spectre1995 Samba Member
Joined: May 06, 2018 Posts: 57 Location: El Segundo, CA
Posted: Sat Jul 14, 2018 9:41 am Post subject: Fuel Gauge not working & blew a fuse (1973 Super Beetle) |
Im relatively new to VW's and I'm going through some of the faulty electrical stuff (headlights and fuel gauge primarily) and I noticed the two nuts holding the yellow wire to the gauge, and the vibrator unit to the speedo body were missing. I replaced both nuts,turned the key, the fuel gauge started to work for about ten seconds, then I heard a pop and found the white #12 fuse (all the way to the right hand side) was blown. What sorts of things would cause this? I thought it might be the loose or dirty connectors so I cleaned up all the connection points and tightened everything up, and this happened.
Also, my low beams never work, and my high beams only work *sometimes* (seemingly at random). Does this sound like more of a ground issue, or possibly a faulty switch or bulbs? |
