Peter T. Samba Member
Joined: October 09, 2006 Posts: 259 Location: Long Island, New York
Posted: Mon Jul 23, 2018 6:33 am Post subject: Electrical issues |
I have a zwitter that I restored 25 years ago. I cleaned, restored and replaced every electrical component including the wiring harness. When I turn on the headlights there is a voltage drop that effects the wipers and semaphores. I've had it checked out by a few mechanics and I ended up rebuilding the generator which helped a little. I also checked the voltage at the headlight switch and fuses and it all checks out 5.5 volts or better.
Any thoughts? |
AndrewCologne Samba Member
Joined: September 05, 2015 Posts: 71 Location: Cologne
Posted: Mon Jul 23, 2018 6:45 am Post subject: Re: Electrical issues |
Did you check all terminals/contacts?
Also ... when you restored your car so many years ago, .. did you solder all ends of the wires? If yes then this can be the guilty one as solder becomes soft during the years and you will get into problems with bad connections. _________________ 1950 Split Window Grey
1955 Oval Window Stratosilber
1982 Porsche 911 3.0 SC Black |
Posted: Mon Jul 23, 2018 7:02 am Post subject: Re: Electrical issues |
This has been a total mystery. I had two vw mechanics check it out.
I didn't solder the ends, but I'm thinking maybe the new harness could be the problem. One mechanic told me to try to find NOS headlight bulb holders and new bulbs. |
Suboval Samba Member
Posted: Mon Jul 23, 2018 7:59 am Post subject: Re: Electrical issues |
Are you running your windshield wipers and semaphores with the engine running or off?
If off, try it with the engine running. Normal voltage should be ~6.4 VDC.
The fuse block and headlight switch could both be affecting the wipers and semaphores.
Solder the connections on the back of the fuse block to ensure no high resistance.
Headlight switches can also have high resistance. Take it apart and clean the contacts and re-grease. _________________ It all works on paper.
There's two things we learn from history:
1.) History repeats itself.
2.) We don't learn from history. |
ZENVWDRIVER Samba Member
Joined: November 07, 2008 Posts: 3340 Location: N.E. Oklahoma
Posted: Mon Jul 23, 2018 12:02 pm Post subject: Re: Electrical issues |
Peter T. wrote: |
Any thoughts? |
I guess what I would do is isolate everything and test... pull all the fuses. So, all that works are the headlights... maybe even isolate one headlight and test each one separately and then together
I got new bulbs at Bughaus.com
What happened when you race the engine, while use the accessories? Any difference _________________ 5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK |
Posted: Mon Jul 23, 2018 1:42 pm Post subject: Re: Electrical issues |
Totally appreciate the input. I'll give ideas a more thoroough try. I've already gone through the headlight switch and the fuseboxes and found no resistance. I also run the motor with these issues still there. If I rev the motor over 2200rpms it helps. Still haven't thoroughly checked bulbs and bulb holders. |
0nebadbug Samba Member
Joined: October 01, 2009 Posts: 1087 Location: Rockford, Illinois
Posted: Thu Jul 26, 2018 7:26 am Post subject: Re: Electrical issues |
AndrewCologne wrote: |
did you solder all ends of the wires? If yes then this can be the guilty one as solder becomes soft during the years |
Not trying to derail the thread at hand but.. I'm not sure about the validity of solder being used at a connection & then causing current loss...
Every early VW I've ever owned (though never owned a split) I have always tinned wire connection ends (always using silver solder) as well as using or re-using factory style brass (?) wire leads (which were originally soldered in as well) and from either of those methods I have never ever had any of them "soften" and be a cause of a current leach, ever...
So just sort of wondering why tinning wire connection ends would be a cause of current draw... _________________ ::: Slowoval ::: LaDawri Sebring ::: '61 Creampuff ::: Dust Storm '66 ::: |
johnshenry Samba Member
Joined: September 21, 2001 Posts: 9364 Location: Northwood, NH USA
Posted: Thu Jul 26, 2018 7:42 am Post subject: Re: Electrical issues |
0nebadbug wrote: |
So just sort of wondering why tinning wire connection ends would be a cause of current draw... |
Bare copper will corrode over time and turn green. This green film does not pass current well and may create a voltage drop. That is one of the reasons for tinning. As someone also pointed out, as there are no spring properties with solder, over time, with vibration, etc, these connections can become loose. I was just about to pull a slow/intermittent cranking starter in my '57 when I wen around with a screwdriver and tightened all of the connections behind the dash and voila! Fixed. That should be the first step in troubleshooting any electrical problem on a screw term car. _________________ John Henry
'57 Deluxe
'56 Single Cab |
Zwitterkafer Samba Member
Joined: November 17, 2007 Posts: 879 Location: Lanark County, Ontario, Canada
Posted: Thu Jul 26, 2018 3:25 pm Post subject: Re: Electrical issues |
X2 ^^
Checking tightness of all screw terminals and quality of wire ends should be an annual "Service" item on all screw terminal cars. The solder itself is not the problem, they came that way from the factory. Good to avoid acid core solder though, when making repairs....the copper strands inside an insulated wire can oxidize badly but remain undetected. _________________ "Criticism comes easier than Craftsmanship"
- Zeuxius, 400 BC |
vwoldbug Samba Member
Posted: Fri Jul 27, 2018 1:52 am Post subject: Re: Electrical issues |
Do you have a spare voltage regulator you can try . Have you tested the generator by grounding the field wire with wires disconnected with engine running . |
Posted: Fri Jul 27, 2018 8:41 am Post subject: Re: Electrical issues |
Just had the generator rebuilt and regulator tested by a "Bosch" guy, generator is putting out 6.5-7 volts. I have had this issue going back 23 years when the repro harness was new so wire corrosion doesn't seem to be the issue....rusty threads?
