Peter - Belgium Samba Member
Joined: December 22, 2003 Posts: 762 Location: Brussels - Belgium
Posted: Mon Jul 23, 2018 7:20 am Post subject: BD spindle difference versus 55-63 spindles -> diskbrakes |
Hello all,
Anyone has an idea how a barndoor spindle from a bearingtap and bolt spacing differs from the slightly later 55-63 spindle?
currently I have a BD axle with the CSP diskbrake kit (item 499 254 5205), but this brakekit should be transfered to a later spindle.
If the bearingaxle is the same, i guess it will only be a matter of a new bracket.
if bearings etc are different/different spacing i guess it all is a no-go and I need to get a complete new wide5 brake kit?
Thanks!
Peter _________________ 356 Outlaw built: https://www.thesamba.com/vw/forum/viewtopic.php?t=430774&highlight= |
streetwagens Samba Member
Posted: Tue Jul 24, 2018 5:54 am Post subject: Re: BD spindle difference versus 55-63 spindles -> diskbrakes |
Hi Peter,
I have used 55> brake drums and redrilled backing plates on barndoor spindles, so the bearing spacing should be the same, however you will need to make up caliper brackets as the backing plate bolts are a different pattern. _________________ To catch a fish, you must first think like a fish.... |
Posted: Thu Jul 26, 2018 5:20 am Post subject: Re: BD spindle difference versus 55-63 spindles -> diskbrakes |
confirmed... spindle bearing axle is the same, only difference in the bolt spacing for teh backingplate. So need a new bracket and i can swap diskbrakes:-)
the plan now is to install the slighly later spindles on the barndoor beam (linkpins are same so should link up) and convert to center steering so the steeringbars are clearing the chassisrails nicely + will work with teh Creative Engineering steering rack.
Thanks! _________________ 356 Outlaw built: https://www.thesamba.com/vw/forum/viewtopic.php?t=430774&highlight= |
