metropoj Samba Member
Posted: Mon Jul 16, 2018 5:03 am Post subject: Ponderings about the 1.8T HP ratings without the 'T' |
I know it sounds stupid, however ... , bear with me here....
I have a 118HP Inline 4 2.0 8V. It uses one off Motronic (TiiCo) that is not tunable in any way.
Without a spare ECU, you are kind of dead in the water. The idea of plenty of spare AEB parts in the world intrigues me even if the turbo wasn't used.
I am curious if anyone has heard or know of what HP a 20V 1.8T AEB would be without the turbo ? Some have suggested 8V numbers of 90 HP, others are suggesting maybe 115 or so ? I suspect the motor breathes pretty well intake wise and would need to totally remove the turbo to exhale the exhaust well.
I figured a Stage 1 tune may even give a little bit of help compared to a stock AEB but I suspect it plays a lot off the turbo spooling and other things I know little about to truly get the HP gains.
This Inquiry mind wants to know ! _________________ John.
86 TiiCo powered Westy. |
dkoesyncro Samba Member
Posted: Mon Jul 16, 2018 5:18 am Post subject: Re: Ponderings about the 1.8T HP ratings without the 'T' |
The 1.8t management is not much different than the ABA 2.0 another way of saying this is motronic 2.9 vs motronic 5.9 or 7.1.
The 1.8T without the turbo is a slug, yes it breathes well but this advantage only can be seen at higher rpms and this brings the torque and hp higher in the power band. A vanagon is a brick and needs low end torque. An 8 valve will bring torque lower in the rpm faster than the 16v and 20v.
If you want to play around with tuning possibly go stand-alone or I'd imagine the didgifant system used on the g60 corrado would be easily adaptable to a ticco. Then you can run boost.
The N/A 1.8t was used in Europe as a 1.8 20v, I believe engine code ADP or it replaced the ADP, bleep also is something too! |
D Clymer Samba Member
Joined: December 22, 2005 Posts: 2978 Location: Issaquah, WA
Posted: Mon Jul 16, 2018 6:12 am Post subject: Re: Ponderings about the 1.8T HP ratings without the 'T' |
If you want to go the AEB route, it would make more sense to use the engine complete, with the turbo in place. It's a pretty simple engine, and it would take more effort to eliminate the turbo than to figure out a basic intercooler setup (the hardest part of an AEB conversion).
As dkoessyncro stated above, Audi did use a 1.8 20V in the A3 and A4 in Europe, and it wasn't a very impressive engine. It had 125hp at 6000 rpms, and 128 lb/ft of torque at 4100. Those figures sound better than they are because those numbers are reached at a very high rpm. Also, an AEB sans turbo wouldn't even reach those numbers because it has a static compression ratio of 9.5:1 vs 10.3:1 for the euro non turbo engine. |
Posted: Mon Jul 16, 2018 10:28 am Post subject: Re: Ponderings about the 1.8T HP ratings without the 'T' |
D Clymer wrote: |
Well put, often my words don't come out as my thoughts! The engine code I believe was bleep on the B5 platform. |
Posted: Tue Jul 17, 2018 4:47 am Post subject: Re: Ponderings about the 1.8T HP ratings without the 'T' |
Interesting stuff.
I figured the HP was probably at high RPM and similar to why not many pursue the 16V motor in a Vanagon, no low end grunt. Wow, 6k ! Geez.
For comparison, the TiiCo motor at 2.0L does :
1. 118HP at 4800 RPM
2. 132 ft/lb at 3500 RPM
10:1 CR _________________ John.
Vanagon Nut Samba Member
Posted: Tue Jul 17, 2018 10:48 am Post subject: Re: Ponderings about the 1.8T HP ratings without the 'T' |
Do all Tiico blocks have piston skirt oil squirters? If you want to build a higher HP/torque engine, what about the Audi bubble block as a start point? I've read that all those blocks c/w squirters. (but that block may be hard to find in some areas?)
1988 West DIY 50º ABA
VE7TBN |
