PDX_VW_Erik Samba Member
Joined: November 15, 2015 Posts: 199 Location: Oregon
Posted: Sat Jul 14, 2018 6:46 pm Post subject: Rear Wheel Bearings |
I know that there are a bunch of threads about this, but they're all old and I don't want to bump a 5 year old thread, for some reason, people don't like it.
'69 IRS, from what I've read, it's all pretty straight-forward, remove circlips, tap them out, clean every freakin thing, tap new packed bearings back in.
My rear outer bearing, the roller, the center part of the bearing is pretty much free and can come loose. I've seen pictures of this and it seems normal.
My question is this: After I install the newly-packed bearings and seals, I then install the stub axle, what happens to this freely-moving inner race? Do I tap it in after stub axle install? It just seems super weird to me.
Also, any caveats would be welcome, I haven't done rear bearings in ~15 years.
Thanks for your time!
E |
slalombuggy Samba Member
Posted: Sat Jul 14, 2018 8:12 pm Post subject: Re: Rear Wheel Bearings |
The spacer has to go in before the outer bearing. It sits between the inner race of both bearings
brad |
runamoc Samba Member
Joined: June 19, 2006 Posts: 5601 Location: 37.5N 77.1W
Posted: Sun Jul 15, 2018 6:30 am Post subject: Re: Rear Wheel Bearings |
Quote: |
the center part of the bearing is pretty much free and can come loose |
As the stub axle is going in from the back, I slide that race on the axle and push it into the bearing as I push the stub axle in all the way. Keeps the spacer 'pipe' from coming thru the bearing.
_________________ Daily driver: '69 Baja owned 44 yrs - Plan B: '81 Rabbit Diesel LS Deluxe - Plan C: '72 Ghia
Yard Art: 2 Sandrails
Outback: '69 Ghia - '68,'69,'70,'72 Beetle - '84 Scirocco, GTI - Pair of '02 Golfs-
VW Wiring = It's just wires |
