bugguy1967 Samba Member
Joined: January 16, 2008 Posts: 4343 Location: Los Angeles, CA 90016
Posted: Sun Jul 22, 2018 1:47 pm Post subject: Sync-Link w/Space Savers |
Can a Sync-Link work with IDFs on reverse CB Space Saver manifolds? _________________ "A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine" |
I Ride Sand Samba Member
Posted: Sun Jul 22, 2018 1:53 pm Post subject: Re: Sync-Link w/Space Savers |
yep. the cables dont care how close the carbs are, the housings flex to accomodate. _________________ Just a dirty coyote playing in the desert.
now where'd that dirty badger run off to? |
mcmscott Samba Member
Joined: March 12, 2010 Posts: 4857 Location: sanger ca
Posted: Sun Jul 22, 2018 3:43 pm Post subject: Re: Sync-Link w/Space Savers |
I did a set with the cables behind the shroud, i'll see if I can find pics. _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
Posted: Sun Jul 22, 2018 3:45 pm Post subject: Re: Sync-Link w/Space Savers |
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
Chip Samba Member
Posted: Sun Jul 22, 2018 9:33 pm Post subject: Re: Sync-Link w/Space Savers |
Is that a freeze plug in the distributor hole? Pretty slick! |
Posted: Sun Jul 22, 2018 9:35 pm Post subject: Re: Sync-Link w/Space Savers |
Oh! Your brackets have a wider pattern than mine. My brackets bolt to the two studs that are on the enrichment circuit side. So they'd have to be against the firewall. _________________ "A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine" |
Bashr52 Samba Member
Joined: July 16, 2006 Posts: 5666 Location: On an island in VA
Posted: Mon Jul 23, 2018 5:21 am Post subject: Re: Sync-Link w/Space Savers |
How did you get access to install them like that, and how do you adjust? Or is that not super critical with an FI system? |
67 Sunroof Samba Member
Joined: February 22, 2014 Posts: 1836 Location: Salisbury, MD
Posted: Mon Jul 23, 2018 5:30 am Post subject: Re: Sync-Link w/Space Savers |
Damn, I like that setup!! Not much there!? Super simple and makes you wonder how it even runs! |
hobbybob517 Samba Member
Joined: June 02, 2011 Posts: 1194 Location: Netherlands
Posted: Mon Jul 23, 2018 8:59 am Post subject: Re: Sync-Link w/Space Savers |
verry clean! but how did you install it? _________________ THE BUILD http://www.thesamba.com/vw/forum/viewtopic.php
SBD wrote: |
3 million rpm? Well there's your problem! No wonder it blew up! |
Posted: Mon Jul 23, 2018 12:00 pm Post subject: Re: Sync-Link w/Space Savers |
The brackets mount to the outside bolts, now inside. You can see them in the pics. It was a pain in the ass to set up. The cables run thru notches in the dog house tin. The motor is a 2332, wedgeport, crank triggered. The coil pack is mounted on top of the trans. Ecu is CB gen 4. The car is a 54 convertible. _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
Posted: Mon Jul 23, 2018 12:16 pm Post subject: Re: Sync-Link w/Space Savers |
Amazing job! _________________ THE BUILD http://www.thesamba.com/vw/forum/viewtopic.php
SBD wrote: |
Posted: Mon Jul 23, 2018 12:24 pm Post subject: Re: Sync-Link w/Space Savers |
hobbybob517 wrote: |
Amazing job! |
Thank you! One of his other cars is in this months hot vw. _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
calvinater Samba Member
Joined: September 06, 2014 Posts: 3330 Location: 802 The Pointless Forrest
Posted: Mon Jul 23, 2018 12:37 pm Post subject: Re: Sync-Link w/Space Savers |
The type 34 ? _________________ "Albatross"! |
Posted: Mon Jul 23, 2018 12:45 pm Post subject: Re: Sync-Link w/Space Savers |
calvinater wrote: |
The type 34 ? |
Yes _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
Posted: Mon Jul 23, 2018 1:05 pm Post subject: Re: Sync-Link w/Space Savers |
So are those wide brackets for sale through Sync-Link? Does anything need notching if I just run them out back instead of hidden, as intended? _________________ "A petrol engine can start readily, run smoothly and give every appearance of being in good order, without necessarily being in good tune." - Colin Campbell, "The Sportscar Engine" |
Posted: Mon Jul 23, 2018 1:10 pm Post subject: Re: Sync-Link w/Space Savers |
bugguy1967 wrote: |
So are those wide brackets for sale through Sync-Link? Does anything need notching if I just run them out back instead of hidden, as intended? |
I have an extra set of the wide brackets if you want them _________________ There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250 |
timvr6 Samba Member
Posted: Thu Apr 08, 2021 10:40 am Post subject: Re: Sync-Link w/Space Savers |
mcmscott wrote: |
bugguy1967 wrote: |
I have an extra set of the wide brackets if you want them |
I know this is an old thread, but do you have any pix of the wide brackets. I'm attempting this type of install now on my 67. |
