Braukuche Samba Member
Posted: Sun Jul 15, 2018 7:52 am Post subject: Early lowlight exterior mirrors |
I learned recently that my pre Oct '56 did not come with mirrors from the factory, so those ubiquitous swan neck mirrors are not correct for my car.
My car had mirrors mounted on both sides, very near the A pillar and with external sheet metal screws I assume as the holes are very small.
So, you early Ghia guys, what are you using for mirrors on your cars? Pictures would help. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1959 SO-23 Westfalia
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32626 Location: Reading Pennsylvania
Posted: Sun Jul 15, 2018 6:55 pm Post subject: Re: Early lowlight exterior mirrors |
djkeev wrote: |
Do you have photos of what you have? |
No mirrors on it, just these holes on both sides.
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
lonotch Samba Padrino
Joined: August 28, 2004 Posts: 3304 Location: So. Cal. Oceanside GFK!
Posted: Sun Jul 15, 2018 9:13 pm Post subject: Re: Early lowlight exterior mirrors |
If I could do it all over again I wouldave left the outside mirrors off, IMHO it makes the car look cleaner. _________________ It's not about the window, it's about the people.
German Folks |
Posted: Sun Jul 15, 2018 9:17 pm Post subject: Re: Early lowlight exterior mirrors |
lonotch wrote: |
If I could do it all over again I wouldave left the outside mirrors off, IMHO it makes the car look cleaner. |
I've considered that,especially after looking at the less then elegant period choices out there. I wonder if it's legal though to have no exterior mirror? _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
Posted: Sun Jul 15, 2018 10:29 pm Post subject: Re: Early lowlight exterior mirrors |
Braukuche wrote: |
lonotch wrote: |
I've considered that,especially after looking at the less then elegant period choices out there. I wonder if it's legal though to have no exterior mirror? |
By law you need a drivers outside mirror only but I’d take the chance at least until I got a ticket for it.
Just weld and fill up the holes you have on the fenders now, they can always be installed at a later time. _________________ It's not about the window, it's about the people.
German Folks |
c21darrel Samba Member
aerosilver Samba Member
Posted: Mon Jul 16, 2018 1:21 pm Post subject: Re: Early lowlight exterior mirrors |
The mirrors on mine are Lucas mirrors (British made), I've seen them fitted on a lot of early Ghia's.
I guess you need to find a mirror you like,as there was no specific mirror fitted in 56/57,whatever the dealer/customer supplied.
The chances of it lining up with your existing holes, and the mirror being in the right place to see are slim I would say, you may have to repaint that area? |
Posted: Mon Jul 16, 2018 3:12 pm Post subject: Re: Early lowlight exterior mirrors |
aerosilver wrote: |
What you say makes sense. I imagine what you put on there would be whatever was broadly available in your country, so in the U.K. The Lucas mirror makes sense,Germans may have used Talbots, Americans a GM or Ford mirror.
I've got my eye on several at this point none of which are too pleasing to look at, but leaving it naked seems like a bad idea safety wise and not true to this car. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
Posted: Mon Jul 16, 2018 4:45 pm Post subject: Re: Early lowlight exterior mirrors |
Safety wise with the hole locations you have on the passenger side I don’t see that mirror having any use with how low the holes are and the A pillar being in the way. _________________ It's not about the window, it's about the people.
German Folks |
56GoldeGhia Samba Member
Posted: Fri Jul 20, 2018 11:54 pm Post subject: Re: Early lowlight exterior mirrors |
The early Ghia's came without mirrors. A lot of early Ghia's used the Talbot mirrors or the early Porsche 356 mirrors.
I went for the clean look and kept the car as it came from the factory.
udo dreisoerner Samba Member
Joined: February 13, 2005 Posts: 1155 Location: Germany
Posted: Sat Jul 21, 2018 2:27 am Post subject: Re: Early lowlight exterior mirrors |
56GoldeGhia wrote: |
Hi rinie. I wann to sign in you at this list. It is ok for you?
https://www.thesamba.com/vw/forum/viewtopic.php?t=699384&start=80 _________________ Searching for a 1956 lowlight karmann ghia with a VIN number between1273054 and 1273440, and the matching engine with an Engine Number between
1525510 and 1525519 PLEASE OFFER ME ONLY THE CARS THAT I'M LOOKING FOR, THANKS!! |
Posted: Sat Jul 21, 2018 12:21 pm Post subject: Re: Early lowlight exterior mirrors |
I've looked at a lot of current and period photos of early lowlights and have not come across one yet with a Talbot mirror, which I find odd since those were sometimes used on Porsches and were common in European sports cars.
I have seen quite a few with Lucas mirrors, period US car mirrors and many retrofitted with later swan necks.
I do like the no mirror look and might go with that. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
Posted: Sat Jul 21, 2018 1:09 pm Post subject: Re: Early lowlight exterior mirrors |
Looky looky
https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0 _________________ Searching for a 1956 lowlight karmann ghia with a VIN number between1273054 and 1273440, and the matching engine with an Engine Number between
Posted: Sat Jul 21, 2018 2:44 pm Post subject: Re: Early lowlight exterior mirrors |
Hi Udo,
Believe me I spent quite a bit of time looking at that thread. I still did not see one with a Talbot mirror. I've got some laying around and they don't seem to work, as in finding a position where they would be usable. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
Posted: Sat Jul 21, 2018 2:55 pm Post subject: Re: Early lowlight exterior mirrors |
Talbot style mirror, bit further down the wing though..
When one mirror just isn't enough!
Posted: Sat Jul 21, 2018 10:58 pm Post subject: Re: Early lowlight exterior mirrors |
Most of the talbot mirrors i saw was in the middle of tyre as shown by the pics of aerosilver. Some a little bit more to the headlight some a little bit more to the driver. Mount your mirrors there where you can see something in it. Funny are swanneck mirrors at the same position at passanger side. You cant see something in it _________________ Searching for a 1956 lowlight karmann ghia with a VIN number between1273054 and 1273440, and the matching engine with an Engine Number between
Posted: Sun Jul 22, 2018 12:18 am Post subject: Re: Early lowlight exterior mirrors |
Posted: Sun Jul 22, 2018 6:51 am Post subject: Re: Early lowlight exterior mirrors |
Thanks for the Talbot pictures. Confirms my decision not to use them!
I'm still trying to find something that would work with the current holes, but so far no luck. They were obviously attached with external sheet metal screws and would have had to lean back to clears the door when opened, sort of like a swan neck. _________________ Go Reds! Smash state!
Retirement is here!
1956 Ghia
1960 double cab
1960 Baja Bug
1963 356 B coupe
1963 Notchback
