Booky Samba Member
Posted: Sun Jul 22, 2018 9:56 am Post subject: Re: Brakes make no sense |
I will take some pictures.How did I order parts I went with early 60 to order parts this is on a Sandrail.One question was were they resurfaced there is all new parts from master to drums all parts are new. |
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9966 Location: Huntington Beach, CA
Posted: Sun Jul 22, 2018 9:57 am Post subject: Re: Brakes make no sense |
mcmscott wrote: |
What is the diameter of the drums? If the drums have been machined the arch in the shoe will not match the drums and flex as you apply them untill they wear to the same arch of the drum. Back in the day, you used to bring your new brake shoes with the drums so the shoes could be re-arched to match the drums. They no longer do this as the sanding of the shoes blew asbestos everywhere. |
I had to rearch several sets from suppliers. They never came in arched correctly. However, most times just taking the car for a test drive, brake shoe break-in, was often enough to get the interaction correct. _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Posted: Sun Jul 22, 2018 10:19 am Post subject: Re: Brakes make no sense |
Booky wrote: |
Please do. I sure several people on here can identify the parts by the pictures.
Did the new parts, match the old parts, or were they not exactly the same?
Did you keep the old parts? _________________ Jimbo
TDCTDI wrote: |
Booky Samba Member
Posted: Sun Jul 22, 2018 2:58 pm Post subject: Re: Brakes make no sense |
I checked the star adjusters 3 of them were wrong way.Also have a picture of the brake.
modok Samba Member
Joined: October 30, 2009 Posts: 26788 Location: Colorado Springs
Posted: Sun Jul 22, 2018 3:11 pm Post subject: Re: Brakes make no sense |
Booky wrote: |
I went with early 60 to order parts this is on a Sandrail. |
What year of brake shoes did you order? 1960 would be wrong shoes, the adjusters were not angled so there was no way to put them on backward. |
Booky Samba Member
Posted: Sun Jul 22, 2018 3:49 pm Post subject: Re: Brakes make no sense |
I don’t remember what shoes they are it’s been a while back that I bought them.But the adjusters were angaled so I switched them won’t be able to test drive till Wednesday. |
modok Samba Member
Posted: Sun Jul 22, 2018 6:00 pm Post subject: Re: Brakes make no sense |
it looks right, but I can't really see enough in the picture to tell for sure
Note these backing plates have six raised pads the edge of the shoe sits on
These can use wide groove cylinders and adjusters
this is an older backing plate, it only has two pads to guide the shoe, so it needs early pads and narrow slot adjusters and cylinders which are NLA, OR replaced with a later backing plate
Your brake shoes have a part number, so you can google that and see what they fit. |
