Mr. Oldskool Samba Member
Posted: Sun Jul 22, 2018 3:43 am Post subject: flywheel seal leakage |
Ok, what am I doing wrong here:
I put the first 200miles on the karmann and every time I stop somewhere there was a puddle of oil under the car.
I took the engine out this morning - because I'm leaving on holliday tomorrow and this couldn't wait 2 weeks, altho my girlfriend seems to think otherwise -
the leakage is coming from the flywheel seal, but here's the strange part: the seal is brand new and still looks brand new. the (lightened) flywheel is also brand new and shows no signs of wear what so ever...
what I did discover is when I put the seal over the flywheel (without puthing it in the engine) there is little or no resistance between the flywheel and the seal. is this normal?
it's the seal with single lip and the flywheel is a lightened one.
thank you
glauco |
Dale M. Samba Member
Posted: Sun Jul 22, 2018 6:10 am Post subject: Re: flywheel seal leakage |
Possibly flywheel is machined to small in area where seal rides?... It only takes a few thousands of a inch (mm) to allow oil to escape by...
Cusser Samba Member
Joined: October 02, 2006 Posts: 31379 Location: Hot Arizona
Posted: Sun Jul 22, 2018 8:32 am Post subject: Re: flywheel seal leakage |
I just rebuilt my 1600cc engine 1.5 years ago, new oil seal. But it did leak at the flywheel seal, a spring had come loose, see picture.
I installed a new seal and O-ring, now no leak. _________________ 1970 VW (owned since 1972) and 1971 VW Convertible (owned since 1976), second owner of each. The '71 now has the 1835 engine, swapped from the '70. Second owner of each. 1988 Mazda B2200 truck, 1998 Frontier, 2014 Yukon, 2004 Frontier King Cab. All manual transmission except for the Yukon. http://www.thesamba.com/vw/forum/album_page.php?pic_id=335294 http://www.thesamba.com/vw/forum/album_page.php?pic_id=335297 |
Mr.Oldskool Samba Member
Joined: November 04, 2012 Posts: 24 Location: Belgium
Posted: Sun Jul 22, 2018 8:40 am Post subject: Re: flywheel seal leakage |
Cusser wrote: |
I installed a new seal and O-ring, now no leak. |
That's what I thought at first, but the spring was still in place. My guess is Dale M. said that the diameter of the flywheel is machined just a tiny bit on the small side... not yet sure how I'm going to deal with that, I'll have to measure the diameter of the flywheel... |
AlteWagen Troll
Posted: Sun Jul 22, 2018 9:13 am Post subject: Re: flywheel seal leakage |
AlteWagen wrote: |
The secret to flywheel (and axle) seals is the spring. Find the ends of the springs and reset them a little tighter. |
I didn't know that! Thank you! I'm going to order a new one because I don't want to reinstall this one, it still looks like new but I don't want to risk it. |
chrisflstf Samba Member
Joined: February 10, 2004 Posts: 3446 Location: San Diego
Posted: Sun Jul 22, 2018 9:21 am Post subject: Re: flywheel seal leakage |
Quote: |
Possibly flywheel is machined to small in area where seal rides? |
Flywheels dont get machined in that area. No one makes over sized seals. If it was, you need a different flywheel
The depth of the seal in the case can cause leaks, depending on how far in the case it was set |
Posted: Sun Jul 22, 2018 9:53 am Post subject: Re: flywheel seal leakage |
chrisflstf wrote: |
I placed the seal all the way in, it was level with the case, I don't think I can place it any deeper, I would need to check... |
gt1953 Samba Member
Posted: Sun Jul 22, 2018 10:13 am Post subject: Re: flywheel seal leakage |
I went and replaced three seals and then duh looked at the groove worn in the flywheel....replaced fly wheel leak gone! _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
VW_Jimbo Samba Member
Joined: May 22, 2016 Posts: 9967 Location: Huntington Beach, CA
Posted: Sun Jul 22, 2018 10:25 am Post subject: Re: flywheel seal leakage |
Many times when cars drove into the shop leaking oil at the flywheel seal, after a customer self build, we would find that the drain hole was blocked full of sealant.
You may need to clear that drain hole, they get plugged very easily. _________________ Jimbo
TDCTDI wrote: |
67rustavenger wrote: |
GFY's Xevin and VW_Jimbo! |
Posted: Sun Jul 22, 2018 10:27 am Post subject: Re: flywheel seal leakage |
gt1953 wrote: |
I went and replaced three seals and then duh looked at the groove worn in the flywheel....replaced fly wheel leak gone! |
Flywheel is brand new.. |
Posted: Sun Jul 22, 2018 11:00 am Post subject: Re: flywheel seal leakage |
Mr.Oldskool wrote: |
gt1953 wrote: |
In today's parts market that is scarrything....
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Sun Jul 22, 2018 11:35 am Post subject: Re: flywheel seal leakage |
You did install the oring on the flywheel? _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
Posted: Sun Jul 22, 2018 11:51 am Post subject: Re: flywheel seal leakage |
Is the new flywheel a new aftermarket flywheel or is the new flywheel a new ( as if you just bought it ) german flywheel?
Seal needs to be installed straight and even. There can be no issues with the area the seal rides on the flywheel. Must be glass like smooth.
Lip of seal needs oiled after replacement, before motor is run or the lips will burn
Excess crank end play can causes leaks also |
74 Thing Samba Member
Posted: Sun Jul 22, 2018 11:56 am Post subject: Re: flywheel seal leakage |
The seal actually goes a little deeper than flush with the case. Are you using a seal tool to install?
Also, are you sure it is not the tranny? I had a leak at the case/tranny mating surface after a clutch disc failure and I thought it was the flywheel seal. It turned out to be the transmission input shaft seal. |
Posted: Sun Jul 22, 2018 5:58 pm Post subject: Re: flywheel seal leakage |
60ragtop wrote: |
You did install the oring on the flywheel? |
Yes, o-ring was installed |
satterley_sr Samba Member
Joined: March 31, 2005 Posts: 650 Location: Belleville,MI
Posted: Mon Jul 23, 2018 8:52 am Post subject: Re: flywheel seal leakage |
I just had an issue with a new Chinese flywheel. Tried new seals, new o rings, sealant on face. Solution was an original German stock flywheel. _________________ DDC racing |
Joined: August 15, 2002 Posts: 4394 Location: Brew City
Posted: Mon Jul 23, 2018 11:00 am Post subject: Re: flywheel seal leakage |
The problem is most likely the flywheel BUT you may be able to fix it. I have found that using a brand new flywheel with a German case that doesn't have the oil return below the seal can cause a leak AFTER the engine is shut off. The problem is that the o-ring groove is cut too deep in the flywheel so it doesn't squeeze the o-ring tight enough around the crank.
IF this is the case, you can either replace the flywheel with a German one OR use permatex between the crank and flywheel. _________________ Please "LIKE" us on facebook to see what we are working on.
https://www.facebook.com/mofoco?ref=ts&fref=ts
www.mofoco.com
Cylinder Head Reference Sheet |
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10773 Location: iT StiNgeD iTseLf tO dEAd
Posted: Mon Jul 23, 2018 11:42 am Post subject: Re: flywheel seal leakage |
chrisflstf wrote: |
Flywheels dont get machined in that area. If it was, you need a different flywheel
inaccurate. that surface can be machined, and quite a bit, before you'd have sealing issues.
read this thread: https://www.thesamba.com/vw/forum/viewtopic.php?t=696222 _________________ thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
thebucket: Yeah Haze, its where people put money into a company in hopes of a return on their money |
Posted: Mon Aug 20, 2018 5:37 am Post subject: Re: flywheel seal leakage |
for those who were wondering, it turned out to be the primairy shaft seal that whas leaking...
replaced both the seals (primary shaft and flywheel seal) and so far no leakages any more...
glauco |
