Panheadguy Samba Member
Joined: November 04, 2016 Posts: 21 Location: SE Wisconsin
Posted: Fri Jul 27, 2018 7:35 am Post subject: 1973 Thing turn signal problems but flashers work |
My turn signals don' t work but my flashers do. I have searched and found some posts regarding this same issue and determined that the green wire to the flasher is hot with ign on. Has anyone else had this problem and ca offer some suggestions? Thanks.
Guy _________________ The police never think it's as funny as I do... |
Dougster43 Samba Member
Posted: Fri Jul 27, 2018 11:46 am Post subject: Re: 1973 Thing turn signal problems but flashers work |
The green wire actually provides power to the emergency flasher switch that is only used for the turn signals. The position of the emergency flasher switch determines the source of power to the flasher relay which is sent to the relay on the white wire. But since your hazard lights work it sounds like the relay is working properly.
First, Check the plug on the turn signal switch that is under the steering column- if that’s loose and not making a good connection, or disconnected that would cause your turn signals to not work.
Next, with the emergency flasher switch off and ignition on, check that you have +12V power on the + terminal (white wire) on the emergency flasher switch. If not then you probably need a new emergency flasher switch.
If that looks ok, check continuity between the 49a terminal on the flasher switch and the L and R terminals on the flasher switch. You should not have continuity between them with the turn signals switch in the middle (off) position, but you should have continuity between 49a and either the L or R terminal with the turn signal switch in the corresponding position. If you don’t have that, then there is either a break in the black wire with white and green stripes that runs from the 49a terminal to the plug on the turn signal switch, or you could have a bad turn signal switch or connection to the switch as noted above.
If you pass the continuity test between the 49a and the L/R terminals and since you already verified that the green and white wires are getting +12V, then the emergency flasher switch is bad.
Hope that helps! |
Posted: Fri Jul 27, 2018 3:04 pm Post subject: Re: 1973 Thing turn signal problems but flashers work |
Huge thanks to Dougster. I'm on it in the AM! _________________ The police never think it's as funny as I do... |
Posted: Sat Aug 04, 2018 9:00 am Post subject: Re: 1973 Thing turn signal problems but flashers work |
Thanks again to Dougster! Sorry so late in posting this reply. I was able to diagnose a bad flasher switch with Dougster's help.
This board is a huge help! _________________ The police never think it's as funny as I do... |
Posted: Mon Aug 06, 2018 1:11 pm Post subject: Re: 1973 Thing turn signal problems but flashers work |
Glad I could help!! Glad it was something simple. |
