sgellis Samba Member
Joined: July 06, 2016 Posts: 2014 Location: SW Nova Scotia, Canada
Posted: Sun Oct 20, 2019 2:17 pm Post subject: Re: Camper interior build on a 64 Kombi |
Had a great summer with the bus but time to put it away.
Unpacked. Surprising just how much stuff was in there. Going to do some work on it this winter so removed everything including cushions.
Few things I want to get done.
Table
Spice rack. Going to be smaller than originally planned.
Shelves in the rear cabinet.
Joiner strips in ceiling.
Clothes line. Need somewhere to hang wet towels when traveling.
Add 2 deluxe coat hooks.
Sub drawers above fridge.
Covers for the electrical area.
Vent battery charger outside.
Tweak the awning poles and add sides.
Add rigid pickup tube in water tank.
Build side lights and awning lights
Install inverter
Install solar charger
Install disconnect switch on conversation battery
Hookup new fridge temperature sensor
Add basket in top of fridge
Add Bluetooth control
Install gas heater
Build outside table that will store below bench
Think that's about it...
_________________ My 64 Kombi restoration
My camper interior build
My 54 standard restoration
The Nova Scotian Barndoor (YouTube)
The Nova Scotian Barndoor (CAD drawings) |
Posted: Tue Feb 04, 2020 7:49 pm Post subject: Re: Camper interior build on a 64 Kombi |
Getting a few camper bits started.
Parts cut for the spice rack out of 3/8" plywood. Decided to make it thinner than most. 3.5" at deepest part. Keeping it 2" above floor for toe room when sitting on bed.
Found a nice latch for the fridge. I will need to fix some screw holes and the catch will be a bit of work to mount. I like the look and I can get rid of the stick of shame.
I need to vent the battery charger through the floor. Too much heat in the summer. Will look around for something to duct the air.
LAGrunthaner Samba Member
Joined: March 18, 2007 Posts: 5509 Location: 1st Coast
Posted: Fri Feb 14, 2020 5:03 am Post subject: Re: Camper interior build on a 64 Kombi |
sgellis wrote: |
Spice rack fitted. Just clears the fridge. Going to be very useful and quite a bit of storage.
I screwed through the panel from the back. Only a few screws are installed so that will fit better when finished. Would like to have a cover on top but don't know how to hinge it that won't make access difficult. I could have a cover that just sits on.
_________________ American Red Cross Safe And Well:
Maui Roadsters
www.mauiroadsters.com
http://www.oacdp.org
Lind wrote: |
langsmer Samba Member
Joined: November 18, 2004 Posts: 1127 Location: CO/NM border
Posted: Sun Feb 16, 2020 10:15 pm Post subject: Re: Camper interior build on a 64 Kombi |
Stunning work! There is a company called B&M hardware that makes a solid brass chrome plated cupboard turn that might match your fridge latch better then the stamped sheet metal ones. I'm sure there must be a few dealers in Canada. I used to be a historic home hardware salesman. There are none better made in my opinion.
http://www.timelyhardware.com/product/1612-pc/ |
djfordmanjack Samba Member
Joined: June 15, 2009 Posts: 2179 Location: Graz, Austria, Europe
mandraks Samba Member
Joined: November 28, 2004 Posts: 7050 Location: Lawrenceville, Ga
Posted: Sat Feb 22, 2020 6:34 pm Post subject: Re: Camper interior build on a 64 Kombi |
sgellis wrote: |
Got the fridge latch on. No more stick of shame
now that is a beautiful latch _________________ regards
Uli
mdege Samba Member
Joined: January 16, 2018 Posts: 940 Location: Niederkruechten, Germany
j.pickens Samba Member
Joined: December 03, 2002 Posts: 9791 Location: Exit 7, New Jersey
Posted: Sun Feb 23, 2020 6:36 pm Post subject: Re: Camper interior build on a 64 Kombi |
Always enjoy your updates.
And a comment, the spacing between your spice rack and cabinet with the door shut looks Awfully tight. I would suggest that you check that carefully to avoid impact when slamming the door. Of course, we never slam bus doors, right? _________________ Founder and Chairman Emeritus, ECMSAS
BeaterBarndoor wrote: |
i wish more people would actually drive their vws rather than just talking about what they have in the garage. |
Red Fau Veh wrote: |
If you've seen one sunroof swivel seat kombi, you've seen them all! |
