engine oil pressure.
brad |
