parker007 Samba Member
Joined: December 21, 2011 Posts: 132 Location: california
Posted: Fri Jul 27, 2018 12:01 am Post subject: Limited slip differential |
im wanting to put limited slip differential in my split case transmission for off road, since this car stays on ranch and never on highway. what will fit? Also what is involved in swapping in a bus reduction box? any help appreciated. |
Peter_N Samba Member
Joined: February 19, 2014 Posts: 321 Location: The Netherlands
Posted: Fri Jul 27, 2018 3:57 am Post subject: Re: limited slip diferential |
I have no clue on the LSD.
For mounting bus reduction boxes you would need to flip the crownwheel orientation inside the box.
You'll have to open the gearbox anyway to switch the axles. _________________ My 1958 PGSG project topic |
Posted: Fri Jul 27, 2018 4:08 am Post subject: Re: limited slip diferential |
my plan is use whole bus box, im guessing that a special adapter need to be fabricated for outer swing mount? |
henry roberts Samba Member
Joined: February 24, 2003 Posts: 1274 Location: australia
Posted: Fri Jul 27, 2018 5:33 am Post subject: Re: limited slip diferential |
if it was easy everybody would be doing it.
as far as i know you are looking at a semi-custom lsd to suit a pre a porsche 356. from memory the guy who makes them is on this site with the username "gears" or similar.
i think there is a chance a paw type lsd out of a kubelwagen may be able to be adapted, but i don't have one to investigate further.
either way it won't be cheap. |
Snort Samba Member
Joined: April 02, 2005 Posts: 1957 Location: Seattle, WA
Posted: Sat Jul 28, 2018 9:19 pm Post subject: Re: limited slip diferential |
wow 2k for one. |
txoval Samba Member
Joined: January 23, 2004 Posts: 3540 Location: The Woodlands, TX
Posted: Sun Jul 29, 2018 6:32 am Post subject: Re: Limited slip differential |
My first thought was why? and then how much are you willing to spend.
If it’s a ranch vehicle, rip the fenders off, put some good mud tires on it and a winch. With the flat bottom and light weight, VW’s will go thru quite a bit of mud easily |
Posted: Sun Jul 29, 2018 6:50 am Post subject: Re: Limited slip differential |
just ,thinking for 1k i could better offroad cap, but now i see more like 3k maybee just use the jeep for snow. |
0nebadbug Samba Member
Joined: October 01, 2009 Posts: 1087 Location: Rockford, Illinois
Posted: Wed Aug 01, 2018 7:29 am Post subject: Re: Limited slip differential |
Silly question....
Many many years ago (early 80's) I owned pair of Green, bone stock, '69's at the same time. One was a standard manualtrans & the other was an Auto-stik trans ...
Just by the rear traction differences between them (especially in Winter) I would have sworn the auto-stick drove like it was LSD and drove totally different than the one with the standard manual trans... And I would also notice that both wheels would spin up together in heavy snow where the manual wouldn't....
I would always drive the auto-stik when it snowed as its rear traction was 10x better than the one with the manual trans. Both cars had matching stock wheels & tires... It's always made me wonder if the A/S's were LSD or maybe even posi, or maybe something different about the auto-stiks that allowed both rears to spin together...
Anyone know? _________________ ::: Slowoval ::: LaDawri Sebring ::: '61 Creampuff ::: Dust Storm '66 ::: |
