MidWesty79 Samba Member
Joined: October 19, 2011 Posts: 485 Location: Milwaukee Wisconsin, US
Posted: Sun Jul 22, 2018 10:52 am Post subject: Low compression... |
Hey all, i’m starting a 3 month voyage to Alaska. Departed WI last week and I’m doing some tune up work at a family member’s place in WY. I did a quick compression test while changing plugs and noticed my #3 cylinder is at 77psi, the rest were around 92. The engine wasn’t super warmed up, but I did let it idle a few minutes before testing.
I rebuilt the engine about 5 years/40k miles ago including rebuild heads from Adrian at Headflow masters with bigger valves and Heavy Duty Stainless Steel valves. It had a sunk valve prior to the rebuild.
I checked the valve adjustment (hydraulic) and didn’t see anything crazy.
My question is, is the valve sunk again? I have about 10-12k miles ahead of me.
Thanks!
Nick _________________ 1979 Westfalia, 1975 BMW 2002, 1996 Mazda Miata, 1979 Jeep CJ5, 2006 325 XI Wagon, 2021 M240i (all manual transmission... as god intended.) |
busdaddy Samba Member
Joined: February 12, 2004 Posts: 51154 Location: Surrey B.C. Canada, but thinking of Ukraine
Posted: Sun Jul 22, 2018 11:02 am Post subject: Re: Low compression... |
Time to pull the rockers and put a straightedge across all the valve tips.
only 9' lbs torque on the rocker shaft nuts when you put them back _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
Posted: Sun Jul 22, 2018 11:21 am Post subject: Re: Low compression... |
Just checked with a straight edge. I didn’t use a feeler gauge or anything, but they appear to be dead level. _________________ 1979 Westfalia, 1975 BMW 2002, 1996 Mazda Miata, 1979 Jeep CJ5, 2006 325 XI Wagon, 2021 M240i (all manual transmission... as god intended.) |
Posted: Sun Jul 22, 2018 11:30 am Post subject: Re: Low compression... |
Smallest feeler I have with me is .006”. I couldn’t get close to getting it under the straight edge at any valve. _________________ 1979 Westfalia, 1975 BMW 2002, 1996 Mazda Miata, 1979 Jeep CJ5, 2006 325 XI Wagon, 2021 M240i (all manual transmission... as god intended.) |
SGKent Samba Member
Posted: Sun Jul 22, 2018 11:46 am Post subject: Re: Low compression... |
Your best bet at this point is to put a leak down tester on it and see where the compression is going. _________________ “Most people don’t know what they’re doing, and a lot of them are really good at it.” - George Carlin |
Posted: Sun Jul 22, 2018 12:15 pm Post subject: Re: Low compression... |
Fed the cylinder 30-40 psi. No air out of the exhaust or intake. Breather had a fair bit of air rushing out. Rings are going I suppose. Anyone have any “magic elixer” recommendations?! _________________ 1979 Westfalia, 1975 BMW 2002, 1996 Mazda Miata, 1979 Jeep CJ5, 2006 325 XI Wagon, 2021 M240i (all manual transmission... as god intended.) |
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22728 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Sun Jul 22, 2018 12:26 pm Post subject: Re: Low compression... |
MidWesty79 wrote: |
Fed the cylinder 30-40 psi. No air out of the exhaust or intake. Breather had a fair bit of air rushing out. Rings are going I suppose. Anyone have any “magic elixer” recommendations?! |
Fix it or this won't end well. Sorry. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
Posted: Sun Jul 22, 2018 12:59 pm Post subject: Re: Low compression... |
Considering that you are likely around 7000' above sea level your number are not that bad. I would at least try adding a full quart of upper cylinder wall lubricant to your fuel for a few tankfuls, MMO, Sea Foam, 2-cycle oil, or synthetic motor oil.
According to the Vanagon Bentley 85 psi is normal at seal level for a 2.0L aircooled engine and 73 psi is minimum while the max difference between cylinders is 44 psi. You are way better than that.
Heading out onto a three month trip would make me a bit more concerned though.
Corrected for a 7000' elevation your number would look more like this
Compression for three cylinders: 114 psi
Compression on one cylinder: 95 psi
Difference between cylinders: 19 psi
A synthetic oil will keep your engine cleaner inside than a dino oil.
When doing an compression test, you need:
A well charged battery
All plugs removed
Throttle held open |
Tcash Samba Member
Posted: Sun Jul 22, 2018 1:12 pm Post subject: Re: Low compression... |
Could be stuck rings.
Might be worth putting a couple of table spoons of Marvels Mystery or Trans fluid down the spark plug hole, turn the engine over a couple of times wo/strarting to spread it and let it soak over night.
With the spark plug out, crank the engine a few times to clear the cylinder. Install the plug, fire it up and bring it up to operating temp, then excel hard and use engine braking to decal hard to brake the rings free.
Good luck
Tcash |
Posted: Sun Jul 22, 2018 2:09 pm Post subject: Re: Low compression... |
I only had one plug out at a time, and didn’t Have the throttle open. I was mainly looking for big differences, not so much the actual numbers, but that would likely throw off the actual values.
I’m at about 6400 ft of elevation.
I always run Rotella 15w 40. I was told years ago on the samba that it was a good choice. Not sure if that wisdom still holds true. I change it every 2k miles.
I’ll try some seafoam in the tank and MMO down the plug hole, see if that gets me anywhere. _________________ 1979 Westfalia, 1975 BMW 2002, 1996 Mazda Miata, 1979 Jeep CJ5, 2006 325 XI Wagon, 2021 M240i (all manual transmission... as god intended.) |
SGKent Samba Member
Posted: Sun Jul 22, 2018 2:26 pm Post subject: Re: Low compression... |
makes the differences too variable to be meaningfull
Altitude Correction
500 0.987
1000 0.971
1500 0.960
2000 0.943
2500 0.933
3000 0.915
3500 0.907
4000 0.888
4500 0.880
5000 0.862
5500 0.853
6000 0.836
6500 0.826
7500 0.800
8500 0.773
92 minus 15% = 78.2 so Mike is correct, 77 is not far off. Do check the chart above. 92 at 5000 feet is 92/0.862 = 106
If you think you have an issue then generally 10% - 15% is max allowable between cylinders. Since it is not the valves, that is good. You can try to DRIZZLE a glass water into the air inlet while holding the warm engine at a fast idle. Don't let it die and don't pour after if it dies. Fans and belts bite. That may knock any carbon loose. If the oil is dirty when you are done change it. GM will have an top engine / upper cylinder cleaner that you can spray into the plenum and let the bus sit 1 hour. It will stink and smoke up the neighborhood so do it on a windy day or out in the country. I wouldn't get it on the rubber so you might have to spray it into the throttle body thru the area where the brake booster attaches, You could also use the egr inlet on under the plenum if it is not plugged up with carbon which most are. where the CSV is would work too but those are hard to take off in the car. Acura/Honda used the GM stuff to uncaptured rings, (trust me it really works). They used a hose from the plenum into a can. You can do that too.
Posted: Sun Jul 22, 2018 2:44 pm Post subject: Re: Low compression... |
MidWesty79 wrote: |
I’ll try some seafoam in the tank and MMO down the plug hole, see if that gets me anywhere. |
I think your numbers will look pretty good if you do the test correctly. |
Posted: Sun Jul 22, 2018 3:57 pm Post subject: Re: Low compression... |
I shot a bit of MMO down the plug and let it sit about an hour. I then drove the bus around, revved her up pretty good a few times and checked the compression again, this time with all the plugs out and the throttle open. I got 80psi on #3 right around 100 in the other 3.
I’m going to shoot some more MMO down the #3 and let it sit overnight. Take another look in the morning I guess. _________________ 1979 Westfalia, 1975 BMW 2002, 1996 Mazda Miata, 1979 Jeep CJ5, 2006 325 XI Wagon, 2021 M240i (all manual transmission... as god intended.) |
Posted: Sun Jul 22, 2018 4:01 pm Post subject: Re: Low compression... |
Bryan67 wrote: |
Tcash Samba Member
Posted: Sun Jul 22, 2018 5:16 pm Post subject: Re: Low compression... |
Good luck
Tcash |
aeromech Samba Member
Joined: January 24, 2006 Posts: 16971 Location: San Diego, California
Posted: Sun Jul 22, 2018 6:30 pm Post subject: Re: Low compression... |
Two things.
1). You’re betting a lot considering your destination is Alaska. Best to try another gauge to be sure.
2). Whatever happens be sure to make an adult decision and if you need to abort the trip and cut your losses then do it. _________________ Lead Mechanic: San Diego Air and Space Museum
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Davada66 Samba Member
Posted: Mon Jul 23, 2018 8:28 pm Post subject: Re: Low compression... |
I would delay that trip. The compression reading should be around 135 to 140. |
airschooled Air-Schooled
Posted: Mon Jul 23, 2018 11:13 pm Post subject: Re: Low compression... |
Davada66 wrote: |
Really? Bentley explicitely tells us a 2L Type 4 engine's Wear Limit is 71psi, and is allowed 28psi difference between the four cylinders. MidWesty79's compression results are within those specs.
I honestly say, if the engine has been reliable for a few thousand miles, and has NOT changed more than an hour in routine valve adjustments, go for it.
Just finished a lap of the country with a low compression engine,
www.airschooled.com |
Posted: Tue Jul 24, 2018 1:16 am Post subject: Re: Low compression... |
15 year +/- ago I asked a question on Shoptalkforums.com and was advised that I should rebuild my engine before I drove out my driveway again. I ignored the advise and only got another 100K miles out of the engine. Should I have ignored the advise and canceled my family's trip to Mexico or not?
Jamb it down into third, put your foot to the floor, and enjoy life. You only get one time around. The best advise I every got in life was to buy a junker when you are planning an extensive trip so you will not have to worry about taking a major financial loss should you have a break down and have to abandon your ride. |
Posted: Tue Jul 24, 2018 1:33 am Post subject: Re: Low compression... |
Wildthings wrote: |
Jamb it down into third, put your foot to the floor, and enjoy life.. |
Hell yeah!!
Tune it, drive it, enjoy it. (In that order.)
As a frequent visitor of Adrian's shop, I am thinking that the stainless steel valves he's installed on ALL my heads are softer than normal stock VW valves, and this preserves the valve seats metallurgy. I regularly go about 10k miles between adjusting any one particular valve.
I also like all four plugs pulled and the throttle floored for comparative compression test numbers.Otherwise your numbers are yours, but can't be reliably compared to others, just like oil temp numbers from non-consistent sensor locations.
