MarkWard Samba Member
Joined: February 09, 2005 Posts: 17155 Location: Retired South Florida
Posted: Tue Jul 17, 2018 4:48 am Post subject: Syncro front shock access hole? |
Hello, I'm in the process of converting a 2wd vanagon to 4wd. To unbolt the front shocks on the 2wd camper, you remove the nut on the top of the shock from the van by working through the fender well.
The syncro tintop had some handy access hole under the seats. I'm trying to figure out if these are necessary. The camper has seat swivels so the access from inside is limited compared to the tintop where you can slide the seat forward to access the shock. I can't see where these holes are necessary, but thought I'd run it by the members. Is there a situation where you can't remove the front shock working through the fenderwell on a syncro? All other suspension is stock. Thanks _________________ ☮️ |
davevickery Samba Member
Joined: July 16, 2005 Posts: 2887 Location: Fort Collins, CO
Posted: Tue Jul 17, 2018 6:10 am Post subject: Re: Syncro front shock access hole? |
I don’t think you need them. People doing struts sometimes use a tool or piece of pipe to help line up the end of the shock because with tension on it, it sometimes doesn’t want to go in. I just use a ratchet strap to pull the strut in whatever direction I need. |
Pcforno Samba Member
Joined: October 14, 2014 Posts: 575 Location: Santa Fe, nm
Posted: Tue Jul 17, 2018 6:15 am Post subject: Re: Syncro front shock access hole? |
If the suspension is stock, it’s dead easy to align it, hole or not |
Posted: Tue Jul 17, 2018 8:51 am Post subject: Re: Syncro front shock access hole? |
Thank you. Do both the tin top and camper Syncro's have this access? I wonder if it was required on the assembly line. Sure would be nice to know the engineer' thinking. _________________ ☮️ |
Posted: Tue Jul 17, 2018 9:02 am Post subject: Re: Syncro front shock access hole? |
Yes the camper has it too. You can still get to it if you remove the central portion of the swivel seats, but in my experience it’s not necessary to use the hole. |
shagginwagon83 Samba Member
Joined: February 07, 2016 Posts: 3804 Location: VA/TN
Posted: Tue Jul 17, 2018 10:07 am Post subject: Re: Syncro front shock access hole? |
On my 2wd I did not go through seat. I had to use a wrench to access the top shock bolt. I could not get a socket on it so I could not torque it down to specs but IIRC it was like 20ftlb torque _________________ Brandon
Instagram @joannthevan |
tencentlife Samba Member
Posted: Tue Jul 17, 2018 10:17 am Post subject: Re: Syncro front shock access hole? |
If you start adding lift the ability to use a tool thru that hole to grab the shock spindle and guide and pull it up thru the hole becomes more and more desirable, because even with that method it's an un-fun procedure to do alone. It's easy to make the tool of some thick-walled tubing, run an M10 x 1.0 tap into one end, make it about 8-10" long, drill across the opposite end to put a pin thru and make a T-handle. Use it like it shows in the book. _________________ Shop for unique Vanagon accessories at the Vanistan shop:
Zeitgeist 13 Samba Member
Posted: Tue Jul 17, 2018 10:47 am Post subject: Re: Syncro front shock access hole? |
I found the hole indispensable when guiding the top of the shock into place. If you have the grommets and an appropriate size hole saw, then I don't see a downside in going that route. _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
Posted: Tue Jul 17, 2018 10:52 am Post subject: Re: Syncro front shock access hole? |
My grommets were old and stiff and wouldn't stay in so I just tape over the holes. _________________ Shop for unique Vanagon accessories at the Vanistan shop:
MsTaboo Samba Member
Joined: June 02, 2006 Posts: 4098 Location: East Kootenay, British Columbia
Posted: Tue Jul 17, 2018 11:18 am Post subject: Re: Syncro front shock access hole? |
I've done it both ways and found using the hole with a tube much easier.
