Rmvr53 Samba Member
Posted: Sat Jul 14, 2018 4:06 pm Post subject: Build a 2 liter from a VW or start with a T4? |
What (and why) would the differences be in building a 2 liter engine up from a VW base (72/94mm bore/stroke and work the case) vs just starting with a 2 liter T4 engine. This is going in a vintage Sports Racer. It needs to stay under (just under) 2L.
thanks for the input
Bill |
jpaull Samba Member
Joined: February 22, 2005 Posts: 3465 Location: Paradise, Ca
Posted: Sat Jul 14, 2018 4:11 pm Post subject: Re: Build a 2 liter from a VW or start with a T4? |
You might as well post a political debate or a "Which oil is best" thread. |
Rmvr53 Samba Member
Posted: Sat Jul 14, 2018 4:21 pm Post subject: Re: Build a 2 liter from a VW or start with a T4? |
and to add the proverbial fuel to the fire, I don't want to go broke building nor maintaining it...
Bill |
modok Samba Member
Joined: October 30, 2009 Posts: 26787 Location: Colorado Springs
Posted: Sat Jul 14, 2018 4:27 pm Post subject: Re: Build a 2 liter from a VW or start with a T4? |
All engines like this cost pretty much the same to build IMO, about 2000$ plus labor.
If you have somebody else do all the labor then you are at their mercy, for better or worse. |
DeathBySnuSnu Samba Member
Posted: Sat Jul 14, 2018 4:30 pm Post subject: Re: Build a 2 liter from a VW or start with a T4? |
Well..... a type 1 would be a lot cheaper and there are plenty aftermarket parts for it.
A type 4 is more robust. Heavier case, more cooling fin area. More expensive and less available hot rod aftermarket.
I suppose you could get comparable power from each. The cross flow head of the type 4 may have more potential......if the parts and research are available. _________________
modok wrote: |
And look at the SHAPE of the curves, just smooth, like gods own slingshot. . |
modok Samba Member
Posted: Sat Jul 14, 2018 5:19 pm Post subject: Re: Build a 2 liter from a VW or start with a T4? |
Will it be high compression for race gas? |
bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4343 Location: Los Angeles, CA 90016
Posted: Sat Jul 14, 2018 6:52 pm Post subject: Re: Build a 2 liter from a VW or start with a T4? |
The heads are gonna be the most expensive parts for the T4 engine. Whereas a good set costs $1000 for a T1, T4s will probably set you back $2000 for a properly done set by a reputable T4 head guy. Notice I said T4 head guy. _________________ "A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine" |
oprn Samba Member
Joined: November 13, 2016 Posts: 12730 Location: Western Canada
Posted: Sat Jul 14, 2018 8:03 pm Post subject: Re: Build a 2 liter from a VW or start with a T4? |
Check out Brothers, they supplied me with a set of rebuilt type 4 heads for just under 1K with some mild porting and chamber work. They have a good reputation.
I will see this winter how prices compare. I just finished doing up a mild type 4 for our street Buggy and I need to refresh a type 1 engine for our sand rail this winter. It will be a mild build too.
The type 4 cost me in the range of $2500 with a switch to Webers and a home built exhaust system. There are a few items that are more money than the type 1, exhaust is a big one. Heads are a bit more too. |
Rmvr53 Samba Member
Posted: Sat Jul 14, 2018 9:35 pm Post subject: Re: Build a 2 liter from a VW or start with a T4? |
modok - its going to be a race gas engine, but not high octane. I only run 100 (usually AV Gas) in my FV. The biggest drawback I am going to have is what a 2 liter T1 or T4 is going to give me HP wise. At just under 2 liter I am competing with 2 liter Porsche 6 cyl, Lotus Twin-cams , BDA's and the like. So building up the VW engine is more for a "labor of love" (and I know/can afford to work on them)
Bill |
Wreck Samba Member
Posted: Sat Jul 14, 2018 10:35 pm Post subject: Re: Build a 2 liter from a VW or start with a T4? |
A type 1 is easier and most likely work out cheaper , a good exhaust is also another expensive part of a hi performance type4 . plus the cooling system .
If you decide to go down the type4 route, Heads wise I would use AA 2 lt 914 bare castings and get Fat to work them over with good valves etc . A friend did some work on a SuperVee (yellow Zink Z11) not much is known about the engine other then it is 1970cc built by Fat .It pulled 162hp at the wheels with 44 idf's (no fan cooling system) .Ask a few old Supervee racers who was the top engine builder and speak to them about a reliable engine . |
oprn Samba Member
Posted: Sun Jul 15, 2018 5:20 am Post subject: Re: Build a 2 liter from a VW or start with a T4? |
As this is road racing (hours of hard running as opposed to seconds on the drag strip) I will speculate that the type 4 will cost a bit more initially perhaps but will cost less in the long run due to it's superior durability and cooling. |
nextgen Samba Member
Joined: August 19, 2004 Posts: 6028 Location: CONGERS, N.Y.
