docdanracy Samba Member
Joined: June 26, 2012 Posts: 1118 Location: Auburn, CA
Posted: Sun Jul 22, 2018 7:17 pm Post subject: Vintage speed exhaust...anyone using them and impressions |
As title states please
Thanks
Doc _________________ Doc
1970 Sunroof Bug Yukon Yellow (L19K)
Custom 6.5x15” 914 Sport Wheels wrapped in 185x65x15 Contis
Empi shifter, full compliment of gauges, 1679 with mild cam, stock induction
SOLD: 1974 Marina Blue Standard Beetle undergoing restoration/preservation
1679 with Kadrons and header/QP
914 sport wheels 5.5" ET40 wrapped in 195x65x15 Kumhos |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 9772 Location: Oregon
Posted: Sun Jul 22, 2018 8:08 pm Post subject: Re: Vintage speed exhaust...anyone using them and impressions |
A couple of friends of mine have them on their cars.
One is a type3. The other is a type 1 40HP.
The 40HP has a great sound. Kinda a low rumble. I think of a Harley when I hear it run.
The type 3, Has a higher pitched sound to it. But not much higher than the type 1. One thing that happened to the T3. One of the O2 sensor plugs fell out of the muffler. The VS exhausts come with two O2 sensor bungs installed.
Engine tuning with a wideband is difficult with a VS exhaust system. You get inaccurate readings on the sensor. Because your really only sampling one side of the engine. Rather than all 4 cylinders. Like when the O2 sensor bung is installed in a 4 into 1 header collector.
I hope this is helpful.
Good Luck.
docdanracy wrote: |
Thanks
Doc |
_________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo! |
beetlenut Samba Member
Posted: Mon Jul 23, 2018 4:41 am Post subject: Re: Vintage speed exhaust...anyone using them and impressions |
I was very impressed with the quality of the muffler even down to the packaging. The fit is very good, and my engine is wider due to the 74mm CW crank. The heat risers bolted up very nicely too. Should have it running in the next few weeks, so can't comment on the sound, but was looking forward to a lower tone, so I think I'll like it. It's expensive, but in this case you get what you pay for.
_________________ scrapyards are for quitters
Wetstuff wrote: |
... I spend more time shaking it than directing it?! I get a pretty decent blast for 8sec. then have to shake it again. |
- Words to live by right there!
My 74 Super rebuild thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=6507104#6507104 |
Lingwendil Samba Member
Joined: February 25, 2009 Posts: 3988 Location: Antioch, California, a block from the hood
Posted: Mon Jul 23, 2018 6:56 am Post subject: Re: Vintage speed exhaust...anyone using them and impressions |
I put one on my 1600 with dual Kadrons, I was tired of ugly headers and mufflers that hung under the car, and wanted a more stock-ish look. I pulled off the old header and quiet pack setup, and bolted it on. I really like it, deeper burble sort of sound, that is actually pretty quiet at idle, but has a satisfying deep tone under heavy acceleration or at higher RPM. I was afraid it might be too loud on the freeway, but it actually has a nicer tone than the quiet pack, so it's actually much more pleasant.
Fit was perfect, and adjustment range was great. Came with all gaskets, and perfectly serviceable hardware for installation.
Looks good.
No noticeable loss of performance from a "real" header type system for me.
Sounds good.
Excellent ground clearance!
Only downside is the price. Highly recommended. _________________ 73 super beetle thread http://www.thesamba.com/vw/forum/viewtopic.php?t=649622 Back on the Road!
Modify your Kadrons for SVDA http://www.thesamba.com/vw/forum/viewtopic.php?p=8115884#8115884
Cast iron VJU4BR8 SVDA reference thread- https://www.thesamba.com/vw/forum/viewtopic.php?t=...mp;start=0
Need replacement filters for original Kadron aircleaners? WIX #42087 is a perfect fit, as is Napa Gold #2087! |
Posted: Mon Jul 23, 2018 9:13 am Post subject: Re: Vintage speed exhaust...anyone using them and impressions |
Thanks guys
Good info
With heat exchangers you have to buy adapters to go from stock heat exchangers to flanges on the muffler? _________________ Doc
Posted: Mon Jul 23, 2018 10:03 am Post subject: Re: Vintage speed exhaust...anyone using them and impressions |
Thanks guys
Good info
Posted: Mon Jul 23, 2018 11:31 am Post subject: Re: Vintage speed exhaust...anyone using them and impressions |
docdanracy wrote: |
Thanks guys
Good info
With heat exchangers you have to buy adapters to go from stock heat exchangers to flanges on the muffler? |
You have to select the preheat primaries option when you order the system, which is $20 dollars more. They're the White items in my picture. They are actually also Stainless Steel covered in a White fiberglass firebraid to reduce the heat on the adjacent fresh air hoses. _________________ scrapyards are for quitters
Wetstuff wrote: |
DanPorges Samba Member
Joined: September 13, 2014 Posts: 119 Location: Natick, MA
Posted: Wed Jul 25, 2018 1:02 pm Post subject: Re: Vintage speed exhaust...anyone using them and impressions |
I really like the Vintage Speed exhaust on my bug. They were the only company that offered a high performance exhaust that works with big-bore motor that is still running heat and has a single outlet option to fit the factory bodywork of a late model Fuel Injected bug. Sounds awesome, much more throaty than stock sound or others I have heard and the build quality is truly top notch. Welds are bordering on art! |
Brian Samba Moderator
mondshine Samba Member
Joined: October 27, 2006 Posts: 2770 Location: The World's Motor Capital
Posted: Wed Jul 25, 2018 2:52 pm Post subject: Re: Vintage speed exhaust...anyone using them and impressions |
I have a VS muffler on my '74 Thing.
It's big, ugly, and too loud...but it's the best option available to me.
(The last NOS stock '74 thing exhaust went for well over a grand; I actually met the guy that bought it!
Anyway, the build quality looks good, and fitment was easy.
I should have had it Jet Hot coated black before it was installed just to make it less visible. Maybe I will do that over the Winter.
I highly recommend the CSP hoses for the heat exchangers.
I used the regular VW wide band clamps on the lower ends.