In my case it's just an aluminum tube I used to align the shock rod through the hole in the shock tower.
Here are some pics for those who may not know what we're talking about.
_________________ Currently:
Posted: Wed Jul 18, 2018 10:02 am Post subject: Re: Syncro front shock access hole? |
Well, I did what I should have done before posting. I looked in the manual to see the reference made. The tool being described above is VW 3141. I think where it would be necessary would be with non gas charged shocks. On a conventional hydraulic shock, the shaft might have a tendency to sink into the shock and the design would be such that getting the shaft to full extension and through the upper shock mount would be difficult. The 2 wd spring seats on the control arm, not the shock, so it might be easier to deal with.
The other tool shown is a VW 3017A, which accounts for why the hole is so large. VW intended on the syncro to use this tool in conjunction with an allen wrench to hold the shock shaft from spinning while you undid the upper shock retaining nut with 3017A. I have not seen vanagon shocks that have an allen hole machined into the end of the shock shaft for some time. The ones I have come across have 2 wrench flats that a 6mm open end wrench would grip.
So, installing the holes are probably the way to go, but without the tools and the handy allen ended shock shaft, probably not going to get used installing my gas shocks.
Its too bad, VW did not do more of a macpherson strut type of setup on the syncro, where you could remove the shock assembly complete. Lots of other vehicles running around with that setup. Probably because they were using the 2wd upper shock mount. _________________ ☮️ |
Posted: Wed Jul 18, 2018 12:45 pm Post subject: Re: Syncro front shock access hole? |
Gas-charged shocks don't push back that hard, they compress easily during this job. Having the tool to grab the rod and guide it up is a big help. Never saw a need for the 2nd tool, it takes little torque to deal with the top nut and the flats on the rod end are more than sufficient, I'd rather have the flats than an in-hex there.
MarkWard wrote: |
Its too bad, VW did not do more of a macpherson strut type of setup on the syncro, where you could remove the shock assembly complete. Lots of other vehicles running around with that setup. Probably because they were using the 2wd upper shock mount. |
I've thought the same, what they built is essentially a piecemeal MacPherson strut anyway. I think it was a corporate cultural thing. Remember who built the Syncro suspension? Not VW, it was an old-school niche company with no mass-market passenger car experience. By the mid-70's the majors adopted McPh struts for one reason: it wasn't a better suspension, but it saved a lot of assembly labor. Meanwhile Steyr-Puch did low-volume specialty work and that probably wasn't in their mindset. They could have easily made a strut top adapter that fit the existing upper spring seat, or asked VW to change that component on vans destined for Graz. VW could have shared their extensive experience with struts, too, although it was all with much lighter vehicles, but most engineered things are scalable. I suppose the anticipated volume was so small and the price target so high it probably didn't matter to them, or else it just never came up in a planning meeting.
There's a supposition you see stated often when people talk about engineering, the notion that every design decision was made for a reason, and if there was a better way to do something it would have been done that way. Neither of those ideas can withstand logical scrutiny. The first is nominally true, decisions are invariably made for some reason, but it doesn't mean it's a good one. The second assumes that engineering departments are all-knowing with unlimited imagination, which is absurd. _________________ Shop for unique Vanagon accessories at the Vanistan shop:
Steve Arndt Samba Member
Joined: August 01, 2005 Posts: 1780 Location: Boise, Idaho
Posted: Wed Jul 18, 2018 1:17 pm Post subject: Re: Syncro front shock access hole? |
I've always been intrigued by that strap _________________ Brandon
SyncroHead Samba Member
Joined: May 23, 2005 Posts: 1145 Location: Northern Nevada
Posted: Wed Jul 18, 2018 4:04 pm Post subject: Re: Syncro front shock access hole? |
MarkWard wrote: |
... I think where it would be necessary would be with non gas charged shocks. On a conventional hydraulic shock, the shaft might have a tendency to sink into the shock and the design would be such that getting the shaft to full extension and through the upper shock mount would be difficult... |
This is exactly the case. I actually have this tool and used it years ago upon replacing my Syncro's original shocks with OEM type non-gas-charged ones. You reach through he hole in the seat base with the tool and thread it on the end of the shock "rod", then you PULL the shock "rod" up through the hole.
