thefladge Samba Member
Joined: July 25, 2005 Posts: 1290 Location: Anaheim, CA
Posted: Tue Jul 17, 2018 9:37 pm Post subject: Alternative Alternator: Modern Car Alternator on a Type 1 Engine |
Many years ago some people installed American car or other non-VW alternators on their Baja Bugs for running many lights.
This may date back to the days before VW switched to an alternator to replace the out dated generator.
So, I'm thinking a modern, high amp alternator may be a cost effective alternative to an expensive, high amp aftermarket alternator.
Of course, it wouldn't mount where a stock VW alternator mounts. Custom brackets would need to be fabricated and a longer belt or second belt would be needed.
I'm wondering if anyone here has done this. How do you like it?
Here is a picture of an old kit I recently saw at a VW Show. I didn't buy it. Probably should have.
_________________ 1957 Vintage Baja Bug.
2110cc engine, 40 IDF Webers on Gene Berg manifolds, Engle 110 cam, Bugpack 40×35.5 Street Pro Heads, W8CC plugs, 12.5 pound Flywheel, Kennedy 1700 pound pressure plate. |
mkparker Samba Member
Joined: October 12, 2004 Posts: 332 Location: Sherman, Tx
Posted: Wed Jul 18, 2018 9:46 am Post subject: Re: Alternative Alternator: Modern Car Alternator on a Type 1 Engine |
Saw that. Not really the information I'm looking for.
Maybe someone who is using a non VW alternator could post pictures showing how they mounted it and wired it.
Pros and cons. _________________ 1957 Vintage Baja Bug.
Axitech Samba Member
Joined: August 31, 2011 Posts: 1265 Location: Bucks County, Pa
Posted: Wed Jul 18, 2018 12:24 pm Post subject: Re: Alternative Alternator: Modern Car Alternator on a Type 1 Engine |
I wouldn’t do it. Go the other way, vw alternator, and modern LED lights. _________________ He said to them, “But now if you have a purse, take it, and also a bag; and if you don’t have a sword, sell your cloak and buy one. Luke 22:36
The strongest reason for the people to retain the right to keep and bear arms is, as a last resort, to protect themselves against tyranny in government.-Thomas Jefferson |
Posted: Wed Jul 18, 2018 12:34 pm Post subject: Re: Alternative Alternator: Modern Car Alternator on a Type 1 Engine |
Looks like I might need to search through some old publications from the '60s and '70s for the information I'm looking for. _________________ 1957 Vintage Baja Bug.
Bashr52 Samba Member
Joined: July 16, 2006 Posts: 5666 Location: On an island in VA
Posted: Thu Jul 19, 2018 5:40 am Post subject: Re: Alternative Alternator: Modern Car Alternator on a Type 1 Engine |
This version looks like what those brackets you found do, but I like this better. IT doesn't rely on that crazy long belt all the way across the engine..
risk Samba Member
Joined: June 24, 2004 Posts: 710 Location: Stumpbroke, Arkansas
Posted: Thu Jul 19, 2018 7:16 am Post subject: Re: Alternative Alternator: Modern Car Alternator on a Type 1 Engine |
Here are a few.. google image search of chevy alternator on thesamba.com
just type your search terms into google, space, then site:thesamba.com
https://www.google.com/search?q=chevy+alternator+s...mp;bih=621
This trick works for any website.
The mount kit you showed only supports the front of the alternator.. seems like you would need to brace the back too to keep it aligned with the belt. |
Vanapplebomb Samba Member
Joined: November 03, 2010 Posts: 5388 Location: Holland, MI
Posted: Thu Jul 19, 2018 1:35 pm Post subject: Re: Alternative Alternator: Modern Car Alternator on a Type 1 Engine |
The more you reduce the belt wrap angle on the fan pulley, the sooner it will slip. _________________ 1800 Type 4 Berrien 295
http://www.thesamba.com/vw/forum/viewtopic.php?t=487021 |
earthquake Samba Member
Joined: January 10, 2008 Posts: 3984 Location: SANDY VALLEY, NEVADA
Posted: Thu Jul 19, 2018 2:09 pm Post subject: Re: Alternative Alternator: Modern Car Alternator on a Type 1 Engine |
Why not just use a air condition pulley, then you would not have to stretch a belt all the way around all three, it might turn it a bit slow but it wouldn't be as much off a drag at idle and up until you get into the mid-range. _________________ 74 CLASS 11 LOOK-A-LIKE
69 DUNE BUGGY
79 INTERNATIONAL SCOUT II
05 SCION XB SERIES RELEASE 2[#437]
95 Chevy C3500 dually
98 Ford E150
Link to Kelly J. Nolte 3/20/53 - 11/6/08
https://time-zonelabs.blogspot.com/p/about-kelly.html
DEATH TO CHINGERS!
