alansvwTwinCab Samba Member
Joined: December 28, 2005 Posts: 164 Location: Sydney, Australia
Posted: Tue Jul 10, 2018 4:15 am Post subject: Tips on connecting Brake fluid lined to bottle |
I'm trying to fit a new dual circuit brake Fluid bottle but having no luck getting the hoses on. Ive tried a light smear of grease, heating the hoses with hair dryer but not working. Any tips? |
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20379 Location: Just a tiny bit west of Yosemite Valley
Posted: Tue Jul 10, 2018 5:40 am Post subject: Re: Tips on connecting Brake fluid lined to bottle |
Sounds like barbs on brake fluid reservoir are just to big for size of tubing you are trying to put on... Tubing will only stretch so far before it just is not going to happen....
Cusser Samba Member
Joined: October 02, 2006 Posts: 31373 Location: Hot Arizona
Posted: Tue Jul 10, 2018 6:32 am Post subject: Re: Tips on connecting Brake fluid lined to bottle |
alansvwTwinCab wrote: |
Someone - it will be me this time - wants to know if you're using the special type and size of brake fluid line here. Fuel line will not hold up here, dangerous. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
raygreenwood Samba Member
Joined: November 24, 2008 Posts: 21518 Location: Oklahoma City
Posted: Tue Jul 10, 2018 7:46 am Post subject: Re: Tips on connecting Brake fluid lined to bottle |
Cusser wrote: |
Someone - it will be me this time - wants to know if you're using the special type and size of brake fluid line here. Fuel line will not hold up here, dangerous. |
Yes....spot on. The ONLY rubber hoses you can use with brake fluid are EPDM.....usually color coded blue.
The brake fluid will eat any fuel line short of teflon.
AND.....just as important.....when you do get the correct EPDM hose....you CAN NOT use ANY petroleum based grease or oils on it. You can only use PURE silicone based oils or greases or brake hydraulic assembly lubes.
EPDM....stands up to glycol ether and silicone based brake fluids.....but cannot work with any petroleum/VOC based chemicals
Ray |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Tue Jul 10, 2018 8:21 am Post subject: Re: Tips on connecting Brake fluid lined to bottle |
raygreenwood wrote: |
Yes....spot on. The ONLY rubber hoses you can use with brake fluid are EPDM.....usually color coded blue. |
except you can't go by the color anymore, blue is being phased out.
https://www.jbugs.com/product/N203501.html _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
Posted: Tue Jul 10, 2018 10:17 am Post subject: Re: Tips on connecting Brake fluid lined to bottle |
60ragtop wrote: |
https://www.jbugs.com/product/N203501.html |
Thats what I have been hearing....so sad nothing is that simple anymore. But....as long as its EPDM....it will be fine and at least you can buy that in many places.
Ray |
Posted: Sat Jul 14, 2018 4:17 am Post subject: Re: Tips on connecting Brake fluid lined to bottle |
I should have seen the problem.. the New bottle has larger sized barbs ,I'll just go get one with smaller barbs and problem solved.
busman78 Samba Member
Joined: August 17, 2004 Posts: 4522 Location: Oklahoma City, OK
Posted: Sat Jul 14, 2018 4:36 am Post subject: Re: Tips on connecting Brake fluid lined to bottle |
The one with the wrong fittings, were the holding tabs for the screws in the right location? |
Posted: Sat Jul 14, 2018 7:04 pm Post subject: Re: Tips on connecting Brake fluid lined to bottle |
The original is the bottom one , replacement with angled barbs on top. |
Posted: Sun Jul 15, 2018 6:21 am Post subject: Re: Tips on connecting Brake fluid lined to bottle |
On the replacement I think you will find the tabs are in the wrong location at least one of them is. Not sure what that reservoir is for, maybe a Wabbit or Dasher, maybe an Audi 100 (spit) but about ten years ago that style reservoir showed up and was sold as a bug replacement, amazing they are still around and being sold for bugs, I have one well had one, trash can ate it. |
Cusser Samba Member
Posted: Mon Jul 23, 2018 4:35 am Post subject: Re: Tips on connecting Brake fluid lined to bottle |
sorted out hose problem, got a new bottle with smaller barbs.