With gas-charged shocks, you do not need to pull it up, since it's under pressure. Getting it aligned is the trick through. Also, FWIW, the latest sets of shocks I'd installed didn't even use the same thread size so I couldn't use the "pulling tool" if I needed to.
Jim _________________ "A Vanagon? It's not a car or a van. It's a hobby!"
Check out:
www.VANAVATION.com
www.SyncroSafari.org and
www.Vanagons.org
sphet wrote: |
I have *no* idea what the previous owner carried in his Westy... angry donkeys? |
Posted: Sat Jul 21, 2018 7:24 am Post subject: Re: Syncro front shock access hole? |
“There's a supposition you see stated often when people talk about engineering, the notion that every design decision was made for a reason, and if there was a better way to do something it would have been done that way. Neither of those ideas can withstand logical scrutiny. The first is nominally true, decisions are invariably made for some reason, but it doesn't mean it's a good one. The second assumes that engineering departments are all-knowing with unlimited imagination, which is absurd.[/quote]
Well said tencent!!
That should be a sticky!
I am so sick of the “appeal to authority” fallacious arguments I hear around here as if engineers are some omnipotent beings who have procured our vans from the nether regions of the cosmos and represent perfection of the natural world
Before I became a doctor I worked in evolutionary biology and there was a fallacious idea shared by many laymen that everything in evolution and nature was there for a reason - some sort of adaptive perfection. It couldn’t be further from the case. Just like in engineering there exists a long history of accumulated errors, junk, historical constraints, maladaptive peaks, evolutionary dead ends, junk DNA, and parts leftover from millennial ago that serve no purpose whatsoever, or have had no selection pressure to eliminate them. No different in any human-based process
levi Samba Member
Joined: February 11, 2005 Posts: 5522 Location: Las Vegas
Posted: Sat Jul 21, 2018 7:56 am Post subject: Re: Syncro front shock access hole? |
This comparitive analogy of biological evolution and vanagon creation gives my van a more humanistic feel.
I think I'll be more compassionate now about it's next breakdown. _________________ One of these days I'm gonna settle down,
but till I do I won't be hangin round.
Going down that long lonesome highway,
gonna see life my way
https://youtu.be/cSrL0BXsO40 |
Posted: Sat Jul 21, 2018 8:50 am Post subject: Re: Syncro front shock access hole? |
Have we established whether these all knowing German enginerds designed air to flow up or downward through this access hole? _________________ Casey--
y u rune klassik? |
Posted: Sat Jul 21, 2018 9:31 am Post subject: Re: Syncro front shock access hole? |
Pcforno wrote: |
Well said tencent!!
Before I became a doctor I worked in evolutionary biology and there was a fallacious idea shared by many laymen that everything in evolution and nature was there for a reason - some sort of adaptive perfection. It couldn’t be further from the case. Just like in engineering there exists a long history of accumulated errors, junk, historical constraints, maladaptive peaks, evolutionary dead ends, junk DNA, and parts leftover from millennial ago that serve no purpose whatsoever, or have had no selection pressure to eliminate them. No different in any human-based process |
Thanks PC. I've said more than once you'll learn a lot more about logical fallacies here than you will about cars, and that the car you're driving is a more faithful expression of the corporate culture that produced it, with all its history, than an expression of good and current design sense. _________________ Shop for unique Vanagon accessories at the Vanistan shop:
Posted: Sat Jul 21, 2018 12:41 pm Post subject: Re: Syncro front shock access hole? |
shagginwagon83 wrote: |
I've always been intrigued by that strap |
The strap is just to limit the droop and save the shock from over-extension from the weight of big tires, etc.
Not needed with stock Syncro setup. _________________ Currently:
