howielambert Samba Member
Posted: Mon Jul 23, 2018 2:17 pm Post subject: Help identifying parts |
Hi all,
I am a newby here. Unfortunately the workshop that was restoring my 181 went bust and all the parts had to be moved by box to a new workshop. The new guys are slowing working on piecing the car back together, but they have come across (and painted) a number of parts where we can't find a home for them.
Of the parts pictured we have identified the spare wheel brace, the door hinges, hood/screen clamps. The remainder of the parts are a mystery. If anyone can help it would be much appreciated.
Thanks in advance
74 Thing Samba Member
Posted: Mon Jul 23, 2018 4:24 pm Post subject: Re: Help identifying parts |
There were lots of mounts available for accessories like wheel chock, shovel, etc.. |
77kafer Samba Member
Joined: April 08, 2008 Posts: 823 Location: New Windsor, NY
Posted: Mon Jul 23, 2018 5:27 pm Post subject: Re: Help identifying parts |
howielambert wrote: |
Hi all,
Thanks in advance
Suggestion, why don't you take a picture of just those parts that you haven't id'd. One picture would be fine, that way if people id something for you they can say top row third from left is _______. _________________ Supposed to be 77käfer, but there are no umlauts on an american keyboard
Overheard on 27 June 07, one lady to another when they saw my Harli in a parking lot at West Point, "maybe he found it on the clearance aisle at the Volkswagen dealer" |
Ron Domeck Samba Member
Joined: August 05, 2007 Posts: 1466 Location: louisville Ky
Posted: Mon Jul 23, 2018 5:54 pm Post subject: Re: Help identifying parts |
Bottom left round edges 4 holes, glove box light mount. |
Al Capulco Samba Member
Joined: October 31, 2005 Posts: 532 Location: Northridge, CA.
Posted: Mon Jul 23, 2018 9:16 pm Post subject: Re: Help identifying parts |
Ok, I'll try. The square rubber parts go in the lower windscreen latch as a cushion for the windscreen . The "L" shaped metal parts are the brackets for the lower gun mounts, they would have been mounted on inside rocker and maybe the rear seat cross brace. Then you have either 2 shovel mounts or an ax mount and 1 shovel mount. |
Posted: Mon Jul 23, 2018 10:36 pm Post subject: Re: Help identifying parts |
This is fantastic, thank you everyone for helping. Re. the shovel and other tool mounts, where would they have been, it seems I have two?
Thanks again!! |
Posted: Mon Jul 23, 2018 10:53 pm Post subject: Re: Help identifying parts |
The shovel mounted on the rear shelf. The ax mounted above the jack. |
Deckard Samba Member
Joined: April 07, 2012 Posts: 296 Location: Knoxville, TN
Posted: Tue Jul 24, 2018 9:28 am Post subject: Re: Help identifying parts |
The big piece with the hole in the middle (upper center) is the spare tire hold down clamp |
Posted: Tue Jul 24, 2018 9:29 am Post subject: Re: Help identifying parts |
the two small rectangles with two holes and a pin are door hinge pins; the screw to the body |
Posted: Tue Jul 24, 2018 4:35 pm Post subject: Re: Help identifying parts |
Deckard, you identified 2 of the 3 things that the poster said they knew in his original post. _________________ Supposed to be 77käfer, but there are no umlauts on an american keyboard
Posted: Wed Jul 25, 2018 6:32 am Post subject: Re: Help identifying parts |
It's always good to have reassurances, right? |
