John cilia Samba Member
Joined: May 03, 2016 Posts: 140 Location: Toronto, Canada
Posted: Tue Jul 31, 2018 5:43 pm Post subject: 11g front window trim install questions |
I am about to install front wind shield on my 52 beetle 11g.
Am I correct in thinking this is the order of install ?
1 put rubber onto window.
2 install window into car
3 install retainer trim clips into moulding
4 install moulding into rubbers groove.
How close am I ?
Thanks John _________________ Currently restoring a 1953 11g in metallic blue.
The most important thing on a Tombstone is the Dash between the 2 dates. |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Tue Jul 31, 2018 7:22 pm Post subject: Re: 11g front window trim install questions |
put the rubber on the glass then the chrome trim before installing in bug. _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
sled Samba Member
Posted: Tue Jul 31, 2018 8:04 pm Post subject: Re: 11g front window trim install questions |
60ragtop wrote: |
put the rubber on the glass then the chrome trim before installing in bug. |
split beetle trim is different and unique to splits.. different process. _________________ drive your split. |
Posted: Tue Jul 31, 2018 8:12 pm Post subject: Re: 11g front window trim install questions |
So what's the process ? _________________ Currently restoring a 1953 11g in metallic blue.
Posted: Wed Aug 01, 2018 5:14 am Post subject: Re: 11g front window trim install questions |
sled wrote: |
60ragtop wrote: |
split beetle trim is different and unique to splits.. different process. |
Sorry
So what is the process _________________ Rick
tasb wrote: |
sb001 wrote: |
ZENVWDRIVER Samba Member
Joined: November 07, 2008 Posts: 3340 Location: N.E. Oklahoma
Posted: Wed Aug 01, 2018 8:50 am Post subject: Re: 11g front window trim install questions |
John cilia wrote: |
How close am I ?
Thanks John |
I have never installed a garnish molding into new gasket, because I have never been able to. so, I leave it out, even though I have a 1952 to 1954 shop manual... I just don't get it.
But here is what it says:
1. place the weather strip around the windshield edge
2. fit a strong cord around the channel for the garnish molding.
This is done by a piece of tube, one end of which should be flattened. Insert the flat end into the channel and move it completely around the windshield. the cord, passing through the tube, is thus embedded in the channel as the tube is moved. The cord should cross in the center of the upper or lower windshield side.
3. First push one of the 2 molding halves completely into place and then the other. Starting at the point where the cord ends cross, slowly pull out the cord, while pushing the garnish molding into place by hand, until the operation is complete.
4. install the two garnish molding sleeves.
5. install the windshield into the opening... requires 2 persons.
So, it looks like the garnish molding is placed in the weather strip BEFORE the weather strip on the window glass is installed... PM me if you want photocopy of pages 6-8 and 6-9 of my VW Workshop Manual
_________________ 5/50, pastel green 11G - SOLD
8/50, gray 11A Beetle
6/52, pastel green 11C - SOLD
1960 single cab
9/63 Pacific blue, Ghia
'87 Toyota MR2
All super-heroes, wear a MASK |
Posted: Wed Aug 01, 2018 9:39 am Post subject: Re: 11g front window trim install questions |
Great info !
Thanks _________________ Currently restoring a 1953 11g in metallic blue.
splitjunkie Samba Member
Posted: Wed Aug 01, 2018 12:13 pm Post subject: Re: 11g front window trim install questions |
splits had metal clips that were installed around the rubber gasket ever couple of inches and then the chrome strip was snapped onto the clips.
I would assume that doing all of this before installing the windshield into the car would still apply here. _________________ Chris
nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3783 Location: Twin Cities, MN
Posted: Thu Nov 22, 2018 3:23 pm Post subject: Re: 11g front window trim install questions |
We're restoring a March 1952 split window. Where can I get the windshield rubber, clips and molding for this car? Any sources or suggestions out there? |
Posted: Thu Nov 22, 2018 3:33 pm Post subject: Re: 11g front window trim install questions |
Split parts unlimited. As long as your not in a hurry for it. _________________ Currently restoring a 1953 11g in metallic blue.
Posted: Thu Nov 22, 2018 4:01 pm Post subject: Re: 11g front window trim install questions |
Splitpartsunlimited ad here.
https://www.thesamba.com/vw/classifieds/detail.php?id=858789
$450 for the seal, clips and trim.
If you want the accurate parts this is the only vendor making them. I plan on using the '53 and later seal and trim. I just can't justify the extra cost for a part that most people would never notice but if you are going for a 100 point restoration this is your only choice.
I just bought the German seals with the molded corners from CIP1. They are running a 20% off sale until the 30th so I snagged a complete set. You can't buy a kit because nobody sells a set with the trim on the windshield and the plain seals for the rest of the windows so you have to buy the individual seals and trim. _________________ Chris
Grant Reiling Samba Slow-Change Artist
Joined: November 28, 2003 Posts: 491 Location: behind the wheel
Posted: Thu Nov 22, 2018 9:40 pm Post subject: Re: 11g front window trim install questions |
splitjunkie wrote: |
I just bought the German seals with the molded corners from CIP1. They are running a 20% off sale until the 30th so I snagged a complete set. You can't buy a kit because nobody sells a set with the trim on the windshield and the plain seals for the rest of the windows so you have to buy the individual seals and trim. |
Thanks Chris, Happy Thanksgiving!
Grant _________________ 1952 Azure Blue 12G (LHD Deluxe 3-fold sunroof Sedan).
"What you really know is possible in your heart is possible.
We make it possible by our will.
What we imagine in our minds becomes our world. That’s just one of many things I have learned from water."
Misaru Emoto
The Hidden Messages in Water |
