valvecovergasket Samba Member
Posted: Wed Jul 10, 2019 8:15 am Post subject: Re: Anyone tried these $179 Webasto heater knockoffs? |
i know this is for knockoff heaters, but i searched and couldnt find any examples of this particular install location and i think it applies the same to the knockoffs - but for those with a diesel that had the original diesel-fired under floor espar, i was able to replace the plumbing with a webasto and get it to push air out of the stock vents that point rearward between the front seats.
and the pass-through the webasto uses was originally used by the old diesel heater
_________________ MegaSquirt resource - SpitfireEFI.com
gone, but not forgotten: '83 tdi westy - swap thread |
the_last1 Samba Member
Joined: March 10, 2015 Posts: 130 Location: Bay Area CA
Posted: Sat Sep 28, 2019 9:55 am Post subject: Re: Anyone tried these $179 Webasto heater knockoffs? |
davevickery wrote: |
This question of where to put a diesel tank came up and this 5.5 liter one looks like it would work really well in the D pillar in the engine compartment.
https://www.ebay.com/itm/173767723601
I like where your head is at! plus the pump can be mounted outside near the engine compartment! Anyone try to mount the fuel outside yet? I don't want the diesel or the pump in the compartment. _________________ 1991 Multivan
1990 Syncro Doka
The shallow end of the pool..is where the turds float |
oldskewlsk8ter Samba Member
Posted: Sat Sep 28, 2019 11:30 am Post subject: Re: Anyone tried these $179 Webasto heater knockoffs? |
the_last1 wrote: |
I like where your head is at! plus the pump can be mounted outside near the engine compartment! Anyone try to mount the fuel outside yet? I don't want the diesel or the pump in the compartment. |
That’s where I mounted mine.
_________________ 1986 Hightop w/EJ25 DOHC & 4EAT auto
1965 Kombi project |
Posted: Sat Sep 28, 2019 12:40 pm Post subject: Re: Anyone tried these $179 Webasto heater knockoffs? |
oldskewlsk8ter wrote: |
the_last1 wrote: |
That looks amazing! do you fill from the outside? also where did you mount your pump. i think this is a great spot to add the fuel _________________ 1991 Multivan
1990 Syncro Doka
danfromsyr Samba Member
Posted: Sat Sep 28, 2019 4:37 pm Post subject: Re: Anyone tried these $179 Webasto heater knockoffs? |
bring the fill hose up the side vent.
2 small screws or some good velcro and the side vent pops off.
though on my van that's where the coolant pressure cap is mounted as a built in 'libby' fill pipe. |
beach_creature Samba Member
Posted: Mon Oct 07, 2019 2:15 pm Post subject: Re: Anyone tried these $179 Webasto heater knockoffs? |
So I want to get a 2kw heater. There is the actual 2kw version with a smaller body. There is also, the 5kw body but labelled as 2kw, I assume with less fuelling. This 5kw body labelled as 2kw seems to be more abundant.
Any reason I’d want to go with the larger body version? I’d rather have a smaller unit that takes less space and is easier to fit.
Thanks! _________________ 84 Westy
1.9TD AAZ
5spd manual with Locking Peloquin TBD |
fxr Samba Member
Joined: December 07, 2014 Posts: 2325 Location: Bay area CA
Posted: Mon Oct 07, 2019 7:33 pm Post subject: Re: Anyone tried these $179 Webasto heater knockoffs? |
Get the 2kW one - you will never need 5kW in a Westy. Just installed mine - works a treat. _________________ Jim Crowther
Vespa GTS 300 |
Posted: Mon Oct 07, 2019 7:47 pm Post subject: Re: Anyone tried these $179 Webasto heater knockoffs? |
Right, but most of the 2kw ones are actually 5kw hearers but fueled down. They use the same actual heater case and chamber. There are very few 2kw heaters that actually use the smaller true 2kw case and burn chamber.
I assume it’s just because it’s cheaper to relabel and adjust the fuel on a 5kw and sell it as a 2kw.
But with there being fewer of the smaller 2kw units, will parts be harder to find if needed? Is there a design reason why they smaller units are not used often? Or does it just come down to ease and expense...? _________________ 84 Westy
1.9TD AAZ
candyman Samba Trout Slayer
Joined: December 20, 2003 Posts: 2694 Location: Missoula MT
Posted: Mon Oct 07, 2019 8:23 pm Post subject: Re: Anyone tried these $179 Webasto heater knockoffs? |
My experience has been its hard to get a true 2kw. Even if its labeled as such, its still likely a 5kw. I got a 5 kw and am totally happy with it. I run it on low with straight kerosene and never an issue of sooting. Got well over 200 hours on it. It does get real toasty for sure, just open some windows and the poptop vents and screens and you will be fine. Unless its really cold like below freezing, we rarely sleep with it on. This weekend we camped and slept with it on overnight in 20 degree weather. My wife slept down below with the kids and i slept up top. We did not open any windows and for me up top I was great with a big down bag. When I climbed down in the morning, the temp gauge read 76* degrees in the bus. Of course that is just down below as the heat does not cycle up top. So pretty toasty for a 20 degree morning. If the windows were open it probably would have been 67* or so |
Posted: Tue Oct 08, 2019 6:06 am Post subject: Re: Anyone tried these $179 Webasto heater knockoffs? |
for a few hundred dollars in our multi thousand dollar rigs,
there's no point in being cold, damp or chilly.
