Murdlem Samba Member
Joined: February 06, 2004 Posts: 512 Location: Port Angeles, Washington
Posted: Fri Jul 20, 2018 2:38 pm Post subject: 1300 sp motor questions |
In preparing for getting my engine running, I came across a few things that I was not familiar with. Car is a 66 1300 sp, and supposedly, still 6v.
This is attached to the intake manifold.
And there is this little guy connected to the coil.
_________________ Eric Meldrum
68 Ghia
Check out my blog. https://vwlifenet.wordpress.com/ |
Mark Evans Samba Member
Joined: April 21, 2004 Posts: 1931 Location: Alsea,Oregon
Posted: Fri Jul 20, 2018 2:56 pm Post subject: Re: 1300 sp motor questions |
I believe the second item is a noise suppressor. _________________ '63 Ragtop |
Helfen Samba Member
Joined: January 19, 2009 Posts: 3450 Location: Vulcania
Posted: Fri Jul 20, 2018 3:00 pm Post subject: Re: 1300 sp motor questions |
First is part of a aftermarket EGR smog devise. Second is a coil noise suppressor. |
Helfen Samba Member
Posted: Fri Jul 20, 2018 3:01 pm Post subject: Re: 1300 sp motor questions |
First is part of a aftermarket EGR devise. Second is a coil noise suppressor. |
Posted: Fri Jul 20, 2018 3:27 pm Post subject: Re: 1300 sp motor questions |
As for the smog device, should I just leave it there? What impact will it have on how the motor runs? _________________ Eric Meldrum
68 Ghia
Joined: April 27, 2002 Posts: 6371 Location: Pentwater, Michigan
Posted: Fri Jul 20, 2018 3:45 pm Post subject: Re: 1300 sp motor questions |
It would be nice if that condenser reduced engine noise . It's to supress radio static due to current discharge from the coil, generator etc. _________________ Roads Scholar &
1961 (October)Single Cab- Road Trip Workhorse |
Posted: Fri Jul 20, 2018 4:12 pm Post subject: Re: 1300 sp motor questions |
Well, on that note, what might these have been used for...
68 Ghia
mukluk Samba Member
Posted: Fri Jul 20, 2018 4:22 pm Post subject: Re: 1300 sp motor questions |
Murdlem wrote: |
Power for the radio normally comes off that fuse, the pair of condensers are for electrical noise suppression. _________________ 1960 Ragtop w/Semaphores "Inga" |
vwoldbug Samba Member
Posted: Fri Jul 20, 2018 6:11 pm Post subject: Re: 1300 sp motor questions |
I believe they have to be grounded . Also the fuse box & wire ends need work . |
Posted: Sun Jul 22, 2018 12:22 pm Post subject: Re: 1300 sp motor questions |
The noise suppression usually came as a kit with multiple condensers. Typical locations for condensers would be coil, generator, radio. Grounding helps but is not a requirement, best if the condenser (resistor) isn't wiggling around loose. . _________________ Roads Scholar &
