Rorke Samba Member
Joined: August 04, 2016 Posts: 255 Location: Traverse City, MI
Posted: Wed Jun 16, 2021 4:41 am Post subject: Re: The official Chinese Diesel Heater thread (Webasto Knockoff) |
How hot does the hot air duct run on a 5k?
I ran the heat through my new storage box in between the seats. I figured it would get warm, but holy Hell this thing is hot! I am guessing 160°F. I couldn't keep my hand on it anyway.
Anyway, has anyone heard of van's combusting or melting because of the hot air heat?
Zeitgeist 13 Samba Member
Posted: Wed Jun 16, 2021 8:22 am Post subject: Re: The official Chinese Diesel Heater thread (Webasto Knockoff) |
I have a 5k unit externally mounted very similar to yours, and the heat is routed through the factory rear heater housing. The housing is plastic, and it hasn't melted yet. I'm drawing my intake air from outside the van, which may allow it to regulate temps a little easier--dunno _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
WetWest91 Samba Member
shagginwagon83 Samba Member
Joined: February 07, 2016 Posts: 3803 Location: VA/TN
Posted: Mon Sep 27, 2021 7:33 pm Post subject: Re: The official Chinese Diesel Heater thread (Webasto Knockoff) |
It's about that time!!! Buy your $120 heaters now!
Seriously - these heaters + LiFePo4 are great. Yeah figuring out the fuel tank sucks...but damn is it not awesome to have a toasty van in super cold temperatures!
Anyway - I think I have around 300 hours on my heater. I sometimes have some issues failing to ignite (E11 I believe). However it usually gets it on the 2nd ignite. I usually run 50:50 diesel to kerosene. I'm thinking it is the glow plug?
Does anyone have any source for some quality parts? I can get an Espar D2 OEM plug for $80 or an aftermarket for $30. I'd say given it's importance - maybe just get an OEM. _________________ Brandon
Instagram @joannthevan
Last edited by shagginwagon83 on Mon Sep 27, 2021 8:20 pm; edited 1 time in total |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6833 Location: Fort Lauderdale, Fl.
Posted: Mon Sep 27, 2021 8:12 pm Post subject: Re: The official Chinese Diesel Heater thread (Webasto Knockoff) |
Shagginwagon, there is also Butler Technik which carries a lot of Webasto/ Eberspacher parts and literature.
https://www.butlertechnik.com/vehicle-heater-kits-c1 _________________ This free advice is worth exactly what you paid for it.
holocenevan Samba Member
Posted: Wed Oct 13, 2021 11:41 am Post subject: Re: The official Chinese Diesel Heater thread (Webasto Knockoff) |
I’m most of the way thru reading every page of this thread before buying one of the 2kw versions.
As a pilot flying turbine aircraft I’m wondering if anyone has run the CDH on Jet A or B? It supposedly burns a little hotter than diesel but Jet A is almost identical to kerosene. It’s also $5 a gallon or so and available at almost any airport. When we sump our aircraft in the morning that cup or two often goes in the tank of the Cummins powered service truck.
Any thoughts, safety issues, flames, or experience on using Jet A in a CDH? |
bobbyblack Samba Member
Joined: May 21, 2015 Posts: 4351 Location: United States, Iowa
Posted: Wed Oct 13, 2021 12:16 pm Post subject: Re: The official Chinese Diesel Heater thread (Webasto Knockoff) |
Jet A would be one step more clean than kerosene. I run 100% kerosene, I am convinced that most of the problems develop due to dirty fuel. Anyway, if running diesel, it is recommended to power the unit up to full blast for a few minutes before shut down to burn out the combustion area a bit better, if its getting carboned up. I'd say give it a try! _________________ '87 Westy 'Flossie','86 Westy 'R1','86 tintop GL - Subi2.2 'J2','83.5 stock tintop L 'ZoomBus','74 Karmann Ghia, '63 Notch |
Howesight Samba Member
Joined: July 02, 2008 Posts: 3274 Location: Vancouver, B.C.
