thomast Samba Member
Posted: Sat Jul 21, 2018 5:32 am Post subject: 1600cc Motor Rebuild - Single vs Duel Carbs - What to do??? |
Hello - I'm a longtime Samba member and longtime Vanagon owner. My son and I just got a 1970 bus. The motor had a Kardon (??) duel carb setup on it when we got it. The engine is currently being rebuilt by my trusted shop here in Minneapolis (Further Performance). We are trying to decide if we should go back to a single carb or stay with the duel carb setup. I've heard good and bad about both setups, so thought I might get some valuable info here.
This will be my 17 year old sons bus. He'll be driving it around Minneapolis mostly with some road trips out to Colorado and up to northern Minnesota planned for the future. He's pretty good mechanically in general, but we'd like the best setup for him that will be the easiest to maintain, but also give good performance. Maybe you can't have both??
Any advise would be very much appreciated as we get this bus ready to drive!
Thanks!
Thomas |
Manfred58sc Samba Member
Posted: Sat Jul 21, 2018 5:56 am Post subject: Re: 1600cc Motor Rebuild - Duel Carb vs Single - What to do??? |
Kadrons ( real ones ) are good carburetors. If they are worn get 'em re-worked by the Kaddy Shack. The extra HP is nice to have on trips. If it were just local driving I would go with a single carburetor. _________________ Fat chick owner/operator |
Davada66 Samba Member
Posted: Sat Jul 21, 2018 7:48 am Post subject: Re: 1600cc Motor Rebuild - Duel Carb vs Single - What to do??? |
Do your self a favor and have the motor built up to a 1776cc you wont have to do any thing to the lower end just have the case opened up for larger piston jugs. uses the same 69mm crank. You will get 75 horse power out of that motor. I used a Weber 40 mm center mounted carburetor much simpler system don't have to balance the carb like duel carbs. It will make a large difference on how you can drive the bus. Also add a oil sump, at least a one quart if not a two quart. Don't forget to make sure you use a high ZDDP oil, like Amsoil Z-Rod or Brad Penn, The Green Oil both made for flat tappet cam engines. |
telford dorr Samba Member
Joined: March 11, 2009 Posts: 3555 Location: San Diego (Encinitas)
Posted: Sat Jul 21, 2018 9:25 am Post subject: Re: 1600cc Motor Rebuild - Duel Carb vs Single - What to do??? |
It depends on what you're going to use the engine for - summer cruse, or all season travel. Unlike the stock carb, Kadrons have no chokes, which will make winter starting and warmup more interesting. Might be an issue in Minneapolis... _________________ '71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST) |
borninabus Samba R&D Dept.
Joined: May 18, 2006 Posts: 4539 Location: Arizona Highways
Posted: Sat Jul 21, 2018 9:46 am Post subject: Re: 1600cc Motor Rebuild - Duel Carb vs Single - What to do??? |
improved breathing--intake and exhaust--is pretty much the best (and easiest) engine upgrade you can do for your bus. if your having it fully rebuilt, consider a mild cam like an Engle 100 or similar.
the key to kadrons is to have them rebushed and buy the CSP linkage _________________ 88 Van WBX, A/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport |
Ry-dog Samba Member
Joined: May 31, 2003 Posts: 452 Location: Lunenburg, MA
Posted: Sat Jul 21, 2018 11:01 am Post subject: Re: 1600cc Motor Rebuild - Duel Carb vs Single - What to do??? |
I have a 70 Westy myself and had gone back and forth over whether I wanted to go to duals or stay with a stock single carb. Since I live in the northeast with cooler temps besides summer, I chose to go with a restored german stock single carb. Stayed with stock exhaust as well so the whole preheat system, thermostat, flaps, etc. all work as originally designed. Also, I figured it is always a good piece of mind to be able to follow the Bentley for any issues that come up on the road, etc if everything is stock. It might be a better starting point for a 17 year old driver who might be learning about ACVWs for the first time (assuming that is the case here). After a better understanding of the system, you can always bring the duals back at another time if you wanted. _________________ '70 Westy
'14 Jeep Grand Cherokee EcoDiesel |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16971 Location: San Diego, California
Posted: Sat Jul 21, 2018 11:46 am Post subject: Re: 1600cc Motor Rebuild - Duel Carb vs Single - What to do??? |
Stay stock with carb and distributor. You’ll gain in smooth running and reliability. Easy maintenance. You’ll suffer a small amount of power but in my opinion it’s worth it. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Brian Samba Moderator
Posted: Sat Jul 21, 2018 12:47 pm Post subject: Re: 1600cc Motor Rebuild - Duel Carb vs Single - What to do??? |
Kads are cool when they're setup right, but that takes some more in depth knowledge that I just flat out ignore.
I'm with Gary, stay stock have him learn on that first. Crawl, walk then run. Or walk don't run _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
AlmostHeavenWV_VW Samba Member
Posted: Sat Jul 21, 2018 1:06 pm Post subject: Re: 1600cc Motor Rebuild - Duel Carb vs Single - What to do??? |
thomast wrote: |
Hello
For general easy, reliability I vote single carb.
Stock for simplicity and learning how to wrench on the bus and tuning.
Go up to a single Weber for a little extra 'get up and go' once he's cut his teeth on the stock single carb for a while.
I honestly believe stock set ups are the best to learn on (lots of literature, manuals, and write ups) then step up to a 'performance upgrade' once the basics are learned with the stock equipment. _________________ 1973 Standard Beetle
1600DP AK case
Solex 34PICT3 Carb
Bosch DVDA 205AJ Distributor |
TomWesty Samba Member
Joined: November 23, 2007 Posts: 3482 Location: Wyoming,USA
Posted: Sat Jul 21, 2018 8:36 pm Post subject: Re: 1600cc Motor Rebuild - Duel Carb vs Single - What to do??? |
Dual Kaddies are dead simple to adjust and synch. If he can adjust a 34 PICT 3 he can adjust Kaddies. They are way better than any non stock center mount carb due to shorter intake runners. The down side for us cold weather types is the warm up time involved. _________________ If you haven't bled on them, you haven't worked on them.
Visit: www.tomcoryell.com and check out my music! |
Posted: Mon Jul 23, 2018 5:52 am Post subject: Re: 1600cc Motor Rebuild - Single vs Duel Carbs - What to do??? |
Thanks everyone for the great info! I think we will be staying stock for now with a single carb and as my son gets more comfortable with it, he can tinker with mods down the road.
Have a great day all!
Thomas |
SGKent Samba Member
Posted: Mon Jul 23, 2018 7:19 am Post subject: Re: 1600cc Motor Rebuild - Single vs Duel Carbs - What to do??? |
thomast wrote: |
Thomas |
FWIW - VW detuned their bus engines on purpose. You'll find dual carb higher performance carbs on some their lighter car that use the type 1 case and heads. You'll also find them on the stronger type 4 cases on buses. The type 1 engine in a bus lasts a lot longer in stock form than set up for higher power. Its very easy to make more power with a bus type 1 engine but the payback is also reduced reliability, and longevity. I base that statement on a 1971 bus that was in my stable for 460,000 miles. The miles that were stock were the most pleasurable - although it was nice to have extra power. Just got tired of breaking things or wearing them out quicker because of that power. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Mon Jul 23, 2018 11:21 am Post subject: Re: 1600cc Motor Rebuild - Single vs Duel Carbs - What to do??? |
thomast wrote: |
Thomas |
I've learned a thing or two over the years. One of those things is that having a real Solex carb that's been rebuilt by Tim at Volkzbitz is worth every penny. Find out which exact carb fits your year bus and get Tim to sell you one of his.
Next, match that stock carb to the stock distributor. Not just a SVDA but the correct SVDA.
Here's the link you need
http://www.type2.com/~keen/ignition.html
Then, when you get the correct part number distributor, make sure it actually works like it should. This guy can help.
https://www.thesamba.com/vw/classifieds/detail.php?id=2196277
or this guy
https://www.thesamba.com/vw/classifieds/detail.php?id=2188024
Link for Tim at Volkzbitz
http://www.volkzbitz.com/ _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW Jetta
VW Passat
Amskeptic Samba Member
Joined: October 18, 2002 Posts: 8568 Location: All Across The Country
Posted: Mon Jul 23, 2018 7:44 pm Post subject: Re: 1600cc Motor Rebuild - Single vs Duel Carbs - What to do??? |
SGKent wrote: |
The type 1 engine in a bus lasts a lot longer in stock form than set up for higher power. Its very easy to make more power with a bus type 1 engine but the payback is also reduced reliability, and longevity. |
^ this ^
Colin _________________ www.itinerant-air-cooled.com |
airschooled Air-Schooled
Joined: April 04, 2012 Posts: 12727 Location: on a bike ride somewhere
Posted: Mon Jul 23, 2018 11:25 pm Post subject: Re: 1600cc Motor Rebuild - Single vs Duel Carbs - What to do??? |
thomast wrote: |
Hello -
This will be my 17 year old sons bus. He'll be driving it around Minneapolis mostly with some road trips out to Colorado…easiest to maintain, but also give good performance…??
My Stock bus, well-tuned, driving from Chicago to Minneapolis:
Yes, the speedometer is correct. I put massive rear tires on to give the "gearing down" effect of a freeway flyer transmission. The head temperatures were NOT impressed, (425+°f) and I netted about 14mpg with that setup.
When I had the stock tires on in May, I was lamenting to some kind folks in Breckenridge about how I had to slow down up the Colorado mountain passes. At that moment I realized I still was utilizing my "seal level" tune. Had I followed John Muir's advice for bumping up the timing 4-5° when crossing the Rockies, I would have shut up.
Tune it, drive it, enjoy it. In that order.
www.airschooled.com |
