seattlesombrero Samba Member
Joined: December 22, 2015 Posts: 16 Location: Seattle
Posted: Thu Nov 18, 2021 6:55 pm Post subject: Re: The official Chinese Diesel Heater thread (Webasto Knockoff) |
I haven't seen this spot being used for a 2kw CDH, is there a reason? It sure looks like it'd fit and I've used the power outlets about 3 times in the last 29 years. It'll fit under the water filler hose. I'm thinking put a fuel tank below, exterior, mounted underneath and possibly add a fourth square port (next to the water/electric/water filler caps) to fill the diesel tank.
Any problems with this theory, so far? _________________ I'm good at 📸 not 🔧.
'90 Westfalia GL + EJ25
'85 Westfalia, 2 Jetta's, Fox, Cabriolet, Bugs
Rolled over in a '65 VW bus my mom was driving. |
GreenZoomBug Samba Member
Joined: September 19, 2021 Posts: 45 Location: Over the Hill
Posted: Thu Nov 18, 2021 6:59 pm Post subject: Re: The official Chinese Diesel Heater thread (Webasto Knockoff) |
Lot's of information there, but l didn't see anything related to heater use and driving. They all seem to call them "parking heater" Where does everyone get replacement parts from ? I get the feeling they are problematic from what l read here |
vanis13 Samba Member
Joined: August 15, 2010 Posts: 3093 Location: ABQ NM USA.... Except when not
Posted: Thu Nov 18, 2021 7:32 pm Post subject: Re: The official Chinese Diesel Heater thread (Webasto Knockoff) |
GreenZoomBug wrote: |
I use my Espar while driving. works well _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
www.SuperVanagon.com - some stuff I make |
Posted: Thu Nov 18, 2021 7:39 pm Post subject: Re: The official Chinese Diesel Heater thread (Webasto Knockoff) |
seattlesombrero wrote: |
Any problems with this theory, so far? |
One can tell you haven't read every page of this topic ...pg 44
https://www.thesamba.com/vw/forum/viewtopic.php?p=9517633&highlight=#9517633
original place I posted those pics
https://www.thesamba.com/vw/forum/viewtopic.php?p=7446063#7446063 _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
Howesight Samba Member
Joined: July 02, 2008 Posts: 3274 Location: Vancouver, B.C.
Posted: Thu Nov 18, 2021 7:53 pm Post subject: Re: The official Chinese Diesel Heater thread (Webasto Knockoff) |
There is no particular problem with using that space for your CDH. However, there are better locations. I used that space for my LiFePo4 280 amp/hour battery and accessories. I looked at many different places where I could install the CDH (mine is a "2000" size) and under the bench seat worked nicely. The key reasons for me were:
1. Super-clean install with no "pan" required;
2. Ideal location for the hot air outlet;
3. Excellent access to the CDH for maintenance or trouble-shooting;
4. Ideal location to keep the CDH exhaust system short. Longer exhaust systems slow exhaust gases exiting the CDH.
Here's that space you show in your pic which, in my rig, houses the lithium battery:
Here's where I installed my CDH:
I cut out the Westfalia "wood" floor beneath the CDH so that I did not have to fabricate a circular "pan".
I also fabricated a sheet aluminum cover for the CDH Not shown) so that I can still utilize the space above the CDH. _________________ '86 Syncro Westy SVX |
Posted: Thu Nov 18, 2021 8:18 pm Post subject: Re: The official Chinese Diesel Heater thread (Webasto Knockoff) |
LOL, I DID see that but after pg 55 it fell out of my brain.
I still use my fridge so I won't be routing the intake that way. Hoping to keep the original "wall" in there, it is our wine cellar after all.
We'll see in the next few weeks..... Thanks! _________________ I'm good at 📸 not 🔧.
Posted: Thu Nov 18, 2021 8:24 pm Post subject: Re: The official Chinese Diesel Heater thread (Webasto Knockoff) |
Howesight wrote: |
Good points. Talking to my mechanic tomorrow, (I do what I can, he fixes my mistakes) and will report back on final locations. Thanks a lot! _________________ I'm good at 📸 not 🔧.
Posted: Thu Nov 18, 2021 9:45 pm Post subject: Re: The official Chinese Diesel Heater thread (Webasto Knockoff) |
We'll see in the next few weeks..... Thanks! |
I still use my fridge too. Heater draws air from under the fridge which is nice since that is where the cold air is at floor level... If it needs more air to draw it can suck around the cabinet including the vent by the window behind the stove.
I also use the extremely convenient easy access storage under the seat.... I have absolutely no idea why anyone would fill that space with something permanent - that's craziness in my mind.
Other place I thought the heater would live well is above the glove compartment piped into the heater box/ducting. Another place to tie into the ducting would be the B pillar and it would plenum into the ceiling vents and even backwards into the front of the van. Not nearly as good as above the glove compartment but many people put fridges, poopers, etc blocking things right where the side door opens.... Which is another totally bonehead thing IMO.
