mabbo Samba Member
Joined: October 13, 2004 Posts: 208 Location: United Kingdom
Posted: Sat Jul 14, 2018 9:30 am Post subject: 1955 questions - Tail light wiring. Fuel reserve tap. Tar boards |
Hi... I have a couple of questions about my 1955 Swedish project.
The rear fenders were removed when I got the car, I have fitted the passenger side and heart tail light, which all works as it should... But I cant see where the wiring should run from the factory for the drivers side. The wiring for both sides runs into the rear valance then I cant trace the drivers side. Where should it run?
Also, my fuel reserve tap is broken. This is the one that was fitted to my fuel tank:
The lever was fitted loosely in the car, but it looks like there should be a clevis pin or something similar fitted to attach the lever to the tap. What is 'correct'?
The tar boards in my engine bay look original, but are out of shape... Any tips on how to get them looking a bit better?
Thanks, Neil |
RareAir Samba Member
Joined: May 11, 2002 Posts: 14577 Location: 18 miles North of the border
Posted: Sat Jul 14, 2018 10:41 am Post subject: Re: 1955 questions - Tail light wiring. Fuel reserve tap. Tar boards |
mabbo wrote: |
Thanks, Neil |
Original was a “R” clip to fasten the lever to the petcock. But most people just use a cotter pin
_________________ 1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241 |
Loren Samba Member
mabbo Samba Member
Posted: Sun Jul 15, 2018 12:06 pm Post subject: Re: 1955 questions - Tail light wiring. Fuel reserve tap. Tar boards |
thanks guys |
txoval Samba Member
Joined: January 23, 2004 Posts: 3552 Location: The Woodlands, TX
Posted: Sun Jul 15, 2018 1:11 pm Post subject: Re: 1955 questions - Tail light wiring. Fuel reserve tap. Tar boards |
The wiring to the drivers side runs in upper section of the rear apron...you should be able to see it looking from under the car...your muffler might be blocking your view |
favguy Samba Member
Joined: January 25, 2012 Posts: 236 Location: England
Hazza6542 Samba Member
Posted: Sun Jul 15, 2018 7:28 pm Post subject: Re: 1955 questions - Tail light wiring. Fuel reserve tap. Tar boards |
I will try and get a photo later of my 55's original wiring for the hearts and where it runs. If you're not too concerned, some basic twin core or three core wire is pretty similar to original if you need it. _________________ 55 build: https://www.thesamba.com/vw/forum/viewtopic.php?t=680057 |
My57Oval Samba Member
Posted: Sun Jul 15, 2018 8:12 pm Post subject: Re: 1955 questions - Tail light wiring. Fuel reserve tap. Tar boards |
For the tar boards, get a crappy used oven and bake them for 30 minutes at 250 degrees. Then remove and reshape, place back in engine bay with oven gloves.
I'm not keen on the WW/WCM replacements although you may like them.
R |
ZENVWDRIVER Samba Member
Joined: November 07, 2008 Posts: 3340 Location: N.E. Oklahoma
Posted: Mon Jul 16, 2018 2:22 pm Post subject: Re: 1955 questions - Tail light wiring. Fuel reserve tap. Tar boards |
... while the fuel tap, you are using, will function, my'55s have the type with a little filter as pictured, on top... in my spare parts box.
_________________ 5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK |
Posted: Mon Jul 16, 2018 2:28 pm Post subject: Re: 1955 questions - Tail light wiring. Fuel reserve tap. Tar boards |
Hazza6542 wrote: |
I will try and get a photo later of my 55's original wiring for the hearts and where it runs. If you're not too concerned, some basic twin core or three core wire is pretty similar to original if you need it. |
... most every time I went to the all-VW salvage, i'd get a complete harness or two... have plenty of correct wiring to make little harnesses - if you need any, PM me. _________________ 5/50, pastel green 11G - SOLD
1960 single cab
'87 Toyota MR2
