Sodo Samba Member
Joined: July 06, 2007 Posts: 9603 Location: Western WA
Posted: Mon Jul 16, 2018 10:44 am Post subject: Replaced Air conditioning condenser with GoWesty |
Replaced air conditioner condenser. I did not disturb any radiator water/coolant connections, just had to cut some zipties to drop the radiator+fan+condenser assembly down a few inches (on its long rubber hoses).
If anyone nearby (Seattle) can help me pump it down (vacuum) that would be GREAT!! I'd really like to get some refrigerant in ASAP and see if it holds.
The entire radiator+fan+condenser is supported by FOUR m8 bolts, on slotted holes. Adapting the GoWesty condenser was fairly straightforward using their directions. Here's some pics that might help.
I did this work with the van at 28" high on wheel ramps. A 32" stick supports the radiator "in place" to remove the bolts. I removed the two radiator supports then lowered the radiator+fan assembly down to sit on the orange ratchet strap. It wasn't too difficult.
Here's pics showing the helper stick holding the weight of the radiator + fan + condenser so you can unscrew or insert the four bolts. My concrete was rough surface that held the stick in place. You may want another length helper stick, but i used just the 32".
Note GoWesty condenser is 1/2 the size of the OEM unit. "They say" it works well, I hope so!
This pic shows the orange ratchet strap that I will drop the radiator+fan+condenser assembly onto. Note at the left side the aluminum tubing will bend under the weight of the assembly sitting on the orange strap. Add a block in there, or perhaps disconnect the pipe first. I had to 'reshape' the pipe little (by hand) to fit to the GoWesty extension hose (to the upper left corner fitting of the condenser)
If you just LOOSEN all four M8 bolts below (13mm head) the entire radiator+fan+condenser will drop down about 1/2 inch in the slotted holes, providing access to these two screws that attach the condenser to the top of the radiator. Don't lose these conical rubber grommets. There's one at each corner of the radiator.
Hope this helps. Sorry it's not a COMPLETE instructional, butyou can see it's not a HUGE project to change the condenser.
Note: Changing the condenser entails opening the system to the atmosphere. This is a bad deal if your van currently has FREON in it, FREON damages your environment and everyone elses too. And not a great thing to do if it has R134 in it. You need to have the refrigerant reclaimed by an air conditioning repair company, before unscrewing ANY fittings. My system has been empty for many years so i did not have to do that.
If anyone nearby (Seattle) can help me pump it down (vacuum) that would be GREAT!! If it holds a vacuum I'll squirt some RedTek in ASAP. _________________
....KTMs, GasGas, SPOT mtb
Paulbeard Samba Member
Posted: Mon Jul 16, 2018 10:46 am Post subject: Re: Replaced Air conditioning condenser with GoWesty |
Sodo wrote: |
My FLAPS lists a vacuum test kit as part of their loaner tools…maybe if that's the case down there? Is that what you need? _________________ Currently -> Frida: 87 Tizian Red (mostly) Vanagon GL Westfalia w/ 2.0L ABA conversion
Formerly -> Steward of a 73 Super Beetle (Beater) and 67 Beetle 1300 (Little Max) both names by POs
— dhaavers |
Sodo Samba Member
Posted: Mon Jul 16, 2018 10:58 am Post subject: Re: Replaced Air conditioning condenser with GoWesty |
Paulbeard wrote: |
My FLAPS lists a vacuum test kit as part of their loaner tools…maybe if that's the case down there? Is that what you need? |
Yes that's it but I called Autozone and the rental cost was $170.... Can buy a pump at HarborFreight for $164. But didn't really want to stock another "seldom" or "ideally seldom" tool. If it was $50 I'd do it, but since this round is first testing if it will even hold a vacuum, I'm hoping to find a Vanagon bro deal...
Another option is to pressurize it, and if it holds pressure that's a good sign. But I moved and can't find my fittings, if anyone nearby has an old refrigerant add kit that I can scavenge fittings from.... send a PM. _________________
....KTMs, GasGas, SPOT mtb |
Butcher Samba Member
Joined: December 05, 2015 Posts: 1285 Location: Right Here
Posted: Mon Jul 16, 2018 11:06 am Post subject: Re: Replaced Air conditioning condenser with GoWesty |
I bet if you inquired about the cost of the vacuum pump rental, you may find that you get most of that $170 back when you return it. I'm almost willing to say you will get all of it back.
Make another call. |
shagginwagon83 Samba Member
Joined: February 07, 2016 Posts: 3795 Location: VA/TN
Posted: Mon Jul 16, 2018 11:09 am Post subject: Re: Replaced Air conditioning condenser with GoWesty |
Yeah today I rented a flange puller from advance auto parts and get 100% of my money back. _________________ Brandon
Instagram @joannthevan |
mikemtnbike Samba Member
Joined: March 26, 2015 Posts: 2795 Location: North Carolina
Posted: Mon Jul 16, 2018 11:12 am Post subject: Re: Replaced Air conditioning condenser with GoWesty |
That's definitely how tool "rental" cost works at both the FLAPS I use (Oreilly and Napa). You "rent it" for the full retail cost of the tool and then get it all back when you return it. You know, what a lot of people would do anyway for one-time use tools...I think it's a brilliant way to prevent use-and-returns. _________________ 1991 Vanagon GL 2.1 AT Westfauxlia. "Frankie" Totaled https://www.thesamba.com/vw/forum/viewtopic.php?t=764510&highlight=carnage
2020 GTI SE manual |
fxr Samba Member
Joined: December 07, 2014 Posts: 2321 Location: Bay area CA
Posted: Mon Jul 16, 2018 11:21 am Post subject: Re: Replaced Air conditioning condenser with GoWesty |
Sodo wrote: |
The entire radiator+fan+condenser is supported by FOUR m8 bolts, on slotted holes. Adapting the GoWesty condenser was fairly straightforward using their directions. Here's some pics that might help. |
That's certainly different to my '84. The new condenser attaches to the van frame with the brackets supplied, not to the radiator, which can be removed separately. _________________ Jim Crowther
Vespa GTS 300 |
Sodo Samba Member
Posted: Mon Jul 16, 2018 11:29 am Post subject: Re: Replaced Air conditioning condenser with GoWesty |
Butcher wrote: |
I WILL DO THAT! Thanks! _________________
SSWesty Samba Member
Joined: August 20, 2008 Posts: 732 Location: Bellevue
Zeitgeist 13 Samba Member
Posted: Mon Jul 16, 2018 4:11 pm Post subject: Re: Replaced Air conditioning condenser with GoWesty |
You should also replace the drier while the system is open _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
Sodo Samba Member
Posted: Mon Jul 16, 2018 4:19 pm Post subject: Re: Replaced Air conditioning condenser with GoWesty |
Zeitgeist 13 wrote: |
You should also replace the drier while the system is open |
I was told I won't need a drier if I hold the vacuum 24 hours.