Posted: Sun Jul 15, 2018 9:45 am Post subject: Re: Build a 2 liter from a VW or start with a T4? |
As mentioned if you are going to have to buy parts for the Type 4 other then just rebuild it, like bearings, and valve job.. THe T-1 will be less if both need the same parts replace, like heads.
Seeing you are talking T-4 2.0 you already will have the 71 mm crank and and rods, close to your wanting 72mm.
I would say as Wreck said, if it is going to be raced, spend the extra money and go T-4 All use a 2.0 case so think 914 and bus the engine was made for racing and lasting. With a T-1 you are making an engine larger then intended, the 2.0 was a stock engine.
Little known fact the 914 2.0 was almost as fast as the 916 6 cyl which was also a 2.0 one year the 916 won 11 out of 12 racers. It is only faster on top end.
For racing drop by the 914 NG. _________________ email: [email protected]
The TYPE IV UPRIGHT CONVERSION MANUAL
BEETLE MAGNETIC DEFLECTOR SHIELDS
LETS TALK DUBS https://www.youtube.com/results?search_query=joe+cali+ghia https://letstalkdubs.libsyn.com/ep-200-joe-cali-ty...qI3xJTCzjs |
modok Samba Member
Posted: Sun Jul 15, 2018 2:04 pm Post subject: Re: Build a 2 liter from a VW or start with a T4? |
Yeah I guess the type-4 has a stronger crank and easier cooling.
But if it's a labor of love....just go with the one you love the most.
You're kind of IN luck, since now you can get 914 re-production heads, and CB panchito heads. Which one has more power potential? I don't know they are both pretty darn nice |
Rmvr53 Samba Member
Posted: Sun Jul 15, 2018 8:11 pm Post subject: Re: Build a 2 liter from a VW or start with a T4? |
"Labor of Love" is kinda pointed at either T1 or T4 (going Volkswagon). If I can get a reliable 130-150 out of the T4 I may go that way as I have a feeling that kind of HP out of a T1 isn't going to be all that reliable. So as said, I'd pay more up front but not have the back-end maintenance/upkeep costs. I already have both a T1 and T4 case sitting on the shelf But they are bare cases. I don't remember what the T4 case is but the T1 is an AH case. Does the T4 need the baffling like we put in the T1 in the Vee? |
modok Samba Member
Posted: Sun Jul 15, 2018 8:37 pm Post subject: Re: Build a 2 liter from a VW or start with a T4? |
Probably similar. Some of the 914 engines had baffles, but if they are good design or not, I don't really know. |
Rome Samba Member
Joined: June 02, 2004 Posts: 9651 Location: Pearl River, NY
Posted: Sun Jul 15, 2018 9:29 pm Post subject: Re: Build a 2 liter from a VW or start with a T4? |
Quote: |
the 914 2.0 was almost as fast as the 916 6 cyl which was also a 2.0 one year the 916 won 11 out of 12 racers |
Careful, Joe. The car you mean is the 914-6, not the 916. Two different models. The 914-6 had the 2-liter 6-cyl. engine from the 911T, rated at approx. 125 hp. The 916 had the powerful Carrera engine, a welded on steel roof, and there were only about a dozen built. All were intended for street use. I knew the owner of one when I worked at VW in Wolfsburg in the early '80's, and he even showed it to me when he drove the car to work one day. Also, Porsche racer Peter Gregg imported one for himself in Florida in the early '70's. The 914-6 GT was yet a third variation of the 914 body, built primarily for racing. |
Wreck Samba Member
Posted: Sun Jul 15, 2018 10:38 pm Post subject: Re: Build a 2 liter from a VW or start with a T4? |
Rmvr53 wrote: |
The 914’s came out with a factory windage tray , they come up regularly on the classifieds or EMW or Fat can probably sorce one , seals for the case to windage tray can still be bought new , a stock well balance crank would be ok to use .
I made drains from the heads to the side of the case to help return the oil to below the tray with simple diy non return valves to stop oil going the wrong way under heavy cornering . |
Steve Arndt Samba Member
Joined: August 01, 2005 Posts: 1780 Location: Boise, Idaho
Posted: Mon Jul 16, 2018 2:23 pm Post subject: Re: Build a 2 liter from a VW or start with a T4? |
nextgen wrote: |
Hey Roland, if someone is going to correct me I am happy to hear from you, Ha.
Been a while!!!
RMV53 All the T-4 cases are the same-- Aluminum not Magnesium and so even if you get a 1.7 engine the case is the same the a 100 -110 hp stock 2.0 uses. |
Some early 1.7 Type 4 cars had mag cases. Very rare. _________________ Steve
Steve's 87 Syncro project |
