cease Samba Member
Joined: October 20, 2008 Posts: 2 Location: l.a. county
Posted: Sun Jul 22, 2018 3:56 pm Post subject: emergency brake cable |
hello all,
need help understanding the route the e-cable runs through. i fish the cable from the rear lower pan into the hump. i cant locate the screw end inside the hump where the e-brake lever goes.
i see 2 tube that run up towards the heater knob. is the cable running inside that tube?
need help
Cease |
RareAir Samba Member
Joined: May 11, 2002 Posts: 14576 Location: 18 miles North of the border
Posted: Sun Jul 22, 2018 9:18 pm Post subject: Re: emergency brake cable |
Once the cable is fully inserted into the frame horn, you shouldn’t have a problem locating the threaded end of the cable.
Did you remove the e-brake handle from the pan? You’ll clearly see the cable if the handle is removed. It will also make attaching the cable to the handle easier _________________ 1947 Typ 11a
1954 Typ 117
1956 Typ 151
1959 Typ 117
1959 Typ 265
1961 356B
1966 Typ 151
1966 Typ 241 |
nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3783 Location: Twin Cities, MN
cease Samba Member
Posted: Wed Mar 06, 2019 4:49 pm Post subject: Re: emergency brake cable |
thanks for the replies. now im searching for the HARD to find brake rod |
tisius Samba Member
Joined: July 11, 2011 Posts: 1570 Location: Rotterdam,NL (+Chicago,IL)
Posted: Thu Mar 07, 2019 3:12 am Post subject: Re: emergency brake cable |
It's between the brake pedal and master cylinder. What did I win?
Do you mean you need to source a "new" one because yours is missing, and the question is where you could get one?
FYI, there were 2 different types, depending on the year of the car.
What model year is your car? _________________ drive it like you just robbed the bank
.... if it ain't dutch, it ain't much! |
