mccann1984 Samba Member
Joined: September 18, 2012 Posts: 63 Location: Prince Edward island
Posted: Tue Jul 17, 2018 11:43 am Post subject: window wipers won't turn off! |
Hey All,
My wipers weren't working at all and I noticed the fuse was blown. I replaced that and now the wipers are on all the time - I can't get them to turn off. Any ideas? It all seems to be grounded ok as far as I can see.....
Andy |
Angus II Samba Member
Joined: June 01, 2016 Posts: 708 Location: Mammoth Lakes Ca. 93546
Posted: Tue Jul 17, 2018 12:06 pm Post subject: Re: window wipers won't turn off! |
Hello,
Pull the fuse back out....
Then check the switch with an ohm meter. It's most likely the problem. |
Posted: Tue Jul 17, 2018 12:59 pm Post subject: Re: window wipers won't turn off! |
I'm not much of a mechanic - how would I go about checking the switch!? |
Malokin Martin Samba Member
Posted: Tue Jul 17, 2018 1:16 pm Post subject: Re: window wipers won't turn off! |
Relay box rusted/wet/corroded? It’s right under where water leaks in when it rusts-out on the windshield |
Posted: Tue Jul 17, 2018 1:30 pm Post subject: Re: window wipers won't turn off! |
By switch do you mean relay box? The fuse/relay box all looks good - I had it off today and it's not wet or rusted etc. |
Posted: Tue Jul 17, 2018 6:08 pm Post subject: Re: window wipers won't turn off! |
Hello,
I may be mistaken, but there is no relay for the wiper motor and/or switch....
Get your wiring diagram out for the year bus you have and see..
Is it stuck in low or high speed? You are getting power to the switch with the fuse in so unless one of the wires are touching the power in wire#30 the problem is in the switch... Take the switch out of the dash with wires in place, us a jumper wire to ground switch body and check it. Will it turn off and on now?, with the fuse in. |
Manfred58sc Samba Member
Posted: Tue Jul 17, 2018 8:05 pm Post subject: Re: window wipers won't turn off! |
When Bay wipers switches get old sometimes you have to push the knob in ( towards the dash) while turning it off . Mine has been that way for oh...24 years now. _________________ Fat chick owner/operator |