The cool thing about next to the water tank or above the glove is it is unused/ bonus space and the heater didn't take away from the vans usable space.
Under the seat is the worst... If you want it there, mount it above the trans if you have a 2wd and pipe it in. _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
Posted: Thu Nov 18, 2021 10:00 pm Post subject: Re: The official Chinese Diesel Heater thread (Webasto Knockoff) |
vanis13 wrote: |
- that's craziness in my mind. |
I get where you're coming from, that's prized space. As King Arthur said, "The quest continues..." _________________ I'm good at 📸 not 🔧.
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6829 Location: Fort Lauderdale, Fl.
Posted: Fri Nov 19, 2021 4:58 am Post subject: Re: The official Chinese Diesel Heater thread (Webasto Knockoff) |
Replacement parts? At the low cost of them I think people just get a new one. Not sure if there is a parts vendor.
Compared to the Webasto's & Espar costing $1100.00 + and you can get parts for them and suport from good reputable vendors. _________________ This free advice is worth exactly what you paid for it.
Rorke Samba Member
Joined: August 04, 2016 Posts: 255 Location: Traverse City, MI
Posted: Fri Nov 19, 2021 2:47 pm Post subject: Re: The official Chinese Diesel Heater thread (Webasto Knockoff) |
My 5 kw CDH is under the bus on the driver’s side toward the centerline.
The box cover was bought online. It is hinged and fastened with wing nuts for simple servicing.
Hot air is ducted over the gas tank and up through a box between the front seats.
Return is tied in through the stock rear heater vent (I still use the stock rear heater, for now)
Exhaust is by the rear jackpoint.
Intake is just forward of the trans mount.
Fuel tank is 3 gallons. Filled through a port just aft of the stock water tank fill.
It runs through the secret spot shown in recent previous posts.
I did have to move the propane tank forward. Not hard.
Now that I have high-temp fittings, it works perfectly.
The zero storage loss is great. The air blowing back toward the bed and/or toward the cab is very nice.
If this helps anyone, sweet.
ProspectiveOwnergon Samba Member
Posted: Mon Nov 22, 2021 1:16 pm Post subject: Re: The official Chinese Diesel Heater thread (Webasto Knockoff) |
Just got delivery of a CDH all-in-one. Is it normal for them to get delivered with a little bit of fuel in the line? Maybe factory tested?
It's a VEVOR, so not a knockoff of a knockoff and purchased from Amazon. |
gbrandt Samba Member
Posted: Mon Nov 22, 2021 2:38 pm Post subject: Re: The official Chinese Diesel Heater thread (Webasto Knockoff) |
Where are you guys picking up your fuel line Tee's from? I need 8mm-8mm with a 5mm tee.
Gregor _________________ 'Lucky' our 1987 Red Westy, ASV 1.9 TDI ~130HP, Peloquin differential (had a GW 2.3 that we loved, but it died, we drove it hard!)
We've driven in 49 countries and 5 continents to date
Canada to Argentina and back, 2015 to 2017.
Canada to Europe and back (including Turkey, Morocco and Iceland), 2017 to 2019
Mexico 2022-2023
https://www.instagram.com/live.travel.play/
http://livetravelplay.ca |
Posted: Mon Nov 22, 2021 2:53 pm Post subject: Re: The official Chinese Diesel Heater thread (Webasto Knockoff) |
gbrandt wrote: |
Gregor |
used the one off the WBX since I put in a Subi. _________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5688 Location: Manhattan, Kansas, USA
gtinseth Samba Member
Joined: July 25, 2019 Posts: 76 Location: NW California
Posted: Mon Nov 22, 2021 9:24 pm Post subject: Re: The official Chinese Diesel Heater thread (Webasto Knockoff) |
ProspectiveOwnergon wrote: |
Mine had some machine oil in it I think from the pump. It wasn't a problem. |
Posted: Mon Nov 22, 2021 9:25 pm Post subject: Re: The official Chinese Diesel Heater thread (Webasto Knockoff) |
Andymon Samba Member
Joined: February 24, 2015 Posts: 313 Location: Medford, OR
Posted: Mon Nov 29, 2021 4:13 pm Post subject: Re: The official Chinese Diesel Heater thread (Webasto Knockoff) |
Ok, all you Chinese diesel heater and battery experts! These are the two batteries I have in a series that are only charged with a Renogy 100w solar panel. (Another 100w panel to be installed soon) https://www.batteriesplus.com/productdetails/sligc115 This is the CDH I want to install in our Westy:
https://www.vevor.com/products/2kw-12v-diesel-air-...4728294498 Does this sound like everthing will work? _________________ "Blanch" '85 Westy
"Too many freaks and not enough circuses". |
Posted: Mon Nov 29, 2021 5:01 pm Post subject: Re: The official Chinese Diesel Heater thread (Webasto Knockoff) |
Vevor is a suitable CDH product. Lavaner is the silver standard for CDH, but you pay more for it. Vevor is a rebrander basically where many types buy and restamp it seems. A CDH will work off any 12v source as long as it doesn't drop and trigger low voltage warnings. |
