arizonabuckeye Samba Member
Posted: Wed Jul 18, 2018 1:39 pm Post subject: Brake adjuster screws |
I am working on wrapping up my brake job and when I put it back together noticed I have the slanted brake adjuster screws but the straight brake shoes. I was going to just get a set of straight screws and swap them out on the thinking that in the future I might end up with angled shoes and being able to just swap them back in would be nice. Is that a bad idea? |
Erik G Samba Member
Joined: October 16, 2002 Posts: 13281 Location: Tejas!
Posted: Wed Jul 18, 2018 2:05 pm Post subject: Re: Brake adjuster screws |
Erik G wrote: |
huh? slanted brake adjust screws? They are all the same except thin or thick slot |
Angled or sloped then? Some the slot is deeper on one side then it is on the other. |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Wed Jul 18, 2018 2:35 pm Post subject: Re: Brake adjuster screws |
No problems switching them as long as they match the shoes you are using
angled
_________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
KTPhil Samba Member
Joined: April 06, 2006 Posts: 34022 Location: Conejo Valley, CA
Posted: Wed Jul 18, 2018 2:41 pm Post subject: Re: Brake adjuster screws |
KTPhil Samba Member
Posted: Wed Jul 18, 2018 3:23 pm Post subject: Re: Brake adjuster screws |
While you are at it, super-clean the screws and star wheels, and the inside of the blocks where they ride. Then use the SLIGHTEST smear of anti-seize compound on the threads and on the block bore walls, so they spin easily. Work them round & round, and in & out, a few times through the full thread, then set them right (usually all-in to start, with new shoes. You will thank yourself next time you need to adjust them (with the drum on)!
Erik G Samba Member
herbie1200 Samba Member
Joined: April 27, 2006 Posts: 833 Location: Rome - Italy
Posted: Thu Jul 19, 2018 12:36 am Post subject: Re: Brake adjuster screws |
I do not agree with using wider slot register on 58-64 brakes.
The narrow slot are needed to keep the shoe in the correct position towards the drum internal surface because brake plate does not have the support for this.
Cylinder's slot and register's slots have the job to keep the shoe aligned.
Correct 58-64 cylinders DO HAVE a narrow slot. If registers are wide slot the effort of keeping the shoe in the correct angle is all in charge of the cylinder that would wear itself internally in advance.
Incorrect slot cause the shoes to be not correctly aligned (when not braking) and the registration should be "loose" to avoid shoe rubbing on drum, then the pedal gains a lot of travel before braking effect occurs. |
Posted: Thu Jul 19, 2018 11:32 am Post subject: Re: Brake adjuster screws |
KTPhil wrote: |
While you are at it, super-clean the screws and star wheels, and the inside of the blocks where they ride. Then use the SLIGHTEST smear of anti-seize compound on the threads and on the block bore walls, so they spin easily. Work them round & round, and in & out, a few times through the full thread, then set them right (usually all-in to start, with new shoes. You will thank yourself next time you need to adjust them (with the drum on)! |
Done and done. This is actually to wrap up a bigger project of doing some much neglected deep cleaning and refreshing. I actually took the stars and adjusters put a good smear on the adjusters worked them back and forth several times, gave them a good wipe, back and forth and wiped off excess again. Wanted to make sure I got all the screw surfaces with a slight coat of the anti-seize. |
