1977 Beetle is lower on one side than the other.
Page: 1, 2, 3  Next
bmlb929
bmlb929 is offline
PostPosted: Tue Jul 17, 2018 5:20 pm    Post subject: 1977 Beetle is lower on one side than the other. Reply with quote
Amateur mechanic. Learning as I go. My driver's side is lower than my passenger side even when I am not in it. Have changed the shocks and that did not help. When I jack the car up, the driver's side comes of the floor after the passenger side does. Can somebody tell me where to start? Limited budget so I have to do most labor myself. Thanks
joey1320
joey1320 is offline
PostPosted: Tue Jul 17, 2018 6:17 pm    Post subject: Re: !977 Beetle is lower on one side than the other. Reply with quote
Absolutely nothing wrong with doing things yourself.
You gotta be proud of that.
It's difficult to say without seeing the vehicle in person, so can you post pics of the issue? Can you also post pics of the underside of the car and the suspension?
**1971 Super Project
bmlb929
bmlb929 is offline
PostPosted: Tue Jul 17, 2018 6:29 pm    Post subject: Re: !977 Beetle is lower on one side than the other. Reply with quote
Will do. Might be a day or two. Thanks
cletus_zuber
cletus_zuber is offline
PostPosted: Tue Jul 17, 2018 6:34 pm    Post subject: Re: !977 Beetle is lower on one side than the other. Reply with quote
Front or rear? were 77's standard still sold in the US, I forget.
if standard and in front I would suspect broken torsion leaves inside the beam.
Kadrons & 019
Q-Dog
Q-Dog is offline
PostPosted: Tue Jul 17, 2018 7:43 pm    Post subject: Re: !977 Beetle is lower on one side than the other. Reply with quote
Beetles are heavier in the rear than in the front, so when a car leans to one side that issue can often be narrowed down to a problem in the rear of the car.
Brian
'69 Dune Buggy
'69 Beetle Convertible
'70 Beetle
bmlb929
bmlb929 is offline
PostPosted: Tue Jul 17, 2018 8:45 pm    Post subject: Re: !977 Beetle is lower on one side than the other. Reply with quote
It's the front. Driver's side. Will post pics as soon as possible. I really hope it's not the torsion bars. That maybe over my head.
bmlb929
bmlb929 is offline
PostPosted: Sun Jul 22, 2018 4:02 pm    Post subject: Re: !977 Beetle is lower on one side than the other. Reply with quote
Here are the pics. Let me know of any other angle that would help.
andk5591 Premium Member
andk5591 is offline
PostPosted: Mon Jul 23, 2018 7:58 am    Post subject: Re: !977 Beetle is lower on one side than the other. Reply with quote
couple things - Try jacking the front of the car under the center of the beam and see how the rear looks. Will help you identify which end of the car has the problem.
You have really ratty ball joint boots that need to be replaced, assuming your ball joints are any good. If you replace those, you can pull the control arms and spring packs to look for any damage and can replace them if needed.
Something else - when you push down on the front, do both sides go down about the same? Couple possibly be a bound up ball joint, but kind of doubt it.
D-Dubya Manx clone - 63 Short pan,1914.
There's more, but not keeping them...
Chad1376
Chad1376 is offline
PostPosted: Mon Jul 23, 2018 8:45 am    Post subject: Re: !977 Beetle is lower on one side than the other. Reply with quote
One more thing to check - is the frame head twisted. A quick check is to look down the bottom center of the car from the rear, and see if the front beams appear parallel with the pan.
My never ending 1302 Autocross Project:
http://www.shoptalkforums.com/viewtopic.php?f=51&a...02b8f83f22
GArBa
GArBa is offline
PostPosted: Mon Jul 23, 2018 9:18 am    Post subject: Re: !977 Beetle is lower on one side than the other. Reply with quote
someone removed the anti-roll bar leaving its bushings in place, this makes me believe the beam has been tampered with.
cars:
'97 type 1 1600i
'14 type AA Seat Mii
moped:
'82 Benelli Magnum 3v
bmlb929
bmlb929 is offline
PostPosted: Mon Jul 23, 2018 10:22 am    Post subject: Re: 1977 Beetle is lower on one side than the other. Reply with quote
Thanks everyone. Guess I got my work cut out for me.
