bluebus86 Banned
Posted: Sun Jul 15, 2018 1:39 pm Post subject: Magnets For Oil Sump |
If you source some low profile magnets, the magnets can be stuck on the inside of the sump plate, under the screen. There is space for a lot of magnets. A large area of magnets collects a lot of junk out of the oil verses a small drain plug magnet.
I used magnets about 3/16 inch tall on my sump plate.
I have a filter minisump on one Bug, magnets would not stick the the aluminum sump, so a steel disc was cut from sheet metal to fit in bottom of the minisump, with a hole in middle of disc for the drain plug. Magnets where then stuck to the disc, and disc and magnets fitted under the filter , at bottom of sump.
Make sure the magnets you use can take the heat. Some magnets, including very strong ones, lose their magnetism at typical motor oil temperatures. You can test them in an oven.
The current 356 Registry magazine has an article written in it about making a large area magnetic sump.
My Bug Has a Magnetic Personality, People Wave at My Bug All the Time.
Bug On! _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Danwvw Samba Member
Posted: Sun Jul 15, 2018 2:59 pm Post subject: Re: Magnets For Oil Sump |
Great Idea, The 356's had a huge magnet! Nowadays you can get the Neodymium magnets too. I should put some on my motors! _________________ 1960 Beetle And 1679cc DP W-100 & Dual Zeniths! |
jason_hamilton Samba Member
Joined: February 07, 2003 Posts: 1118 Location: Abbotsford, BC
Posted: Sun Jul 15, 2018 4:51 pm Post subject: Re: Magnets For Oil Sump |
Use a regular hose clamp to attach a cow magnet (Google it) to the pickup tube. A 5/8 x 2-1/2 inch magnet has a surface area over 12 square inches. _________________ Jason Hamilton
1969 Karmann Ghia coupe
@MiddleAgedHoon |
bomberbob Samba Member
Posted: Sun Jul 15, 2018 7:11 pm Post subject: Re: Magnets For Oil Sump |
Got any bad computer hard drives? Take it apart, pull the magnets out. Stick them to the outside of the metal oil cover. It will magnetize that section of the cover, and particles will stick to the inside. Those are not refrigerator magnets, they are strong. _________________ 1968 Beetle (storage)
1990 Jetta GLI megasquirted, burning E85 (currently in heavy maintenance)
2004 Jetta turbo GLI
Marion, Iowa |
goober Samba Member
Posted: Sun Jul 15, 2018 7:39 pm Post subject: Re: Magnets For Oil Sump |
"..... magnets can be stuck on the inside of the sump plate, under the screen."
Have you ever tried putting magnets on the outside of the sump plate around the drain plug and compared the results of inside verses outside magnets? |
Joined: August 31, 2013 Posts: 12856 Location: North Carolina
Posted: Sun Jul 15, 2018 7:43 pm Post subject: Re: Magnets For Oil Sump |
What good are magnets gonna do? Most of the wear surfaces are nonferrous, if you get metal on the magnets the engine is pretty much trashed at that point. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
OLD VW NUT Samba Member
Joined: February 23, 2011 Posts: 2776 Location: High Desert of Washington 98823
Posted: Sun Jul 15, 2018 7:55 pm Post subject: Re: Magnets For Oil Sump |
bomberbob wrote: |
Got any bad computer hard drives? Take it apart, pull the magnets out. Stick them to the outside of the metal oil cover. It will magnetize that section of the cover, and particles will stick to the inside. Those are not refrigerator magnets, they are strong. |
I removed the magnets on an old Seagate Elite 5.25" hard drive. First time I stuck two of them together I nearly got pinched by the two magnets. It took my shop vise and some locking pliers to get them apart. Those things could do bodily harm if you aren't careful with them. Those things are seriously strong! _________________ 71 Ghia Coupe - stock body - no rust! Powered by a 2110 W/Dual HPMX 44's - Rancho Pro Street Transaxle - A/C by Gilmore
Other car - 2013 VW Golf TDI |
73SlowBug Samba Member
Joined: November 28, 2017 Posts: 439 Location: PENNSYLVANIA
Posted: Sun Jul 15, 2018 8:07 pm Post subject: Re: Magnets For Oil Sump |
I use an empi magnetic drain plug. Just a small rare earth magnet. I have no idea if it's worth having a sump magnet at all on our cars.