Posted: Wed Oct 13, 2021 1:10 pm Post subject: Re: The official Chinese Diesel Heater thread (Webasto Knockoff) |
I am just thinking out loud here on 100% kerosene (I run 50/50 diesel/kerosene). Some folks have mentioned that running 100% kerosene is not recommended since straight kerosene will not adequately lubricate the fuel pump. While I agree that diesel oil will provide more lubricity, I disagree that kerosene will not provide enough lubrication for that pulse pump. Bombardier and Rotax designed their 2-stroke engines some 15 or 20 years ago to run on straight gasoline (before their current crop of direct-injection engines) when the engines were idling at around 1,500 to 2,000 rpm. Their studies showed that gasoline provided adequate lubrication at those "slow" engine speeds and they designed the oil-injection system to shut off at idle speeds. These are companies (esp Rotax) with very advanced engineering, so I think, if these high performance two-stroke engines can idle at these speeds with only raw gasoline providing the lubrication, then a solenoid pulse-pump can easily do so. Besides, the gasoline versions of the Eberspacher also run a pulse-pump with only gasoline as lubricant.
I reckon that the "lubrication theory" for running some amount of diesel in the CDH is not a good theory.
I run a diesel/kerosene mix only because up here in the Great White North, kerosene is obscenely expensive compared to US prices. _________________ '86 Syncro Westy SVX |
Posted: Thu Nov 04, 2021 7:05 am Post subject: Re: The official Chinese Diesel Heater thread (Webasto Knockoff) |
I was getting E10 error (failure to ignite). LiFePo4 voltage with upgrade wire loom. All looked good. Had a spare new heater on shelf - swapped it in and same error. Replaced fuel pump. Remove intake silencer. No dice. Turned out to be my Webasto brand silencer was clogged up. I guess my mixtures settings are off? Also any recommendations on how to clean this nice exhaust silencer? _________________ Brandon
Instagram @joannthevan |
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5688 Location: Manhattan, Kansas, USA
Syncro Jael Samba Member
Posted: Thu Nov 04, 2021 7:36 am Post subject: Re: The official Chinese Diesel Heater thread (Webasto Knockoff) |
bobbyblack wrote: |
I run 100% kerosene |
I too have been running 100% kerosene. For many years and hundreds of hours on the heater. I have never had to replace the pump because of lubrication problems.
Howesight wrote: |
I run a diesel/kerosene mix only because up here in the Great White North, kerosene is obscenely expensive compared to US prices. |
I have also run 50%-50% Offroad Diesel and Kerosene. I have also not noticed any difference in sooting.
A friend owns our local emissions shop and let me set my air-fuel ratio while the "sniffer" exhaust analyzer was attached. The stock settings were way to rich at my home altitude of 4800ft. I also adjust the fuel down when at over 7000ft. I did find an inexpensive CO analyzer on Amazon.
The exhaust pipe is as clean as the day it was installed. Also if you want to reduce the noise of the heater, run the same muffler on the intake. It will surprise you how much quieter it is outside the vehicle. _________________ 1987 Syncro Westfalia Hightop - NAHT
Subaru EJ25 Forged Frankenmotor, Triple Knob.
Jael = (Mountain Goat) |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16505 Location: Brookeville, MD
Posted: Thu Nov 04, 2021 9:18 am Post subject: Re: The official Chinese Diesel Heater thread (Webasto Knockoff) |
Syncro Jael wrote: |
Also if you want to reduce the noise of the heater, run the same muffler on the intake. It will surprise you how much quieter it is outside the vehicle. |
Ooooo, thanks. I am going to try that on my gas heater. I have two mufflers on the exhaust and that makes a difference but nothing on the intake, yet. _________________ Dave O
The Western Syncro build
gtinseth Samba Member
Joined: July 25, 2019 Posts: 76 Location: NW California
Posted: Thu Nov 04, 2021 9:00 pm Post subject: Re: The official Chinese Diesel Heater thread (Webasto Knockoff) |
shagginwagon83 wrote: |
I was getting E10 error (failure to ignite). LiFePo4 voltage with upgrade wire loom. All looked good. Had a spare new heater on shelf - swapped it in and same error. Replaced fuel pump. Remove intake silencer. No dice. Turned out to be my Webasto brand silencer was clogged up. I guess my mixtures settings are off? Also any recommendations on how to clean this nice exhaust silencer? |
Not to add worry, but if the muffler is sooted up, what must the burn chamber and glow plug look like? Did you dial in the pump speed and fan speed with temp readings and a CO monitor on the exhaust? I would also strongly advise acquiring Ray Jones's Afterburner controller if your unit will support it. As Jael has demonstrated in another post with great pictures, it gives you tons more control and options. |
erste Samba Member
Joined: March 29, 2013 Posts: 1110 Location: San Francisco
Posted: Thu Nov 04, 2021 11:44 pm Post subject: Re: The official Chinese Diesel Heater thread (Webasto Knockoff) |
dobryan wrote: |
Ooooo, thanks. I am going to try that on my gas heater. I have two mufflers on the exhaust and that makes a difference but nothing on the intake, yet. |
I have this intake silencer on my Espar D2 and does help keep the noise down. I'm not sure you need the metal muffler for the exhaust on the intake side. There are other options on ebay that look identical.
