Restoration of a former '65 firetruck (21F)
mdege
mdege is offline
PostPosted: Tue Jul 02, 2019 12:44 pm    Post subject: Re: Restoration of a former '65 firetruck (21F) Reply with quote
It's time to do an update.
I finally finished the center section of the van. The new cargo floor is installed.
Haven't made a picture of the completed floor from the top.
I also patched a few spots on the passenger side:
The repair section for the right front wheel-well did not fit at all Shocked
First I cut out the rusty part:
And modified the repair section to make it fit:
And then I made a repair section for the floor and welded it in:
and two more little patches:
Yesterday I started to remove the front valance:
Lots of work to get it all out without cutting into the parts that don't need replacing.
- Michael
1988 Multivan Magnum 112i
2006 T5 (sold)
1986 Caravelle C (sold)
1987 Caravelle Coach (R.I.P)
1972 T2ab Bay Window (sold)
1965 21F
1971 & 1969 Variant LE (sold)
John Ghia
John Ghia is offline
PostPosted: Thu Aug 01, 2019 9:25 pm    Post subject: Re: Restoration of a former '65 firetruck (21F) Reply with quote
Any updates?
OG BUS BOYZ
mdege
mdege is offline
PostPosted: Thu Aug 01, 2019 11:17 pm    Post subject: Re: Restoration of a former '65 firetruck (21F) Reply with quote
John Ghia wrote:
Any updates?
Thank you for asking.
I am currently on a road trip to Sweden.
The week before I left I finished the second dogleg and got everything ready for installing the front valance. I will continue on that next week.
I will also follow up with the photos.
- Michael
2006 T5 (sold)
1965 21F
mdege
mdege is offline
PostPosted: Thu Aug 08, 2019 12:14 pm    Post subject: Re: Restoration of a former '65 firetruck (21F) Reply with quote
I decided, that the old doglegs were not worth saving after all. Therefore I replaced both sides. I don't understand why they bother to put them together. I find it much easier to install the outer part first and then the inner part, especially when using a spot welder to assemble them. The main reason for taking them apart is, that you cannot weld about 6" of the seam to the b-pillar when it is in one piece.
Then I installed the inner part of the front valance including the parts which connect to the a-pillars.
- Michael
2006 T5 (sold)
1965 21F
otherbeach
otherbeach is offline
PostPosted: Thu Aug 08, 2019 12:23 pm    Post subject: Re: Restoration of a former '65 firetruck (21F) Reply with quote
Have you seen this slideshow of a California-based, former German firetruck?
https://1drv.ms/u/s!AmhOW3ckxMVHgmDBl9v2hy_Ewjvn?e=uHVbyG
Coming to you from Godís Own Time Zone: Central Time.
"Cows at the border of the Dairy State and the Land of Lincoln are remarkably honest."
mdege
mdege is offline
PostPosted: Thu Aug 08, 2019 12:28 pm    Post subject: Re: Restoration of a former '65 firetruck (21F) Reply with quote
No, haven't seen that one. Thank you for sharing.
First double door firetruck I remember seeing. It's kinda cool.
- Michael
2006 T5 (sold)
1965 21F
mdege
mdege is offline
PostPosted: Thu Sep 05, 2019 12:23 pm    Post subject: Re: Restoration of a former '65 firetruck (21F) Reply with quote
Its time to continue on this thread.
In the mean time I scored some NOS spring plates. They were not advertised as such but looked good on the pictures. They still weren't cheap but it was a pleasant surprise to see that they had never been installed on a car.
I decided it would be a good idea to paint the cargo floor from the bottom before the weather gets bad. I gave it two coats of Brantho Corrux Nitrofest. the first coat I chose black and the second coat is red RAL 3000 the original color of the van, before it faded.
Since the front is done except for the front valance, I decided to move on to the back of the car. I need to replace the battery tray and fix some old not so good repairs I did back in the nineties.
I pounded the patches with a rubber mallet on a bag of sand to give them the correct 3D curvature. I am really happy how it turned out so far.
I did not finish the front valance yet, because I still want to sandblast the wheel wells and I figured I would not be able to get the blasting media out of the closed front valance.
- Michael
2006 T5 (sold)
1965 21F
LAGrunthaner Premium Member
LAGrunthaner is offline
PostPosted: Mon Sep 09, 2019 3:58 pm    Post subject: Re: Restoration of a former '65 firetruck (21F) Reply with quote
Keep up the great work, Applause Applause Applause
American Red Cross Safe And Well link:
https://safeandwell.communityos.org/cms/index.php?...OSmeUzh8l4
Maui Roadsters VW Logo
www.mauiroadsters.com
Lind wrote:
mdege
mdege is offline
PostPosted: Thu Sep 12, 2019 12:51 pm    Post subject: Re: Restoration of a former '65 firetruck (21F) Reply with quote
@LAGrunthaner: Thank you for the kind words.
