Daviscpa Samba Member
Posted: Thu Jul 19, 2018 11:46 am Post subject: oil pump gasket |
Got a '64 Beetle and the oil pump cover leaks. It also has one of the studs broken off. So I need a little help....I have looked all over the internet, but have yet to locate a cover gasket for a '64..any suggestions? Also, looks like I need to take the pump off to fix the stud, would it be wise to just replace the pump with a new one? Or is that just over kill? Car runs fine, but I have no idea what the oil pressure is.
thanks for any help |
Cusser Samba Member
Joined: October 02, 2006 Posts: 31374 Location: Hot Arizona
Posted: Thu Jul 19, 2018 12:07 pm Post subject: Re: oil pump gasket |
Daviscpa wrote: |
Got a '64 Beetle and the oil pump cover leaks. It also has one of the studs broken off. |
First - you MUST determine what size engine you have in that 1964. Post photos. post engine number, just below generator stands.
Earlier engines use 6mm x 1.0mm studs, later use 8mm x 1.25mm.
Yes, likely you'll need to remove the oil pump to extract that broken stud, you'll need an oil puller tool, under $10. And if you're doing that, you may want to consider a combination pump/filter unit. For those you'd pull all 4 studs. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Posted: Thu Jul 19, 2018 12:37 pm Post subject: Re: oil pump gasket |
It's a stock engine, 1200 and still 6v. Pretty sure it has the 6mm studs. Never thought about the puller tool, but certainly sounds like I'll need that.
So any idea who sells gaskets?
thanks. |
Posted: Thu Jul 19, 2018 12:48 pm Post subject: Re: oil pump gasket |
I'll post the engine number shortly |
diablosandwich Samba Member
Joined: January 15, 2012 Posts: 469 Location: Illinois
Posted: Thu Jul 19, 2018 2:53 pm Post subject: Re: oil pump gasket |
Engine # is 8697231...hope that helps. |
rcooled Samba Member
Joined: September 20, 2008 Posts: 2506 Location: Santa Cruz, CA
Posted: Thu Jul 19, 2018 3:25 pm Post subject: Re: oil pump gasket |
Daviscpa wrote: |
So any idea who sells gaskets? |
You may have to buy a complete engine gasket set to get those 6mm oil pump gaskets. Not very common to see the 6mm gaskets sold separately.
http://vwparts.aircooled.net/Engine-Gasket-Set-40hp-Engines-111-198-005-p/111-198-005.htm
Applying a THIN film of sealer (Curil T or equiv) to both sides of the cover-to-pump gasket will help prevent leakage.
Daviscpa wrote: |
Engine # is 8697231 |
That would be a correct engine # for a 1964 1200cc, 40HP Beetle. _________________ '63 Ragtop (current)
'65 Ghia coupe (totaled)
'69.5 Ghia convertible and
'62, '63, '65, '69 Bugs (all long gone) |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9767 Location: Oregon
Posted: Thu Jul 19, 2018 4:57 pm Post subject: Re: oil pump gasket |
Daviscpa wrote: |
thanks. |
Just PM me your name and address and I'll mail you a set. No charge.
I have several from gasket kits form repair and engine builds I have done over the last couple of years.
Good Luck. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
67CarGuy Samba Member
Joined: April 01, 2017 Posts: 46 Location: Boston area, USA
Posted: Thu Jul 19, 2018 5:15 pm Post subject: Re: oil pump gasket |
And the Samba karma comes through again! Way to go, rustavenger! _________________ 1967 Beetle (Family car - 2nd owner) ...What have I gotten myself into?!
1967 Plymouth Barracuda (Family car - 2nd owner) ...See a pattern yet?
rcooled wrote: |
On the other hand, if what the OP really wants is a project that'll take up all of his free time for a couple of years, relieve his bank account of many thousands of dollars and frustrate the living hell out of him, then this car is a good place to start. |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24759 Location: Olympia Wash Rinse & Repeat
Posted: Thu Jul 19, 2018 6:37 pm Post subject: Re: oil pump gasket |
Daviscpa wrote: |
thanks. |
You can get paper gasket sheets from your FLAPS for the pump body to engine case. As for the oil pump to cover gasket, yellow pages work just dandy for that. An Exacto knife is a great tool to have to cut out the gaskets. _________________ In Stereo, Where Available! |
Posted: Fri Jul 20, 2018 4:06 am Post subject: Re: oil pump gasket |
Thanks everyone for the help....and parts.
Really appreciated. |
bluebus86 Banned
Posted: Fri Jul 20, 2018 8:47 am Post subject: Re: oil pump gasket |
the pump can be checked for wear, Id not replace it unless it is proven to be worn badly.
the top cover gasket is supposed to be VERY THIN, the pump to engine gasket is thick. do not mix them up. too thick a cover gasket will result in reduced oil pressure!
use of sealant on gasket can block the guard ring around the pump. this guard ring is designed to supply suction into the ring to intercept leaks from the high pressure side of the pump do not allow ring to be filled with sealer.
the thin gasket for cover is from .002 to.003 inch typically. some aftermarket kits supply too thick a gasket.
you can cut your own gasket, using the old one or the lid as a template. as stated, many autoparts stores have gasket sheets for sale.
Bug On! _________________ Help Prevent VW Engine Fires, see this link.....Engine safety wire information
Posted: Thu Jul 26, 2018 5:45 pm Post subject: Re: oil pump gasket |
Daviscpa,
Did the gaskets make it yet? _________________ I have learned over the years.
Buy Once, Cry Once!
FL-Frank Samba Member
Joined: August 08, 2015 Posts: 823 Location: Jupiter, Florida
Posted: Fri Jul 27, 2018 3:12 pm Post subject: Re: oil pump gasket |
Couple of potential issues to be aware of based on my experience earlier this year...
1) If you buy one of the Empi pullers, you might want to buy two so you’ll be able to complete the extraction with the second one when the first one breaks. Also, You may have to modify their puller by grinding down the wings so it will fit.
2) if you loosen the case nuts adjacent to the oil pump, it will make it easier to Install the pump. However, you’ll run the risk of causing case seam leaks even though you tighten everything back down to spec _________________ “Tinker Toy” 1967 Savannah Beige Beetle Sedan...........Mostly Original Survivor
“Fritz” 1964 Gulf Blue Karmann Ghia Coupe...Complete Pan-Off Restoration SOLD |
