74 Thing Samba Member
Posted: Sun Jul 29, 2018 8:53 pm Post subject: How do you separate the turn signal switch from the wiper switch |
How do you separate the turn signal switch from the wiper switch? They come out together as one unit after unscrewing 4 screws and lifting it out. I don't want to break anything prying them apart.
Thanks |
JayC Samba Member
Posted: Mon Jul 30, 2018 9:28 am Post subject: Re: How do you separate the turn signal switch from the wiper switch |
Very very carefully
I think i remember when I did mine that they kind of "snapped" apart. Look around the edges and see if there are 2-3 tabs that hold the plastic parts together if we are talking about the same thing.
jay |
carsdlt Samba Member
Joined: May 02, 2012 Posts: 317 Location: So. OC, Calif.
Posted: Wed Aug 01, 2018 10:08 pm Post subject: Re: How do you separate the turn signal switch from the wiper switch |
IIROC, they are usually sold as a pair. If you're having an issue with one or the other, you might want to replace the whole unit. Usually available in the classified section, Thing and Beetle. Also TTS has them new. _________________ Thanx, DLT
'73 181 stock 1600 - "Dr. Bombay"
"If it works, don't fix it....let it break on its own." |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Thu Aug 02, 2018 5:22 am Post subject: Re: How do you separate the turn signal switch from the wiper switch |
yes they just have lock tabs holding them together and no you don't have to replace both at the same time
They do come out of the housing together then seperate
_________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
Posted: Thu Aug 02, 2018 6:46 am Post subject: Re: How do you separate the turn signal switch from the wiper switch |
Thanks for the advise.
I was able to separate them and clean them and the contacts, and the turn signal cancelling mechanism.
The two white wire looms have three male/female interlocking tabs that need to be separated.
After that the two switches can be gently separated. There are male studs on one switch that connect the two so using a screwdriver and gently prying up separated them for me. |