SdAufKla
SdAufKla is offline
PostPosted: Mon Jul 23, 2018 10:59 am    Post subject: Re: 1977 Beetle is lower on one side than the other. Reply with quote
What is the "U-shaped" bar / rod piece under the bottom end of the shock mount?
(See the 2nd photo, down.)
There is no comparable part under the bottom of the other - driver's side - shock mount (see the 3rd photo).
Maybe the problem is not that the driver's side is sagging, but that the passenger side is being held upwards by something.
bmlb929
bmlb929 is offline
PostPosted: Mon Jul 23, 2018 11:36 am    Post subject: Re: 1977 Beetle is lower on one side than the other. Reply with quote
Good point. I did not see that. Will check today
ashman40
ashman40 is offline
PostPosted: Mon Jul 23, 2018 2:18 pm    Post subject: Re: 1977 Beetle is lower on one side than the other. Reply with quote
Two comments on your issue....
    The sway bar (yours is missing) provides some level of balance between the two sides. If one side is more compressed than the other, the sway bar tries to force the other side down by the same amount. Lacking this, your front end can appear uneven. This is probably NOT the primary cause but may be exaggerating it.
    After 40+ years... springs sag. When driven, the car will ALWAYS have a driver adding weight to the left (driver's) side, but may not always have a passenger. This leads to the driver side springs wearing out (sagging) earlier than the passenger side. This is a common problem with classic cars.
    This applies to the front springs and the rear. The rear torsion springs are adjustable by rotating the torsion bar on either the inner and/or outer teeth and you can often get the ride height in the rear corrected. For the front... you probably need to buy a new set of torsion leaf packs (top & bottom).
That looks sort of like a tow loop?? Maybe something a PO welded in place?
My RHD Beetle had a similar loop but it was welded to the bottom of the lower tube and extended forward horizontally.
AshMan40
allenw
allenw is offline
PostPosted: Mon Jul 23, 2018 4:07 pm    Post subject: Re: 1977 Beetle is lower on one side than the other. Reply with quote
The bumper looks higher on the passenger side than the driver side
Chris333
Chris333 is offline
PostPosted: Mon Jul 23, 2018 4:35 pm    Post subject: Re: 1977 Beetle is lower on one side than the other. Reply with quote
Are the shocks different?
bmlb929
bmlb929 is offline
PostPosted: Mon Jul 23, 2018 5:18 pm    Post subject: Re: 1977 Beetle is lower on one side than the other. Reply with quote
Front shock are the same. Just replaced.
Chris333
Chris333 is offline
PostPosted: Mon Jul 23, 2018 5:23 pm    Post subject: Re: 1977 Beetle is lower on one side than the other. Reply with quote
You could need new torsion bars. Maybe the driver side is sagging after so many years with only a driver.
sleeper bird
sleeper bird is offline
PostPosted: Mon Jul 23, 2018 5:26 pm    Post subject: Re: 1977 Beetle is lower on one side than the other. Reply with quote
although the front is not even the bumper makes it look worst,its cocked down
bmlb929
bmlb929 is offline
PostPosted: Sat Jul 28, 2018 9:13 pm    Post subject: Re: 1977 Beetle is lower on one side than the other. Reply with quote
Ok. Thanks for all the help. My next question is where do I start? I know the ball joints need replacing and a sway bar added. Should I check the torsion leaves and torsion bars first before I start buying parts? And should this novice mechanic try to remove the torsion bars or bite the bullet and try to find a shop?
Page: 1, 2, 3  Next