https://www.heatso.com/webasto-combustion-air-intake-silencer/ |
Posted: Fri Nov 05, 2021 11:51 am Post subject: Re: The official Chinese Diesel Heater thread (Webasto Knockoff) |
gtinseth wrote: |
I haven’t opened that heater up yet. I have Afterburner controller. I did not dial in my burn settings. I need to do that. _________________ Brandon
Posted: Fri Nov 05, 2021 2:23 pm Post subject: Re: The official Chinese Diesel Heater thread (Webasto Knockoff) |
erste wrote: |
dobryan wrote: |
I used that same intake silencer and it really quiets the CDH a lot. I also used a genuine Webasto muffler on the exhaust side, after seeing some CDH posts (not on the Samba) showing how poorly the Chinese-made mufflers worked. So, $250 CAD for the whole CDH, but $100 CAD for the Webasto muffler.
*SIGH*
Also, since my rig is s Syncro and the underside is exposed to mud, dust and snow, I inserted the CDH intake muffler inside a K&N cone filter with a plastic shield outside the cone to keep it from being totally covered in mud.
It is now very quiet. _________________ '86 Syncro Westy SVX |
DyerMaker Samba Member
Joined: November 17, 2021 Posts: 1 Location: Cabranes
Posted: Wed Nov 17, 2021 12:21 am Post subject: Re: The official Chinese Diesel Heater thread (Webasto Knockoff) |
beach_creature wrote: |
No polystyrene, it came packed in soft plastic foam. The smell has gotten less intense, but still noticeable. Hole it will eventually go away. Kind of smells like hot brakes.
I have sniffed around the unit after it has shut off but still warm, and I have yet to identify which part of the heater is so fragrant. |
Hey, did you find something out? I have the same problem with mine and Im worried about breathing this plastic smell... |
Posted: Wed Nov 17, 2021 10:56 pm Post subject: Re: The official Chinese Diesel Heater thread (Webasto Knockoff) |
DyerMaker wrote: |
I just saw a post on the facebook group that mentioned that the silicon gasket for the base of the heater was not really high temp silicon. Maybe check that? |
GreenZoomBug Samba Member
Joined: September 19, 2021 Posts: 45 Location: Over the Hill
Posted: Thu Nov 18, 2021 3:05 am Post subject: Re: The official Chinese Diesel Heater thread (Webasto Knockoff) |
I'm considering buying one of the Chinese diesel heater for my 67 Baja. They advertise them as a parking heater. Can you use them while driving ? |
ZsZ Samba Member
Joined: December 11, 2010 Posts: 1647 Location: Budapest Hungary, Europe
Posted: Thu Nov 18, 2021 4:27 am Post subject: Re: The official Chinese Diesel Heater thread (Webasto Knockoff) |
GreenZoomBug wrote: |
If you set up the intake and the exhaust pipes correctly then yes, you can.
Check Eberspaecher D2 or D4 install broschures for the correct installation. _________________ Zoltan
1.9 MTdi 2wd Multivan (ex Caravelle)
Van since 2006, engine since 2008 |