I do highly recommend a Aux battery as part of a standard Auxillary heater install. |
vwhammer Samba Member
Joined: May 20, 2006 Posts: 998 Location: Boulder CO.
Posted: Tue Oct 08, 2019 6:28 am Post subject: Re: Anyone tried these $179 Webasto heater knockoffs? |
From my experience, I thought the 5kw were actually the larger 8kw sized units tuned down a bit.
My 2kw unit is much smaller than my 8kw unit and I have seen other people with 5kw versions that are the same size as the 8kw but not 2kw that were that size.
I probably already posted this in this thread somewhere but since the size think came up I figured I would post it again.
here is the size difference between my 8kw and my 2kw.
I suppose it is possible that they are detuning the 5kw to get 2kw but if you pay attention to the specs in the ad (if there is any) you can look for the smaller body and it is likely just a 2kw unit. |
Posted: Tue Oct 08, 2019 8:12 am Post subject: Re: Anyone tried these $179 Webasto heater knockoffs? |
if anyone wants a spare fuel pump i have a couple of the chinese knockoffs i tried to run with my webasto - which didnt work. the pumps themselves work fine but the webasto was picky about fuel flow at startup. _________________ MegaSquirt resource - SpitfireEFI.com
Posted: Tue Oct 08, 2019 8:37 am Post subject: Re: Anyone tried these $179 Webasto heater knockoffs? |
what I am curious about is the controller or the altitude kits..
I live at ~800ft, but on occasion travel to the Mtns over 6,000ft..
so I'd certainly want to be able to adjust it to work then.. would be a bad time to find it not working..
but there is sooo much chatter out there that I don't know what is the right route for high altitude preparedness.
anyone with personal experience care to share the look/design/number of the controller they use at altitude?
thanks. |
Posted: Tue Oct 08, 2019 8:50 am Post subject: Re: Anyone tried these $179 Webasto heater knockoffs? |
From researching, it looks like you can enter the password protected settings and adjust the fuel flow rate. So you can dial it down for high altitude.
It also looks like most of the new controllers have a mountain setting for high altitude. But I do not know that this setting actually changes anything. _________________ 84 Westy
1.9TD AAZ
Posted: Tue Oct 08, 2019 8:54 am Post subject: Re: Anyone tried these $179 Webasto heater knockoffs? |
In terms of size, most of the 2kw specs show the 39 cm long unit that is 14 cm by 15 cm wide / tall.
There are a few of the 2kw units that show 34 cm long and 11 cm x 11 cm wide / tall.
What are the dimensions of your 8kw and 5kw heaters? If there are accessible to measure. _________________ 84 Westy
1.9TD AAZ
Posted: Tue Oct 08, 2019 9:39 am Post subject: Re: Anyone tried these $179 Webasto heater knockoffs? |
danfromsyr wrote: |
thanks. |
I bought the blue LCD controller from ebay for like $24 shipped with red remote control. Anyways, it supposedly self compensates for altitude on its own. It has an altitude measurement in meters on one of the screens. It also allows you to set up the settings for best performance. This is well documented on the FB group. So i live at 3200ft and regularly camp at 6k+ and so far have not had any issues nor have I had to make any adjustments other than the stock settings listed on FB. 10k ft may be a different story, Ron Chandler can chime in here as it sounds like he regularly camps at that altitude. But this particular controller is supposed to compensate for altitude provided the settings are set up correctly. Hope this helps |
tristessa Samba Member
Joined: April 07, 2004 Posts: 3992 Location: Portland, OR
Posted: Tue Oct 08, 2019 11:56 am Post subject: Re: Anyone tried these $179 Webasto heater knockoffs? |
People on the FB group have looked into it, and the consensus is that there are no 8KW units. They're 5KW heaters where someone in the supply chain has used some very optimistic calculations and some "Chinese Math" fudge-factoring to come up with a number around 8KW to use for marketing.
There seem to be more true 2KW units on the market right now than there were last winter/spring, but they're still not easy to find. Check dimensions before ordering, and if they ship the larger 5KW unit in place of what you thought you were getting based on what they'd put on their listing file a dispute. You might get a free 5KW out of it... |
Syncro Jael Samba Member
Posted: Tue Oct 08, 2019 12:20 pm Post subject: Re: Anyone tried these $179 Webasto heater knockoffs? |
danfromsyr wrote: |
thanks. |
I have mine set at pmin 1.3, pmax 4.8 - rpmmin=1450, rpmmax 4500
This setting works great from 4,800 ft to 10,000ft. I have camped at 10k ft numerous times with no issues. If in doubt I can run the rpmmin up a couple hundred to force more air in.
I have just ordered an Afterburner controller from Austrailia. This product will enhance the capabilities of tuning and monitoring these heaters. _________________ 1987 Syncro Westfalia Hightop - NAHT
Subaru EJ25 Forged Frankenmotor, Triple Knob.
Jael = (Mountain Goat) |
vanagonjr Samba Member
Joined: October 07, 2010 Posts: 3431 Location: Dartmouth, Mass.
Posted: Tue Oct 08, 2019 6:14 pm Post subject: Re: Anyone tried these $179 Webasto heater knockoffs? |
It may degrade rubber seals and fuel line. _________________ 84 Westy
1.9TD AAZ