Is this your understanding?
Also was told that hot summer day is the best time to evacuate and 'dry' the system.
A beautiful thing... Thanks for telling me about the loaner program, it absolutely rules. And I can keep it for 90 days.
It went to minus 1. I backed off the plungers and it's holding 'minus 1' for 1 hr so far. _________________
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32584 Location: Reading Pennsylvania
Joined: January 01, 2007 Posts: 16863 Location: sticksville, ct.
Posted: Mon Jul 16, 2018 5:56 pm Post subject: Re: Replaced Air conditioning condenser with GoWesty |
Sodo wrote: |
I was told I won't need a drier if I hold the vacuum 24 hours.. |
you were told wrong. any time the a/c is open to atmosphere for more than 20 minutes or so the desiccant can absorb (and saturate) too much moisture.
at the minimum I would pull a vacuum for a minimum of a couple hours. water boils under a good deep vacuum. otherwise, you run the risk of "black death" when water, refrigerant and oil mix up _________________
gprudenciop wrote: |
Jake Raby wrote: |
Brian wrote: |
Sodo Samba Member
Posted: Mon Jul 16, 2018 7:44 pm Post subject: Re: Replaced Air conditioning condenser with GoWesty |
djkeev wrote: |
Absolute Vacuum varies based upon elevation. |
I'm at 130 feet elevation.
skills@eurocarsplus wrote: |
Sodo wrote: |
at the minimum I would pull a vacuum for a minimum of a couple hours. water boils under a good deep vacuum. otherwise, you run the risk of "black death" when water, refrigerant and oil mix up |
I was going to hold vacuum for 24 hours. But are you saying the desiccant in the drier won't 'dry under a vacuum'? _________________
baltik Samba Member
Posted: Mon Jul 16, 2018 7:57 pm Post subject: Re: Replaced Air conditioning condenser with GoWesty |
Dumb question - does cleaning solvent/PAG oil contaminate the dryer? or is the disecant isolated? |
Abscate Samba Member
Joined: October 05, 2014 Posts: 22641 Location: NYC/Upstate/ROW
Posted: Tue Jul 17, 2018 4:21 am Post subject: Re: Replaced Air conditioning condenser with GoWesty |
The desiccant will get soaked in PAG oil but that won’t affect its ability to pick up moisture
If you haven’t detonated parts into your AC and held pressure you can forego changing the drier. Pumping on it for a couple hours will purge the desiccant of water. I run six cars now, newest is a 2012,next is a 2006, all but one on original driers with good working AC and original compressors.
You do lose your warranty if you don’t replace the drier but unless you are in the trade they won’t honor it anyway. Read the fine print. _________________ .ssS! |
Posted: Tue Jul 17, 2018 4:50 am Post subject: Re: Replaced Air conditioning condenser with GoWesty |
The boiling action stops when you stop pulling a vaccum. _________________
Jake Raby wrote: |
Brian wrote: |
Posted: Tue Jul 17, 2018 5:55 am Post subject: Re: Replaced Air conditioning condenser with GoWesty |
If you have 24 hours just leave the pump running. You should have new oil in it, too if you are a DIY type. If you are an AC tech, you keep track of hours on the oil, but we don't, so I just replace each year on AC season when I have jobs coming up. It is cheap. _________________ .ssS! |
t3 kopf Samba Member
Joined: October 22, 2012 Posts: 1115 Location: over by 'der
Posted: Tue Jul 17, 2018 6:06 am Post subject: Re: Replaced Air conditioning condenser with GoWesty |
You do need to replace the drier if you had it open long enough to replace the condenser. If you're putting R-134 in a system that wasn't already correctly converted, you also need to replace all the O-rings in the system because the O-rings for R-12 are not compatible with R-134. I'm running that Gowesty condenser as well. Its just a marked up version of a universal condenser. It gets the job done well enough. I have cold AC in my van running off my Subaru compressor and R-134. _________________ '90 Carat w/ '95 phase 1 EJ22 OBD2 conversion |
vanagonjon Samba Member
Posted: Tue Jul 17, 2018 9:15 am Post subject: Re: Replaced Air conditioning condenser with GoWesty |
The refrigerant desiccant in a drier holds moisture by a chemical reaction. You cannot remove it by using a vacuum pump. It is like trying to un-bake a cake.
The vacuum pump is used to remove any free moisture in the system. Then the desiccant in the system is to capture any moisture missed by the vacuum pump and any moisture that happens to enter the sealed system after servicing. |
