Exhaust Parts Information 1977 Bus
Georgey0414
Georgey0414 is offline
PostPosted: Thu Jul 26, 2018 5:31 pm    Post subject: Exhaust Parts Information 1977 Bus Reply with quote
Hey everyone! So Iíve got some holes in my exhaust, and I need to order some new parts. Can anyone tell me where to get them, and have them delivered to Canada?
Iíve attached a picture of the diagram of the parts I need highlighted.
Hoody
Hoody is offline
PostPosted: Fri Jul 27, 2018 7:22 am    Post subject: Re: Exhaust Parts Information 1977 Bus Reply with quote
Those are not available new. Your U pipe flanges are also toast. Contact Scott at German Supply. I had my F pipes and U pipes rebuilt with new flanges by Scott and they are perfect. Heís in Canada as well. I donít know if he still offers this service or not. But send him an email. Hope this helps.
tommu
tommu is offline
PostPosted: Fri Jul 27, 2018 11:10 am    Post subject: Re: Exhaust Parts Information 1977 Bus Reply with quote
They do not look like they're going to come apart easily. What condition is the rest of the exhaust in?
Green Bay Bus Yellow Ghia
Georgey0414
PostPosted: Fri Jul 27, 2018 11:21 am    Post subject: Re: Exhaust Parts Information 1977 Bus Reply with quote
Iíll throw some pictures up here shortly. For what itís worth Iím probably going to have to just do the whole exhaust. Anybody have any recommendations for a whole kit?
tommu
tommu is offline
PostPosted: Fri Jul 27, 2018 11:23 am    Post subject: Re: Exhaust Parts Information 1977 Bus Reply with quote
Do you have any emissions testing or parts compliance regulation that would force you to keep the same exhaust? If not it's worth exploring all options. You should have oval exuast ports on your manifolds - but be sure about that before you buy.
Georgey0414
PostPosted: Fri Jul 27, 2018 11:41 am    Post subject: Re: Exhaust Parts Information 1977 Bus Reply with quote
Here are the pics I could get just now from underneath.
Hoody
Hoody is offline
PostPosted: Sat Jul 28, 2018 5:23 am    Post subject: Re: Exhaust Parts Information 1977 Bus Reply with quote
After seeing the rest of your exhaust I agree with you. You should replace everything. Do you have any aircooled VW mechanics close to you? This is not going to be an easy nor inexpensive job. Your head studs are going to be an issue based on the amount of rust that exhaust has. I would switch to the 72-74 set up drop the engine. Replace the head studs....which may lead to more. Good luck!
SGKent Premium Member
SGKent is offline
PostPosted: Sat Jul 28, 2018 9:57 am    Post subject: Re: Exhaust Parts Information 1977 Bus Reply with quote
can you hear exhaust leaking? Here is why I ask - the F and U pipes have a shield on them. That shield can rot and fall off but it doesn't affect how the exhaust works - just heat radiation from it. Your photos look like you still have a part of the shield left so it is unusual for the thick metal pipe to rot if the shield is still there. If the hole in the photo does leak, for now I would have a professional welding shop fix it still on the bus but disconnect the alternator plug at the VR when they weld. The inner steel pipe is usually thick and that is the first one I have seen burn thru is that is what the photo is showing. If it is just the shield ignore it. My fear is that you will snap studs on the head trying to fix it and then things really go downhill fast.
here is a photo from classifieds showing the pipes with the shields rusted off
Here is a photo of an afterburner and a little of the F-pipe where both still have shields. See how much wider / fatter they are with the shields?
Godspeed to all who undertake a journey in a VW Bus.
*You can do it right the first time, or do it over, the choice is yours. It is a free country. As to brakes, steering, tires, axles etc. - you may only get one chance at doing those right.
It isn't our fault you bought a 50-year old toy you can't afford. None of us can afford it really. Even Steve Jobs had to sell his bus to make his financial life work.
1971 (sold)
1977
Georgey0414
PostPosted: Sat Jul 28, 2018 6:20 pm    Post subject: Re: Exhaust Parts Information 1977 Bus Reply with quote
Here is a link to a video I took earlier today. Just started it for the first time in a week.
https://youtu.be/nprhN5IbRQo
I couldnít tell you myself if I can hear the exhaust leak.
Iíd look into swapping for a 72-74, but Iím always a bit weary swapping parts for other model years. (Bad experience from when I was younger)
Georgey0414
PostPosted: Sat Jul 28, 2018 6:49 pm    Post subject: Re: Exhaust Parts Information 1977 Bus Reply with quote
I should also probably mention I currently donít have any heat hooked up/ missing the lever on the dash. Never really noticed until after I bought it.