[From a military recruitment poster in the novel "The Stainless Steel Rat" By Harry Harrison] |
EnjoyNukaCola Samba Member
Joined: January 27, 2014 Posts: 491 Location: Santa Clarita
Posted: Fri Jul 20, 2018 3:11 pm Post subject: Re: Alternative Alternator: Modern Car Alternator on a Type 1 Engine |
What are you planning to run off the alternator, killer 5000W 8-track sound system? _________________ "when i go to drive it i get to like 5-10 mph it is at high rpms and gets higher the faster i go when i shift up to second the rpms drop is this normal or what and this is my first vw please help" |
Posted: Fri Jul 20, 2018 3:50 pm Post subject: Re: Alternative Alternator: Modern Car Alternator on a Type 1 Engine |
EnjoyNukaCola wrote: |
What are you planning to run off the alternator, killer 5000W 8-track sound system? |
Yes.
Brian Samba Moderator
Posted: Fri Jul 20, 2018 4:21 pm Post subject: Re: Alternative Alternator: Modern Car Alternator on a Type 1 Engine |
I saw your alt blew out the other day yea? Switch over to a 38 amp generator. I've had less problems with my 38 than the 6 alternators I've burned. _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
Mr. Unpopular Samba Member
Joined: September 20, 2005 Posts: 3715 Location: Tampa Florida
Posted: Sun Jul 22, 2018 11:17 am Post subject: Re: Alternative Alternator: Modern Car Alternator on a Type 1 Engine |
Bashr52 wrote: |
That would burn a motor up in short order. Think of it this way, I've seen built motors make an extra 15-20hp at the tires by disconnecting the fan belt on an ACVW. So if that fan takes at least 15hp to turn, how is that little bit of belt wrap going to do the job? _________________ "In any racing engine, the nearer you are to it disintegrating, the better it's performance will be"
-Keith Duckworth, creator of the Ford/Cosworth DFV |
veeweeman Samba Member
Joined: December 20, 2009 Posts: 940 Location: New Port Richey, FL
Posted: Sun Jul 22, 2018 5:47 pm Post subject: Re: Alternative Alternator: Modern Car Alternator on a Type 1 Engine |
You want to stay away from anything newer than 2006...I saw a video on YouTube where the guy was saying that for fuel economy, modern alternators don't put out 14.1V anymore, they put out like 13.2+,somewhere in that neighborhood. ..just a FYI _________________ Never be a follower...Do your own thing, make it your own! |
Posted: Sun Jul 22, 2018 5:53 pm Post subject: Re: Alternative Alternator: Modern Car Alternator on a Type 1 Engine |
That’s probably true, made possible by the fact that automakers have embraced LED lights, and modern electronics. High charge voltages aren’t needed on new cars anymore. _________________ He said to them, “But now if you have a purse, take it, and also a bag; and if you don’t have a sword, sell your cloak and buy one. Luke 22:36
risk Samba Member
Posted: Tue Jul 24, 2018 9:26 am Post subject: Re: Alternative Alternator: Modern Car Alternator on a Type 1 Engine |
How about a serpentine setup with a longer belt for the 2nd alternator?
Posted: Tue Jul 24, 2018 9:27 am Post subject: Re: Alternative Alternator: Modern Car Alternator on a Type 1 Engine |
That would be the better option, because you can snake the belt around to wherever you mount the second alternator. You just need to make sure you have adequate belt wrap on the stock generator pulley to keep the fan spinning. _________________ "In any racing engine, the nearer you are to it disintegrating, the better it's performance will be"
dustymojave Samba Member
Posted: Tue Jul 24, 2018 9:42 pm Post subject: Re: Alternative Alternator: Modern Car Alternator on a Type 1 Engine |
How about placing the alternator like a power steering pump on an offroad racer? _________________ Richard
SoCalBajas Member
Posted: Wed Jul 25, 2018 4:43 am Post subject: Re: Alternative Alternator: Modern Car Alternator on a Type 1 Engine |
AC pulley with secondary belt is likely your best bet. |