There is very little ferrous metal in our engines, as someone pointed out. But it was fairly inexpensive, and at the time I had no oil filter, so I figured it was better than just the sump screen. I'm running an oil filter now, but I left the magnetic plug on too. I've yet to see anything on it at all. I guess that's good. The magnet itself is amazingly strong. I think it is Neodymium. Im not sure of more magnets is better here, especially given the brass/aluminum/magnesium components of our engines for outnbering the iron/steel. I guess it's cheap insurance. _________________ Daily driven....Slowly. |
bluebus86 Banned
Posted: Sun Jul 15, 2018 8:49 pm Post subject: Re: Magnets For Oil Sump |
goober wrote: |
The magnetic field is shunted thru a metal plate such that the force of the magnet will be greatly diminished inside if magnets are attached outside of the sump plate.
bluebus86 Banned
Posted: Sun Jul 15, 2018 8:56 pm Post subject: Re: Magnets For Oil Sump |
TDCTDI wrote: |
What good are magnets gonna do? Most of the wear surfaces are nonferrous, if you get metal on the magnets the engine is pretty much trashed at that point. |
The are likely more wear surfaces that are ferrous than not ferrous. The bearings and valve guides are half ferrous, half non ferrous. each of equal area. then we have ferrous to ferrous wear surfaces such as rockers, valve to valve seat, rings to cylinders, etc..
But even if non ferrous wear surfaces made up the majority, so long as there is ferrous wear, the magnet can remove the wear bits from circulation. I have magnets in engines that pick up metal bits and those engines are far from trash. some of these magnets have been in use since engine was new build.
Bug On! Use the force, the magnetic force! _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Mon Jul 16, 2018 1:03 pm Post subject: Re: Magnets For Oil Sump |
Magnets are not a bad idea, but you should look into getting an oil filter/pump like CB Maxi 2 or the VW of Mexico one. With using a quality off the shelf oil filter like WIX makes, you will hardly ever find any metal on the sump plate. The one time we did over 30,000 miles of pulling the sump plate at each 3,000 mile tune up found one flake of metal that had gotten wedged under the sump strainer. _________________ In Stereo, Where Available! |
olspeed Samba Member
Joined: May 01, 2008 Posts: 489 Location: In the shadow of Denali, I still don't give a damn how they do it outside
Posted: Mon Jul 16, 2018 7:41 pm Post subject: Re: Magnets For Oil Sump |
Eric&Barb wrote: |
Magnets are not a bad idea, but you should look into getting an oil filter/pump like CB Maxi 2 or the VW of Mexico one. With using a quality off the shelf oil filter like WIX makes, you will hardly ever find any metal on the sump plate. The one time we did over 30,000 miles of pulling the sump plate at each 3,000 mile tune up found one flake of metal that had gotten wedged under the sump strainer. |
If you found any metal in an engine with a filter you might want to split the filter and squeeze the oil from the media in a vise and then check it for particles as that will be an eye opener for sure. _________________ 66- Ghia
76-Beetle |
Posted: Mon Jul 16, 2018 7:51 pm Post subject: Re: Magnets For Oil Sump |
Eric&Barb wrote: |
The only problem with the vw of Mexico one is that it only fits the 4 bolt cams (without modification). Otherwise, it wuld be nice to have "oem quality" for piece of mind. _________________ Daily driven....Slowly. |
Posted: Mon Jul 16, 2018 7:55 pm Post subject: Re: Magnets For Oil Sump |
73SlowBug wrote: |
The only problem with the vw of Mexico one is that it only fits the 4 bolt cams (without modification). Otherwise, it wuld be nice to have "oem quality" for piece of mind. |
Would not be too hard to modify or have such done, but that is why as stated before to the OP "should look into". _________________ In Stereo, Where Available! |
Posted: Mon Jul 16, 2018 7:58 pm Post subject: Re: Magnets For Oil Sump |
olspeed wrote: |
If you found any metal in an engine with a filter you might want to split the filter and squeeze the oil from the media in a vise and then check it for particles as that will be an eye opener for sure. |
Just going from always having metal on the sump plate to only finding one flake in 30,000 miles was enough of an eye opener.
Replaced rod bearings in a used engine with 20,000 miles since last rebuild from a friend, and installed oil filter/pump. Got about 10,000 miles more before crank broke. Found the now used rod bearings in perfect shape with only slight polish to them in the thrust directions! _________________ In Stereo, Where Available! |
