vwssvl Samba Member
Posted: Thu Jul 19, 2018 4:45 pm Post subject: Split front beam |
Hi!
Can you please help me to identify this front beam?
Thanks
Peter_N Samba Member
Joined: February 19, 2014 Posts: 321 Location: The Netherlands
Posted: Fri Jul 20, 2018 12:48 am Post subject: Re: Split front beam |
vwssvl wrote: |
Hi!
Thanks
I'm not an expert on this, but there should be a number stamped on the bump stop finger (part in the picture).
You can check the number in this table to see when it was built (fifth column mentoins front axle numbers).
https://www.thesamba.com/vw/archives/info/bugchassisdating.php _________________ My 1958 PGSG project topic |
vwssvl Samba Member
Posted: Fri Jul 20, 2018 6:40 am Post subject: Re: Split front beam |
Thanks for your reply but the early beams do not have that stamped Number 😞 |
Posted: Fri Jul 20, 2018 10:57 am Post subject: Re: Split front beam |
vwssvl wrote: |
Told you I’m not an expert _________________ My 1958 PGSG project topic |
Martin Southwell Samba Member
Joined: November 24, 2010 Posts: 984 Location: Bath, England
Posted: Sun Jul 22, 2018 4:55 am Post subject: Re: Split front beam |
vwssvl wrote: |
Not so. All beams are numbered on a vehicle when they left the factory, including early ones. |
Porsche904 Samba Member
Posted: Sun Jul 22, 2018 8:46 am Post subject: Re: Split front beam |
this is a short tower Split beam |
DDub Samba Member
Joined: January 06, 2005 Posts: 307 Location: central pa.
Posted: Sun Jul 22, 2018 9:42 am Post subject: Re: Split front beam |
My '52 is numbered. |
sweden Samba Member
Posted: Tue Jul 24, 2018 10:53 am Post subject: Re: Split front beam |
Up to 1961 the stamp is here.
_________________ Me and my sons cars Typ1 -49 -50 -51 -52 -52 -53 -53 -54 -55 -55 -56 -56 -57 -58 cab -64 cab
T3 TriStar airride with Audi 1,8T engine and Porsche 996 gearbox. |
vwssvl Samba Member
Posted: Wed Jul 25, 2018 5:28 pm Post subject: Re: Split front beam |
DDub wrote: |
Where??? |
DDub Samba Member
Posted: Wed Jul 25, 2018 8:33 pm Post subject: Re: Split front beam |
vwssvl wrote: |
DDub wrote: |
Where??? |
I might be where Swedan shows. It's been 20 years but I remember a stamped number. I may have to crawl under it to find it again. |
vwssvl Samba Member
Posted: Fri Jul 27, 2018 4:15 am Post subject: Re: Split front beam |
I already checked again and there isn’t any VW reference |
66brm Samba Member
Joined: January 25, 2010 Posts: 3676 Location: Perth Western Australia
Posted: Fri Jul 27, 2018 5:48 am Post subject: Re: Split front beam |
Rh bump stop horn is where it's typically located _________________ Aust. RHD 66 Type 1
Aust. RHD 57 Type 1 Oval
modok wrote: |
I am an expert at fitting things in holes, been doing it a long time |
type4split Samba Member
Joined: May 23, 2007 Posts: 681 Location: Hamilton, Indiana
Posted: Thu Jan 10, 2019 7:39 pm Post subject: Re: Split front beam |
I have a short shock beam. But it doesn’t follow numbers. Has a zero “0” at beginning
_________________ '67 deluxe bus w/the little windows
'52 beetle
'55 convertible
'50-something convertible (*need ribbed 'vert quarter panel )
'63 "milo" beetle
Part, parts and more parts |
DDub Samba Member
Posted: Thu Jan 10, 2019 8:31 pm Post subject: Re: Split front beam |
Was that arm replaced? Look at the ugly welds. |
Posted: Thu Jan 10, 2019 8:43 pm Post subject: Re: Split front beam |
I agree?? Looked welded. Back side is clean though??
Still doesn’t explain the part number _________________ '67 deluxe bus w/the little windows
'52 beetle
'55 convertible
'63 "milo" beetle
vwoldbug Samba Member
Posted: Tue Jan 22, 2019 5:50 pm Post subject: Re: Split front beam |
Maybe it's a replacement part . |
