VWTortuga336 Samba Member
Posted: Tue Jul 17, 2018 7:44 am Post subject: Close Deck Lid With Turbo |
I'm picking up a 1776 turbo'ed engine for my 72 convertible this weekend. I've seen several pics of turbos in Ghias, but can't tell if it's possible to fit it all under the deck lid.
Any one have any pics? _________________ Stop dead photo links! Post your photos to The Samba Gallery! |
KGCoupe Samba Member
Joined: July 01, 2005 Posts: 3580 Location: Putting the "ill" and "annoy" in Illinois
Posted: Tue Jul 17, 2018 9:33 am Post subject: Re: Close Deck Lid With Turbo |
If you go to the Gallery tab here on The Samba and search the Ghia Coupe category for "turbo", this is the list of results that will be returned.
If none of those pics help answer your questions, then perhaps you can try performing the same search in the Ghia - Cabriolet gallery category. |
Joined: August 31, 2013 Posts: 12856 Location: North Carolina
Posted: Tue Jul 17, 2018 10:16 am Post subject: Re: Close Deck Lid With Turbo |
A turbo in the engine compartment is a great idea, you can use all of the incoming air to keep the turbo from getting too hot. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
c21darrel Samba Member
Starbucket Samba Member
Posted: Tue Jul 17, 2018 3:33 pm Post subject: Re: Close Deck Lid With Turbo |
You better put an electric radiator fan assy. under the deck lid to force a lot of cool air in there as that Turbo will heat the cooling air to the motor and really cook the motor and kill it quick. The exhaust housing on the turbo runs at 1200 deg.s F. |
Onceler Samba Member
Posted: Tue Jul 17, 2018 5:47 pm Post subject: Re: Close Deck Lid With Turbo |
If heat becomes an issue, just drill some 1 1/2” holes in the front sheetmetal that fits over the flywheel area, btdt with a bug. Cool air is forced in from under the car and out the decklid vents, unless ur idling, but ur not on boost idling _________________ 1972 Karmann Ghia |