I just thought of running a thread tap into anything that is holding something electrical. |
Posted: Fri Jul 27, 2018 9:42 am Post subject: Re: Electrical issues |
I wouldn't be concerned about the screw term thread contact,but you could run a small round file through the bore that the the wire goes through.
If you want to get technical, you can use a volt meter (DC volts) and some clip leads and "hunt down" the voltage drop. I'd start the car, turn on the headlights then measure the voltage right on the battery terminals for reference. Then (you'll need to make one very long clip lead) measure the voltage between the pos term at the battery, and the positive wire terminal at whatever device you are trying to find the drop for, headlight, sem (when on) whatever. In an ideal situation, you'd get 0 volts, no drop. But there is always some.
Now start moving the lead back from the device, toward the battery. Measure from battery + to the next terminal point to that device, probably either a switch or a fuse holder. Keep working your way back toward the battery in the circuit and not the values.
Say you see a 2 volt drop at the sem + terminal (its the lower one, black/white or black/green wire there. Then at the sem switch term you get .4 volts, then at the fuse box you get .2 volts, then at the big red wire term on the back of the headlight switch (I think, I don't know Zwitters wiring as well as I know split dashes) you get .1 volts.
That would tell you that most of the drop is 1.6 volts lost between the sem switch and the sem. So suspect either the wire or term connections. Clean the term connections, if that drop is still there, then it is the wire. Verify it by using your really long clip lead and "jumper out" the sem wiring, clip right on the sem switch then around the side of the car to the sem on the other end?
Make sense? Tedious, but I have done this in the past in tough situations where voltage is getting lost somewhere in the car. _________________ John Henry
'57 Deluxe
'56 Single Cab |
Brezelmeister Samba Member
Joined: September 11, 2017 Posts: 61 Location: Germany
Posted: Fri Jul 27, 2018 4:01 pm Post subject: Re: Electrical issues |
Ground straps !
Make sure to check them, specially the one between gearbox and chassie,
Bad ground can cause all sorts of weird trouble. |
Grant Reiling Samba Slow-Change Artist
Joined: November 28, 2003 Posts: 491 Location: behind the wheel
Posted: Fri Jul 27, 2018 7:15 pm Post subject: Re: Electrical issues |
Brezelmeister wrote: |
Ground straps !
Good point Brezelmeister; I was wondering when that would get mentioned. Just may be the simplest solution to the problem.
What VW purist doesn't love simplicity?
Good luck eliminating possible causes.
Grant _________________ 1952 Azure Blue 12G (LHD Deluxe 3-fold sunroof Sedan).
"What you really know is possible in your heart is possible.
We make it possible by our will.
What we imagine in our minds becomes our world. That’s just one of many things I have learned from water."
Misaru Emoto
The Hidden Messages in Water |
Posted: Sat Jan 05, 2019 1:49 pm Post subject: Re: Electrical issues |
Ok I finally got around to cleaning and replacing the ground strap from the transaxle to the chassis. Made everything better and brighter. The semaphores still struggle a little with the lights on.
I checked the generator and its putting out 7.3 volts so I was thinking about putting a thinner ground strap from the generator to the body.
Any thoughts? |
wimkever Samba Member
Joined: July 16, 2004 Posts: 412 Location: Holland (the Netherlands)
Posted: Sat Jan 05, 2019 3:00 pm Post subject: Re: Electrical issues |
Peter T. wrote: |
..... so I was thinking about putting a thinner ground strap from the generator to the body.
Any thoughts? |
_________________ a beetle is like a cocker spaniel, always funny but sometimes not listening |
Posted: Sat Feb 02, 2019 2:28 pm Post subject: Re: Electrical issues |
So it seems that I solved the electrical issue with running an extra insulated generic cable from the trans to the chassis.
What is the functional difference between a generic battery cable and the OEM braided cable? |
DDub Samba Member
Joined: January 06, 2005 Posts: 307 Location: central pa.
Posted: Sat Feb 02, 2019 3:22 pm Post subject: Re: Electrical issues |
One had a good connection, the other did not. Put an ohm meter on it and check resistance. |
Posted: Sat Feb 02, 2019 8:35 pm Post subject: Re: Electrical issues |
resistance checks out good. Just wondering the difference between the braided cable vs a insulated cable. |
Posted: Mon Feb 04, 2019 9:52 pm Post subject: Re: Electrical issues |
Peter T. wrote: |
Electrically, there is none... _________________ John Henry
'57 Deluxe
'56 Single Cab |
