yel-mel Samba Member
Joined: May 07, 2015 Posts: 421 Location: Tampa Florida
Posted: Fri Jul 20, 2018 6:11 am Post subject: Rear fender removal |
Quick question :
I need to remove my rear fenders to do some mild bodywork on the apron.
Can I get them off with the engine in place. Just not sure if there is a nut on the reverse side that I would need to reach/ and hold from the engine compartment. I have a non stock engine that takes up most of the space.
Any advice greatly appreciated....Thanks |
Canadian VW Samba Member
Joined: August 24, 2007 Posts: 220 Location: Ontario Canada
Posted: Fri Jul 20, 2018 6:21 am Post subject: Re: Rear fender removal |
All the bolts are inside the fender, none from the engine compartment. There will be one between the running board and fender as well. _________________ Instagram: patrick_macpherson
Samba 67 Beetle build thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=607949&highlight= |
catahoula lou Samba Member
Joined: August 30, 2008 Posts: 594 Location: south of Silver Springs, NV
Posted: Fri Jul 20, 2018 6:33 am Post subject: Re: Rear fender removal |
To prevent damage from dropping the fender remove the bolt at the top last...reverse process when you install...
Best,
Thom _________________ 1 great wife
2 Catahoula Leopard Dogs (Mahogany Star and Spartan) - RIP Lucy, Braveheart, & Dusty!
1 1959 mango green Ragtop Bug (the "Mango")
1 1958 pantina red Lowlight Ghia (the "Chili Pepper")
Still looking for:
(1) My Dad's 1955 356 (he raced it amateur-class at Riverside and other courses during 1950s),
(2) My parent's black 1955 hardtop bug (CA license plate FWC 201 or FWG 201), and
(3) My parent's agave green 1957 ragtop bug (CA license plate LFK 734). |
Posted: Fri Jul 20, 2018 6:44 am Post subject: Re: Rear fender removal |
Thanks to both of you guys for the info !
I have a rust area on the apron only about 1/2 inch from the fender bead. It would be to hard to work on that close.... with fender I place. |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24759 Location: Olympia Wash Rinse & Repeat
Posted: Fri Jul 20, 2018 10:41 am Post subject: Re: Rear fender removal |
Add a bit of grease to the bolt threads as you take them out. So when you put it back together the threads will be much less rusted together next time you need to pull that all apart. _________________ In Stereo, Where Available! |
Posted: Fri Jul 20, 2018 11:42 am Post subject: Re: Rear fender removal |
Good idea Eric&barb………...thanks |