Finished the right rear corner today.
- Michael
2006 T5 (sold)
1965 21F
mdege
mdege is offline
PostPosted: Wed Sep 25, 2019 11:01 am    Post subject: Re: Restoration of a former '65 firetruck (21F) Reply with quote
I finished the sheet metal work on the body for now. The only thing missing is the nose which I am waiting with until if finish blasting the bottom. I don't want the blast media trapped in the front valance.
Today I did the last bit of grinding and welding on the left rear corner.
Blasted the main rail before I installed the new parts.
- Michael
2006 T5 (sold)
1965 21F
mdege
mdege is offline
PostPosted: Wed Oct 16, 2019 10:26 am    Post subject: Re: Restoration of a former '65 firetruck (21F) Reply with quote
Some more progress. I pulled out the rear hatch seal and blasted the rust in the seal channel and I straightened out the warped rear apron:
On Monday I took the bus to a place which does media blasting and had the undercarriage blasted:
On Tuesday I took a day off from work to spray the first coat of paint. It was supposed to rain and it did rain. I dragged the bus over to my farmer neighbors and used their shop to do the work:
First layer is done, this will keep the rust from coming back:
- Michael
2006 T5 (sold)
1965 21F
mdege
mdege is offline
PostPosted: Sun Oct 27, 2019 2:02 am    Post subject: Re: Restoration of a former '65 firetruck (21F) Reply with quote
Some more updates on my van.
I closed the front valance. I had put that off because I was sure I would not get the blasting media out once it is closed. I definitely think that was a good idea. I still have crushed glass coming from all kinds of places. Every time I move the van or tip it on its side more of the stuff comes out of the crevices.
I did add more spot-welds on the top, but didn't take a picture. The spot-welder had to cool off, therefore I postponed the upper welds.
Then I installed most of the heater tubes. I let out the long center section because the tube I bought is a bit too small. I need to make some adapters.
Yesterday I took advantage of the really nice fall day to spray the second and in most parts last coat of paint on the under carriage.
- Michael
2006 T5 (sold)
1965 21F
Major Woody
Samba Enigma
Major Woody is offline
PostPosted: Tue Oct 29, 2019 11:12 am    Post subject: Re: Restoration of a former '65 firetruck (21F) Reply with quote
You are doing a great job on that bus.
mdege
mdege is offline
PostPosted: Tue Oct 29, 2019 11:50 am    Post subject: Re: Restoration of a former '65 firetruck (21F) Reply with quote
Thank you!
Today I started to weld the last panel to the body.
- Michael
2006 T5 (sold)
1965 21F
1970PAKombi
1970PAKombi is offline
PostPosted: Tue Oct 29, 2019 12:40 pm    Post subject: Re: Restoration of a former '65 firetruck (21F) Reply with quote
I love the detail in terms of how you keep documenting each step. Thank you for sharing and getting this thing back to show quality!
PostPosted: Tue Oct 29, 2019 3:07 pm    Post subject: Re: Restoration of a former '65 firetruck (21F) Reply with quote
I couldn't agree more.
Lind wrote:
mdege
mdege is offline
PostPosted: Tue Oct 29, 2019 10:08 pm    Post subject: Re: Restoration of a former '65 firetruck (21F) Reply with quote
Thank you!
I read a lot of build threads before I started. I feel now it is time to pass on some of my experience to the next ones who start on such a journey,
- Michael
2006 T5 (sold)
1965 21F
bus guy
bus guy is offline
PostPosted: Fri Nov 01, 2019 4:19 pm    Post subject: Re: Restoration of a former '65 firetruck (21F) Reply with quote
I just read your whole thread - great job youíre doing 👍🏻
mdege
mdege is offline
PostPosted: Sun Nov 03, 2019 10:31 am    Post subject: Re: Restoration of a former '65 firetruck (21F) Reply with quote
Thanks!
This weekend I spent some more time touching up places I couldn't reach with the airgun. And I tinned the weld on front panel. It didn't turn out great but I guess I filled enough with tin to get a reasonably thin layer of epoxy putty.
And layer of primer to keep the rust away. It is getting really damp at night.
- Michael
2006 T5 (sold)
1965 21F
mdege
mdege is offline
PostPosted: Thu Nov 21, 2019 12:52 pm    Post subject: Re: Restoration of a former '65 firetruck (21F) Reply with quote
I can't really do much to the body at the moment because it is too cold for the epoxy filler. Therefore I started putting some parts back. I started with the clutch pedal. The seal is no longer available. I decided, that there must be a solution and I think I have a greatly improved version.
I made a ring from PA6 plastic on my lath and use a standard o-ring.
And I also reinstalled the brake pedal.
- Michael
2006 T5 (sold)
1965 21F
Page 4 of 5
