Matthew Tolbert Samba Member
Posted: Sat Jul 28, 2018 12:37 pm Post subject: Which oil plungers should I use? |
I have several oil plungers and springs to choose from and have read numerous threads all with conflicting opinions. So which ones are correct to use? The plungers and springs marked in pink were in the engine. I have another complete set not pictured. The plungers are all the same diameter except the grooved one shown and they all vary in length. The springs are all close to the same in wire diameter and lengths.
Oil plunger sizes
15.89mm x 23.62mm grooved was in engine
15.94mm x 18.80mm was in engine
15.94mm x 18.31mm
15.94mm x 18.92mm
15.94mm x 18.41mm
15.94mm x 18.50mm
15.94mm x 23.50mm grooved not shown
15.94mm x 17.66mm not shown
Short springs
1.42mm x 31.56mm was in engine
1.39mm x 30.62mm
1.40mm x 31.10mm
1.41mm x 29.88mm not shown
Long springs
1.56mm x 76.98mm was in engine
1.65mm x 77.19mm
1.57mm x 79.20mm
1.59mm x 78.30mm silver not shown
_________________ Matthew Tolbert
1958 ragtop
1961 doublecab
1965 Notchback S |
fivelugshortaxle Samba Member
Joined: May 13, 2011 Posts: 4254 Location: Aumsville, Oregon
Posted: Sat Jul 28, 2018 1:48 pm Post subject: Re: Which oil plungers should I use? |
_________________ Good things come to those who wait.
2332 with lots of goodies....
Rotating assembly balanced by Brothers VW
4340 84mm crank
AA 94mm p&c' s
Total seal 2nd ring, rest are Grants
5.5 h beams
Magnum straight cuts
Steve Long XR310 on a 106
CB 1.4 rockers
CB Magnaspark 2 distributor
NGK D7ea plugs
A1 lowdown 1 3/4 with single muffler
Dellorto 48's with 40 venturies
Kennedy Stage 2 with Daiken disc |
Dougy Dee Samba Member
Joined: August 21, 2004 Posts: 1669 Location: Niagara Region, CANADA
