karghia74 Samba Member
Posted: Thu Aug 02, 2018 11:04 am Post subject: 1966 Rescue |
And I AM BACK
Hey fellow airheads, it has been 4 years or so since I posted anything but I have been lurking and reading needless to say I missed my Ghia's so against my better wisdom or lack thereof I adopted my 3rd Karmann Ghia a 1966 internet rescue.
I have not named her yet, she is rough around the edges and has been molested but for the most part still all there. Learning from past mistakes I am approaching this restoration differently this time, no more brand new everything so whatever can be fixed and restored will stay but as usual, I will be doing everything myself including the paint and bodywork. To start with it came with a Weber that had the wrong jets and a manifold that was missing the preheating tubes, the muffler was shot so I rebuilt the carb, changed the jets and replaced both the intake and muffler. I also added a PerTronix distributor and replaced the clunky high pressure fuel pump he had with the correct one for the carb. Spark plugs, valve adjustment, brand new starter and it came back to life purring.
I really like the new Bosch starter, it is a lot smaller in size but it starts the engine right away and in my opinion it is a lot less noisy.
Everything is getting a coat or two of Corroseal Rust Converter for now until I decide if I am taking the body of or not
couple of pictures of what I am dealing with
WHY!!!
Seals, new ball joints, ball bearings and drop spindles in the work
_________________ 69 Ghia Autostick (Also Gone)
68 Ghia (gone)
560SEC (gone)
530I (gone but not forgotten)
1969
http://www.thesamba.com/vw/forum/viewtopic.php?t=609541
1968
http://www.thesamba.com/vw/forum/viewtopic.php?t=459544 |
Rome Samba Member
Joined: June 02, 2004 Posts: 9602 Location: Pearl River, NY
Posted: Thu Aug 02, 2018 5:18 pm Post subject: Re: 1966 Rescue |
Car actually looks quite solid in the rockers and floors. Hope you get it driveable as planned. Good work with the engine so far.
Your shifter looks like either a Superior or a Sparkomatic, both being popular units in the '70's. |
anthracitedub Samba Member
Posted: Thu Aug 02, 2018 6:15 pm Post subject: Re: 1966 Rescue |
I like the sticker on the starter. |
Posted: Thu Aug 02, 2018 6:52 pm Post subject: Re: 1966 Rescue |
Rome wrote: |
Thanks for the good wishes, rockers are good except for couple of small rust through spots that I need to address on both sides. The floor has been replaced by the PO using sheet metal screws so I will need to weld them in and remove the screws. Overall the body and the untouched nose is in a good shape.
Good catch on the shifter it’s MR Gasket, I like it so it’s staying minus the knob. _________________ 69 Ghia Autostick (Also Gone)
68 Ghia (gone)
560SEC (gone)
1969
1968
sputnick60 Samba Moderator
Joined: July 22, 2007 Posts: 3907 Location: In Molinya Orbit
kman Samba Member
Joined: November 04, 2005 Posts: 739 Location: Michigan
rbsurfguy Samba Member
Joined: August 10, 2008 Posts: 1757 Location: Fairfax, Northern Virginia Formerly Huntington Beach, SoCal
Posted: Fri Aug 03, 2018 4:45 am Post subject: Re: 1966 Rescue |
kman wrote: |
anthracitedub wrote: |
What are you supposed to hit it with then? |
Clearly with a futbol bat, duh!! _________________ 1971 Ghia convertible (Body off rebuild)
2019 VW Atlas 4Motion
2012 Passat-Sold
See my build on The Samba at:
Jeff's 71 Vert Restoration/Reassembly http://www.thesamba.com/vw/forum/viewtopic.php?t=6...highlight= |
c21darrel Samba Member
Joined: January 22, 2009 Posts: 8206 Location: San Dimas
iowegian Samba Curmudgeon
Joined: February 16, 2005 Posts: 9826 Location: Somewhere between Dubuque and Keokuk
Posted: Fri Aug 03, 2018 11:45 am Post subject: Re: 1966 Rescue |
c21darrel wrote: |
I like this car, lots of what looks like Sea Blau under the paint. Too bad they welded the side trim holes and made off with the inside door trim.
Drop spindles? |
Indeed.
Filling the holes with Bondo is the proper procedure. |
Posted: Fri Aug 03, 2018 1:49 pm Post subject: Re: 1966 Rescue |
c21darrel wrote: |
Drop spindles? |
Yep one of the few odd things that was done to the poor car, I was hoping to find the dash trim tucked somewhere inside or the inside door trim but no luck and why weld a trim hole but not the floor pans is beyond me.
Nonetheless for a Midwest car it’s a solid foundation and it shall return to its original beauty.
Yep drop spindles and the back will be adjusted appropriately once I sort out the transmission and engine seals. The whole brake system will be replaced plus a dual master cylinder. I will get it roadworthy and drive it this fall then get the bodywork started. _________________ 69 Ghia Autostick (Also Gone)
68 Ghia (gone)
560SEC (gone)
1969
1968
Posted: Fri Aug 03, 2018 5:06 pm Post subject: Re: 1966 Rescue |
c21darrel wrote: |
Quote: |
Yep drop spindles and the back will be adjusted appropriately once I sort out the transmission and engine seals. |
Stock beam? ...may need small tire. |
Yes, I was thinking 175/55R15 or 145sr15 haven’t got there yet. Wheels will need to be replaced I am not a big fan of EMPI fake chrome stock wheels.
So I was just getting ready to replace the tie rod ends and my right is pressed in no threads! I don’t remember that on my 69 or 68 and I don’t see a mention of it in the manual. Is it the original 66 tie rod? _________________ 69 Ghia Autostick (Also Gone)
68 Ghia (gone)
560SEC (gone)
1969
1968
Posted: Fri Aug 03, 2018 6:00 pm Post subject: Re: 1966 Rescue |
c21darrel wrote: |
IIRC the ball joint drop spindles use the 68 and later larger diameter ends. |
Yes I Bought the later outer tie rod ends but I was talking about the inner end with the steering damper it’s pressed in the tie rod not bolted. I will get a picture uploaded. _________________ 69 Ghia Autostick (Also Gone)
68 Ghia (gone)
560SEC (gone)
1969
1968
Posted: Sat Aug 04, 2018 7:42 am Post subject: Re: 1966 Rescue |
karghia74 wrote: |
c21darrel wrote: |
Yes I Bought the later outer tie rod ends but I was talking about the inner end with the steering damper it’s pressed in the tie rod not bolted. I will get a picture uploaded. |
some pictures
pressed in tie rod end
the wheels it came with
68 Ghia (gone)
560SEC (gone)
1969
1968
Peter D. Samba Member
Joined: February 25, 2004 Posts: 718 Location: Stamford, CT
Posted: Sat Aug 04, 2018 8:09 pm Post subject: Re: 1966 Rescue |
karghia74 wrote: |
And I AM BACK
WHY!!!
Nice looking bumpers! _________________ 2019 Golf Alltrack, '65 Ghia Coupe Restoration in Progress |
Basketcase Samba Member
Posted: Sun Aug 05, 2018 1:31 pm Post subject: Re: 1966 Rescue |
looks like a good project. hope to see you out and about sometime. been a while since there was another Ghia siting around here. _________________ '72 Karmann Ghia Coupe (the Boss's) |
