danfromsyr Samba Member
Posted: Tue Oct 27, 2020 10:38 am Post subject: Re: The official Chinese Diesel Heater thread (Webasto Knockoff) |
and here's an interesting intake filter/muffler. looks promising for underneath installs. the cheap cylindrical ones mesh is really a joke for keeping anything out of the units intake.. esp bugs/spiders
https://www.ebay.com/itm/25mm-Diesel-Heater-Air-In...4882744290
vanis13 Samba Member
Joined: August 15, 2010 Posts: 3097 Location: ABQ NM USA.... Except when not
for the discrete install location. this is where mine has resided happily for years now.
HEY! some of my images are missing too!
_________________ 83.5 Westy with Subaru 2.5, 4 spd manual, center seat, COLD A/C on 134a!, Winter camp heated with an Espar B4 gasoline furnace
www.SuperVanagon.com - some stuff I make |
zoti Samba Member
Joined: December 26, 2007 Posts: 2061 Location: Plano, TX USA
Posted: Tue Oct 27, 2020 3:55 pm Post subject: Re: The official Chinese Diesel Heater thread (Webasto Knockoff) |
SSWesty wrote: |
Zoti, nice job selecting heavy gage wire for your batteries. You may have already covered the positive terminals but if not it's a best practice to cover them so they are not exposed. The cabinet you mention for the heater seems like a good spot to give up some space, it's definitely a hands and knees type cabinet if you need to get something from the back out of it. |
I'm not finished with the install. Got a couple of extra wires to run. Then everything will get covered and boxed including the heater so I can make use of the rest of the area under the rear seat. |
beach_creature Samba Member
Posted: Tue Oct 27, 2020 6:42 pm Post subject: Re: The official Chinese Diesel Heater thread (Webasto Knockoff) |
Great find! I just ordered one. _________________ 84 Westy
1.9TD AAZ
5spd manual with Locking Peloquin TBD |
zoti Samba Member
Posted: Wed Oct 28, 2020 3:04 pm Post subject: Re: The official Chinese Diesel Heater thread (Webasto Knockoff) |
I decided to mount directly to the floor using the mounting plate that came with the heater.
I cut some of the subfloor then placed the metal plate as a template. Marked and drilled. That was the best location but I will need to shield the exhaust as it will run between the rear hand brake cable to the driver side wheel and the line to the slave clutch cylinder. I will need to protect them both from heat.
What do people use for that?
Test fit upside down just to figure out the location.
And installed in the new cut holes. The air inlet will fit under the ECU and I plan to enclose it all in a box to protect the heater and prevent anything from blocking the airflow.
The hot air will come out just under the latch that opens the rear seat area.
And I will make a vent that will let air in through the old heater vent.
kguarnotta Samba Member
Joined: April 01, 2004 Posts: 1160 Location: Woodstock, NH
Posted: Thu Oct 29, 2020 5:43 am Post subject: Re: The official Chinese Diesel Heater thread (Webasto Knockoff) |
hey zoti - nice pics.
I see the hole appears to be cut on the 2nd rib from the rear. I think I already have a hole in that area from something a previous owner had (maybe a water tank).
Do youh ave any pics from below - ie how is the clearance below? _________________ -Kevin
Lincoln, MA
'86 Triple Knob Syncro w/EJ22
'78 Westy
'69 Single Cab
'65 Kombi - EZ-Camper |
zoti Samba Member
Posted: Thu Oct 29, 2020 9:03 am Post subject: Re: The official Chinese Diesel Heater thread (Webasto Knockoff) |
kguarnotta wrote: |
Do youh ave any pics from below - ie how is the clearance below? |
I cut it right over the hole that was there for the wiring of the rear heater.
I didn’t take a picture from below. The handbrake cable and clutch line run there but with proper insulation of the exhaust it should be ok. |
zoti Samba Member
Posted: Fri Oct 30, 2020 12:36 am Post subject: Re: The official Chinese Diesel Heater thread (Webasto Knockoff) |
More progress today. Made another plate that will go under then floor and installed the hot air outlet.
If it will be nice weather tomorrow then I will work under the van.
zoti Samba Member
Posted: Fri Oct 30, 2020 11:13 pm Post subject: Re: The official Chinese Diesel Heater thread (Webasto Knockoff) |
It’s not bolted yet but I did wire most of it and tested that it gets power and turns on.
I’m thinking of installing the pump inside some sort of a weather protected box as it is going to be outside by my diesel tank.
I bought a 3 gal tank that will fit between the frame rails under the sliding door and will be held in place by a bracket.
I will then be able to pull the tank out and lay it on the ground for refill.
Posted: Sat Oct 31, 2020 4:18 am Post subject: Re: The official Chinese Diesel Heater thread (Webasto Knockoff) |
Looks like a nice solution - and nice install.
Is that the afterburner controller? Or the one that came with your unit? _________________ -Kevin
Lincoln, MA
'78 Westy
'69 Single Cab
zoti Samba Member
Posted: Sat Oct 31, 2020 8:19 am Post subject: Re: The official Chinese Diesel Heater thread (Webasto Knockoff) |
kguarnotta wrote: |
Is that the afterburner controller? Or the one that came with your unit? |
Just the one that came with it. |
KentABQ Samba Member
Joined: September 11, 2016 Posts: 2406 Location: Albuquerque NM
Posted: Sat Oct 31, 2020 8:32 am Post subject: Re: The official Chinese Diesel Heater thread (Webasto Knockoff) |
I installed a new Diesel Heater last summer (excellent timing, no?)
