Turd Furgusson Samba Member
Posted: Fri Jul 20, 2018 9:23 am Post subject: Loud drilled rotors |
Has anyone tried these rotors: https://www.jbugs.com/product/22-3853-B.html?gclid...q0QAvD_BwE
And notice how loud they are? Not the squealing, but like a hissing
sound when you hit the brakes? I put them on new with the recommended
semi metallic pads. Will the sound die down some? |
Eskamobob1 Samba Member
Joined: August 08, 2016 Posts: 541 Location: South OC SoCal
Posted: Fri Jul 20, 2018 9:28 am Post subject: Re: Loud drilled rotors |
I haven't tried those specifically, but even when installing with the anti-squeal grease on the back of the pads brand new rotors often squeal for a little bit. Have you set the pads yet? Often a real world heat cycle will help quite a bit with the sound. _________________ '74 - front disks/lots more work to do |
Posted: Fri Jul 20, 2018 9:49 am Post subject: Re: Loud drilled rotors |
They don’t squeal...it’s a hissing sanding noise...I used the disc brake grease on the back of the pads. |
Joined: August 31, 2013 Posts: 12858 Location: North Carolina
Posted: Fri Jul 20, 2018 10:22 am Post subject: Re: Loud drilled rotors |
Umm, that's what they're gonna do. You just bought cheese graters for your brake pads.
The cross drilling/fire slotting not only gives the gasses that build up between the pad & rotor upon extreme braking somewhere to go but they also give the brake pad a fresh surface with each pass. Hopefully they put enough forethought into the drilling pattern so that you don't end up with parts of the pad that don't get "cleaned", this will leave you with high & low spots on the pads & decreased braking ability. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
sawed off Samba Member
Joined: September 15, 2016 Posts: 428 Location: Idaho
Posted: Fri Jul 20, 2018 10:46 am Post subject: Re: Loud drilled rotors |
Yes sound should die down some after break in. Semi metalic are rough until seated |
kangaboy Samba Member
Joined: August 28, 2010 Posts: 1063 Location: St. Louis, Mo
Posted: Fri Jul 20, 2018 12:05 pm Post subject: Re: Loud drilled rotors |
I have drilled rotors as well...and they never quiet down. I have put a few thousand miles on mine and they are as loud as they day I put them on. I wish I would have known this prior to purchase, because I'm at the point of shopping for standard rotors to replace the drilled ones. So annoying. _________________ -74 Standard - "CaliBug" 2084T, MS3X w/FI and Crank Fire
-76 Westy - "Gandalf"
-18 GTI SE
skills@eurocarsplus wrote: |
that fucking thing looks like it drove through a J.C. Whitney catalogue and hit everything on the way out |
Posted: Fri Jul 20, 2018 1:20 pm Post subject: Re: Loud drilled rotors |
kangaboy wrote: |
I have drilled rotors as well...and they never quiet down. I have put a few thousand miles on mine and they are as loud as they day I put them on. I wish I would have known this prior to purchase, because I'm at the point of shopping for standard rotors to replace the drilled ones. So annoying. |
Did you use semi metallic pads? |
Posted: Fri Jul 20, 2018 1:25 pm Post subject: Re: Loud drilled rotors |
TDCTDI wrote: |
The cross drilling/fire slotting not only gives the gasses that build up between the pad & rotor upon extreme braking somewhere to go but they also give the brake pad a fresh surface with each pass. Hopefully they put enough forethought into the drilling pattern so that you don't end up with parts of the pad that don't get "cleaned", this will leave you with high & low spots on the pads & decreased braking ability. |
I’m pretty sure half of what you said isn’t correct, but thanks for
sharing. |
Posted: Fri Jul 20, 2018 7:02 pm Post subject: Re: Loud drilled rotors |
Turd Furgusson wrote: |
kangaboy wrote: |
I'm not sure, mine came in a kit with my Wilwood Calipers. I can look at them tomorrow and reply. _________________ -74 Standard - "CaliBug" 2084T, MS3X w/FI and Crank Fire
-18 GTI SE
Epilog79 Samba Member
Joined: June 04, 2009 Posts: 218 Location: Tigard,Oregon
Posted: Fri Jul 20, 2018 9:56 pm Post subject: Re: Loud drilled rotors |
I have the Topline drilled and slotted rotors and they also make that hissing sound under braking. As you say it is annoying. It’s has been 3 years since I switched to these and the sound has not gone away. Oh well, not going to change now, maybe in the future.
slalombuggy Samba Member
Posted: Fri Jul 20, 2018 10:35 pm Post subject: Re: Loud drilled rotors |
TDCTDI wrote: |
sharing. |
Nope. Everything he said is correct. I've put drilled rotors on all sorts of cars with all kinds of pads. Buy a bigger stereo cause they're gonna be noisy for life. They also eat pads faster and usually the rotors are also grooved up after a set of pads are done. 911 C4s destroyed their brakes, when they were done they were DONE.
brad
brad |
Posted: Sat Jul 21, 2018 4:16 am Post subject: Re: Loud drilled rotors |
TDCTDI wrote: |
sharing. |
Yeah, the part where they had enough forethought to actually design the pattern to clean all parts of the pad equally when in all probability they just tossed the rotors in the CNC & let it rip.
In one of the above pics you can see that the cross drilling in that rotor at least appears to have chamfered edges to decrease the cheese grater effect but you can also see that the swept area of the pad reaches beyond the cross drilling/slotting, this will lead to areas on the brake pad that will be higher that the parts that don’t get cleaned/ground off. These high points will now be the the first to make contact with the rotor & do most of the braking leaving you with far less contact surface area causing decreased braking performance and grooves in the rotors.
And in this pic that the other person posted...
You can already see the phenomenon of which I speak by the darker lines starting at the edges of the cross drilling, this is where the rotor is getting hotter due to an incorrect pattern. The wear/localized overheating would be worse if not for the fire slotting.
Another thing that the chamfering does is that it reduces the tendency of stress cracking in the rotor (especially on a cast iron rotor), but most crappy cross drilled rotors don’t experience this because they’re not used on the track in the extreme conditions that would warrant the actual use of cross drilling & fire/gas slotting. Basically, unless you actually drive the car to it’s limits & have to brake repeatedly to the point of brake fade, you’re just installing these for looks. _________________ Everybody born before 1975 has a story, good, bad, or indifferent, about a VW.
volksworld Samba Member
Joined: November 26, 2011 Posts: 2529 Location: formerly NY currently NC
Posted: Sun Jul 22, 2018 7:51 am Post subject: Re: Loud drilled rotors |
the last time i worked for a nascar cup team they had stopped drilling rotors and were only putting the slots in them....and the slots extend all the way to the edge of the rotor or the gasses and dust would be trapped |