SGKent is offline
PostPosted: Sat Jul 28, 2018 7:06 pm    Post subject: Re: Exhaust Parts Information 1977 Bus Reply with quote
my 2 cents is have it patched - welded professionally for now. There is a good chance the studs on the head are going to snap and if they do things will go down hill fast. Wait until you decide to pull the motor so if they do you can either take the heads off and to a machine shop, or replace them. Just my 2 cents worth.
1971 (sold)
1977
Georgey0414
PostPosted: Sat Jul 28, 2018 8:08 pm    Post subject: Re: Exhaust Parts Information 1977 Bus Reply with quote
Iím guessing thatís just a short term fix? Iíll take it to the local expert, Guntherís.
Any idea in a ballpark for how much it will cost me to pull the motor and swap the exhaust? 1-2k? More?
Hoody
Hoody is offline
PostPosted: Sun Jul 29, 2018 5:18 am    Post subject: Re: Exhaust Parts Information 1977 Bus Reply with quote
These things can lead to opening Pandoraís box. How is the engine running? How many miles are on it? Are you going to keep it? What does the underside look like? Is it rotted like your exhaust? What does your front and rear beam look like? My point is I know that part of the world is rough on cars in the winter. I used to live in New England for a long time. Yours looks to have been driven in the winter. If the underside and front and rear beams are not rotted too than itís worth fixing right. If on the other hand itís all rotted like your exhaust it may not even be safe to drive. Where the rear trailing arms attach to the body and the front beam. I think you should get it up on a lift with a pro and take a good hard look at everything first before you dump a ton of cash into a Bus that may need thousands more to be safe. Sometimes itís just not worth it. I am hoping that is not the case. If itís all rotted to hell under there your better off finding a donor body and and swapping things over. If your on limited funds and itís safe to drive than I would do as Steve said just put some bandaids where you need to to get some more life out of it. Maybe you have not crawled under there and taken really good look at everything. But my advice would to be to get it up on a lift and with your VW expert and assess the rot. Not trying to discourage you. Just donít want you to throw good money after bad.
Hoody
Hoody is offline
PostPosted: Sun Jul 29, 2018 5:50 am    Post subject: Re: Exhaust Parts Information 1977 Bus Reply with quote
Let us know what you find with some pics. When you said the ďlocal expertĒ was that an aircooled VW shop or a local welder? I donít want to give you advice as how to proceed with before you take a REALLY hard look at the undercarraiage. Just to give you a quick example I recently heard from a friend about a guy that doesnít know yet that heís spent over 25,000 in metal and body work to get it back to where it needed to be. Which is totally insane. There are good donor bodies out there where the previous owner just through in the the towel. In fact I may know of where a nice Westy is that has no engine and can be bought for short money. But itís been a couple years since I saw it and it may be gone. I donít think many if anyone knows about it though. However I did not crawl underneath it. But the fact that it had all original paint and looked really good leads me to believe it was nice underneath. I would have bought it on the spot but donít want and canít afford another project right now. Like I said I am not trying to discourage you. Just realized via Google Guntherís is a VW shop. You are VERY fortunate to have a place so close that specializes in aircooled VWís. Good luck!
Bleyseng
Bleyseng is offline
PostPosted: Mon Jul 30, 2018 11:09 pm    Post subject: Re: Exhaust Parts Information 1977 Bus Reply with quote
Ken at thebusco.com should have what you need in stock.
70 Ghia Black convert-9/69 build date-stock w/133k 1600 SP-barn find now with a rebuilt tranny and engine
77 Westy 2.0L w/Ljet, Camper Special engine-95hp and with LSD!
76 Porsche 914 2.1L L20c, 120hp Djet
Wasted youth
Wasted youth is offline
PostPosted: Tue Jul 31, 2018 7:37 am    Post subject: Re: Exhaust Parts Information 1977 Bus Reply with quote
Here is work I did on my 1977 GD engine... you'll need to scroll down a little more than halfway to get to the exhaust parts. All my parts came from Bus Depot, except for the Catalytic converter and its clamp.
https://www.thesamba.com/vw/forum/viewtopic.php?p=7358931#7358931
1968 Double Cab truck, 1973 Auto trans bus, 1978 Auto trans Sunroof bus with A/C and a 1987 Auto trans Westfalia.
Goach2
Goach2 is offline
PostPosted: Tue Jul 31, 2018 8:53 am    Post subject: Re: Exhaust Parts Information 1977 Bus Reply with quote
I changed mine over to earlier exhaust, you can check it out here:
https://www.thesamba.com/vw/forum/viewtopic.php?t=693943&highlight=
1977 FI Westfalia