And I was living in Florida at the time, so I only tested it in short periods, and it worked great.
However, now that I'm in New Mexico, I've been using it more often. The problem is that it started blowing white smoke out the exhaust, and then would shut off and not restart.
In researching this phenomenon online, it was revealed the white smoke is caused by incomplete combustion, which causes carbon soot build up in the combustion chamber.
So I removed the unit completely, disassembled it and found a huge amount of soot in the chamber. So it got cleaned out well using brushes and carb cleaner.
Reinstalled it and it ran great again! Hooorah! But that was short lived... it's back to blowing huge amounts of white smoke again.
As for causes of the incomplete combustion, I figured either there was an obstruction in the air inlet, or in the exhaust hose or muffler. They both proved to be clear.
So I bought a second heater, thinking maybe there was a defect in the heater.
But the new one has the same problem.
Can anyone give me pointers in what else could be causing this problem?
I love the dry heat when it works, but don't want to disassemble and clean it out after each use.
BTW, I understand the unit has to be run at it's highest setting for about 15 minutes in order to burn out the carbon. I've tried that a couple times, and it didn't eliminate the problem.
Any help would be greatly appreciated!
Here is where the heater is installed:
I rebuilt the cabinet to fit over it, allowing for good air inlet on the passenger side and heated air to blow out into the walk-thru area.
(The carpet has since been replaced with vinyl flooring.)
_________________ -Kent-
1976 Riviera, 1.8l FI chrome yellow VAN - "Chloe"
"I must say, how can you be in a bad mood driving this vehicle full of vibrant color.
Cars of today are so bland in comparison. It's like driving a celebration!" ---WildIdea
Bus ownership via emoticons:
---williamM |
zoti Samba Member
Posted: Sat Oct 31, 2020 10:34 am Post subject: Re: The official Chinese Diesel Heater thread (Webasto Knockoff) |
Check your intake under the car to make sure it is not blocked. Sometimes animals will crawl into it.
KentABQ wrote: |
Posted: Sat Oct 31, 2020 10:43 am Post subject: Re: The official Chinese Diesel Heater thread (Webasto Knockoff) |
zoti wrote: |
Check your intake under the car to make sure it is not blocked. Sometimes animals will crawl into it. |
Thanks!
Yup, I checked both the intake and exhaust to make sure they're not blocked, and also not too long. I understand 6' is the longest exhaust, and mine is only 2'.
I'm open to all ideas and suggestions.
It's frustrating not having it work correctly when it performs so well for so many others. _________________ -Kent-
---williamM |
fxr Samba Member
Joined: December 07, 2014 Posts: 2325 Location: Bay area CA
Posted: Sat Oct 31, 2020 12:44 pm Post subject: Re: The official Chinese Diesel Heater thread (Webasto Knockoff) |
KentABQ wrote: |
zoti wrote: |
Thanks!
It's frustrating not having it work correctly when it performs so well for so many others. |
What are your max and min pump Hz and fan rpm?
_________________ Jim Crowther
Vespa GTS 300 |
Posted: Sat Oct 31, 2020 6:10 pm Post subject: Re: The official Chinese Diesel Heater thread (Webasto Knockoff) |
are you sure you are stopping the CDH fuel priming (manual pump) cycle.
it'll FLOOD the unit if you leave it on full on..
review a few of these and see if that may be why BOTH units you are starting with have the same odd problem.
https://www.google.com/search?q=chinese+diesel+heater+priming |
rmcd Samba Member
Joined: October 29, 2010 Posts: 1349 Location: PNW - its a dry rain.
Posted: Sat Oct 31, 2020 9:59 pm Post subject: Re: The official Chinese Diesel Heater thread (Webasto Knockoff) |
I recall my instructions indicated that the intake had to be similar length as the exhaust. Maybe something to check? _________________ VW LT40 build. Like a Vanagon but 30% larger in every direction and 40% slower even in metric.
https://www.thesamba.com/vw/forum/viewtopic.php?t=749359&highlight= |
zoti Samba Member
Posted: Sun Nov 01, 2020 12:20 pm Post subject: Re: The official Chinese Diesel Heater thread (Webasto Knockoff) |
Working on a vent cover to replace the original now that the heater core is gone.
Got so close with my first attempt. Oh well. Making another one.
zoti Samba Member
Posted: Sun Nov 01, 2020 1:32 pm Post subject: Re: The official Chinese Diesel Heater thread (Webasto Knockoff) |
Finished. Pretty proud of myself.
peteymedic Samba Member
Posted: Sun Nov 01, 2020 3:09 pm Post subject: Re: The official Chinese Diesel Heater thread (Webasto Knockoff) |
Zoti: That's a really great grill! Nice job!
An Amazon reviewer of these Chinese heaters found using kerosene instead of diesel cured the carbon build up issue. Cleaner fuel for a more complete combustion. _________________ 91 Vanagon Westy Camper
“If we do not hang together, we shall surely hang separately.”
- Thomas Paine |
