Help! 64C-180 mm clutch and C TO bearing in need of replacement
Hkspwrsche
Hkspwrsche is offline
PostPosted: Tue Jul 24, 2018 6:08 am    Post subject: Help! 64C-180 mm clutch and C TO bearing in need of replacement Reply with quote
This is the combination that was recommended to me
http://www2.cip1.com/ProductDetails.asp ... C10%2D5040
http://www2.cip1.com/ProductDetails.asp ... %2D031%2DE
And the expensive part is the TO bearing.
https://www.stoddard.com/90111608101.html
Will the 180mm VW pressure plate and clutch listed be a direct fit? Has anyone used this with success?
Again, I donít have the 200mm C set up but the 180mm clutch and pressure plate with a C bearing set up currently.
Thanks,
1964 356C
PostPosted: Tue Jul 24, 2018 9:30 am    Post subject: Re: Help! 64C-180 mm clutch and C TO bearing in need of replacement Reply with quote
Just a note that the CIP1 links you posted above do not work.
They must have been shortened links you copied from somewhere instead of the full links that appear once you click on them in the original source.
Starbucket
Starbucket is offline
PostPosted: Tue Jul 24, 2018 3:54 pm    Post subject: Re: Help! 64C-180 mm clutch and C TO bearing in need of replacement Reply with quote
Check with autohausaz.com and get the correct stuff.
